TR4/4A Fuel Pump Gasket
RJS
Hi
I need to renew my fuel pump gasket and have a few questions:
  1. Is the single paper gasket sufficient? Any gasket dressing suggested?
  2. Do I need to disconnect the fuel lines?
  3. And if so, can the compression fittings be reused, or do they need to be renewed as well?
Thanks
Bob
bobhustead
Paper gasket usually supplied is fine. Use shellac, permatex , or RTV. Fuel lines need to be off. Fittings should remain as you find them. Be sure to use tube wrenches to break loose and finally tighten the lines.
Bob
charleyf
Bob
I have never owned a tube wrench and have changed at least a dozen + tube nuts. 1/2" wrench works fine for me.
I have now restored 4 TR's.
Charley
RJS
RJS
Got it, thanks. Later decided fuel lines should come off so I can properly clean flanges. Are tube wrenches same flare nut wrenches, because I have those for brake line work?
Bob
mctriumph
When you rebuild an OE fuel pump(recommended) the replacement diaphragms, as supplied, must have the attaching slot
dressed with a small file.Otherwise they will Not lock into the receiver arm properly.
Mad dog
charleyf
Mad dog
I have not had a problem with my several rebuilds. However I am curious as to exactly what you are saying. Can you address this once more maybe with a picture? As to what parts you are referring to.
Charley
M_Pied_Lourd TR2/3/3A Fuel pump sediment bowl gasket question Triumph 12
PeterK Fuel pump screen & gasket source Triumph 6
jsneddon TR2/3/3A TR3 Fuel Pump Gasket Triumph 23
R TR2/3/3A Fuel pump? Triumph 8
AndreL TR6 Conversion to electric fuel pump Triumph 14
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
D TR4/4A TR4a Fuel Pump Triumph 10
D MGB Fuel Pump MG 2
Martinld123 Electric Fuel Pump Austin Healey 6
S TR2/3/3A Fuel Pump??? Triumph 14
D Fuel Pump Ticking but Not Pumping Austin Healey 8
A Spitfire Fuel Pump Triumph 5
A Spitfire Spitfire Fuel pump issues Triumph 5
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
S fuel pump upgrade Spridgets 0
S Sprite Fuel Pump Upgrade Austin Healey 1
F TR4/4A New to forum - Rebuilt Fuel Pump and weeping float bowl Triumph 9
P XJ12 Fuel pump relay 85 Jaguar 4
petnatcar Fuel Pump Upgrade Austin Healey 2
R Electronic Conversion on an SU Fuel Pump? Restoration & Tools 2
T TR6 Fuel pump lines Triumph 2
1 TR2/3/3A TR3 Fuel Pump Thread Type? Triumph 4
R Electric fuel pump wiring Spridgets 4
T SU Fuel Pump Mounting Austin Healey 5
D TR2/3/3A More Fuel pump questions. Triumph 10
Donald1107 59 TR3A Fuel Pump Triumph 48
BobHaskell SU Fuel Pump Pressure Austin Healey 1
Cutrog1 Fuel Pump Ticking Austin Healey 13
MGTF1250Dave T-Series MG TF fuel line from tank to pump MG 3
S SU fuel pump servicing Austin Healey 4
71TR6 TR2/3/3A AC Fuel Pump Lever Triumph 10
E MGB 1965 mgb fuel pump removal MG 2
D For Sale Su fuel pump Other British Classifieds 5
D For Sale Su fuel pump Austin Healey Classifieds 5
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
vette A Quiet SU Fuel Pump Austin Healey 2
A TR4/4A AC Fuel Pump stuff Triumph 11
AngliaGT Fuel Pump Problems Spridgets 2
B SU Fuel Pump Parts Austin Healey 8
B TR4/4A Mechanical fuel pump vs electric Triumph 16
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
J TR4/4A Fuel pump saga Triumph 4
longbridgehealey Fuel pump racing, no gas Austin Healey 26
D General TR Fuel filter before the pump. Triumph 2
T 66 Austin Healey fuel pump replaced Austin Healey 30
