Donovan2001
Member
Hello,
I recently got my Healey to turn over and the next step is to check if the fuel is getting to the carburetors. There is No fuel getting pumped thru the fuel lines. Then, I checked if power was getting to the fuel pump. There is No power getting to the pump.
So, I went and looked at the wire diagram and started tracing the wires. The first point I hit was the fuse box.
Is this the correct procedure? How do I check the fuses? Is there something I'm missing or am I right on track?
Thank you for your help
Donovan
65 AH 3000 MKIII
Donovan
65 AH 3000 MKIII
