Wanted Working Fuel Gauge for TR3A
TR3-Stu
If anyone has a working TR3A fuel gauge I'd be interested in buying it as mine looks good but, after trying it with two different working senders, I'm convinced it's a goner.
Stu
T
TR3-Stu
Have you tried putting 12v directly to guage.
I'm not sure if I did apply 12v directly to the gauge - I believe I wired it up to simulate the typical situation, going through the sender (actually two senders, one brand new. I'll give it a try.
Stu
GilsTR
I would send your fuel gauge to....
West Valley Instruments in SoCal.
They do a real good job.
You buy a used gauge...who knows it may be no better than what you already have.
Just my thoughts
Gil. NoCal
Martinld123 Austin Healey 100 BN2 fuel gauge not working Austin Healey 13
DanLewis Looking for an old-style fuel gauge [working or not] Spridgets 3
T BJ8 Tachometer and Fuel gauge stopped working. Austin Healey 27
Scott_Hower Fuel and temp gauge not working MG 5
H fuel gauge not working. Austin Healey 5
bugedd Fuel guage not working Spridgets 7
D new mecahnical fuel pump not working Spridgets 8
S Temp and Fuel guage not working Triumph 4
D Fuel Pump Not working Austin Healey 18
Andrew Mace Wedge TR7 fuel and temp. gauges not working Triumph 28
SCguy TR6 How can you tell if your TR6 fuel pump is working? Triumph 4
Woodie fuel guage not working Spridgets 8
D Trying to get back working on the 1974 Midget Spridgets 11
T Wanted Working overdrive unit Austin Healey Classifieds 2
D Overdrive Stops Working After Oil Change Austin Healey 26
S TR2/3/3A my OD stopped working after it was working Triumph 25
D TR2/3/3A Traffic at or and horn button not working Triumph 2
tr6nitjulius For Sale TR6 working/clean parts 4sale Triumph Classifieds 0
O Spitfire Tail lights not working Triumph 6
rgfrey 1959 Low Beam Headlights Not Working Austin Healey 5
Celtic 77 MGB Non working tach. MG 4
M Tachometer not working following ignition upgrade Austin Healey 10
S TR2/3/3A LED turn signal -- panel flasher not working Triumph 5
KVH General Tech Speedometer Not Working Triumph 5
S TR2/3/3A Horn not working unless I rotate the control head Triumph 6
S TR2/3/3A Speed O not working Triumph 27
M Wiper Motor Problem Not Working Spridgets 5
TRclassic3 TR4/4A A type OD working in 3rd but not in 4th Triumph 5
W Healey 100 Overdrive stopped working Austin Healey 15
1 MGB Lights not working MG 11
A MGA High beam indicator light not working MG 2
1 MGB Speedometer and tachometer on '66 MGB are not working MG 8
2billydavies TR2/3/3A generator doesn't appear to be working Triumph 7
Airwave BJ8 overdrive stops working after a while driving Austin Healey 17
warwick-steve Direction indicators not working Austin Healey 29
L Wanted WANTED: good Working Oil Pressure GAUGE Triumph Classifieds 0
Jim_Gruber Brake Light - Getting them working Spridgets 8
Superwrench Tach not working Austin Healey 6
M TR2/3/3A Panel lights not working........ Triumph 5
Rhodyspit75 Working on the Bugeye body Spridgets 19
J General TR D Type overdrive not working need suggestions Triumph 5
J Helping out some students working on a 59 bugeye Spridgets 6
R Master Cylinder change working Austin Healey 12
F Overdrive - working but not really working Austin Healey 14
T TR2/3/3A Air dam seems to be working very well Triumph 5
BN6_2197 BN6 brakes not working properly Austin Healey 9
Nelson Working under the car Spridgets 5
T Horn and rear right indicator stopped working...head scratch imminent Austin Healey 16
R Choke Not Working In Cool Weather Austin Healey 15
Gerry M TR6 Speedo stopped working Triumph 6
