Spitfire Fuel Pump
afoster
I had recently rebuilt an engine for a triumph spitfire and, when the fuel pump was installed it did not work. My question is is the spacer for the fuel pump needed. I had put a new cam shaft in maybe the lobe on the cam is smaller not activating the pump? I had bought a new pump and it seems to be the same size (lever) and it doesn't work either.
Thanks
bobhustead
The Moss catalogue shows a spacer in 1978 to 1980. It also shows 3 fuel pumps. '62-'72, '73-'78, and '78-80. Gotta match your engine year.
Bob
TomMull
I have no expertise but It seems to me that there would be no harm in trying it with the spacer. You could also bench test the pumps.
Tom
bobhustead
Tom,
Like you, I lack direct experience, but the shape of the actuator arms on the three versions of the pump could be quite different. This could lead to jamming the arm against the cam lobe and damaging something if you put the wrong one in there.
Bob
sp53
Is it possible to get the fuel pump lever on the wrong side of the cam lobe? Get a flashlight and a mirror and take a look at the lobe position. if you need to turn the engine over by hand to get a better look at the lobe i would do that. I am not saying that is the problem or if it is even possible to get the pump in wrong, but I usually feel better when I can feel the pump hit the lobe and actuate the arm on the pump.
steve
TomMull
Tom,
Bob
I agree for sure but my logic was that if you tried it without the spacer it wouldn't hurt try try it with one. That said, I'd go with the correct pump setup for your car. Rimmer Bros have a good breakdown of the choices. > Triumph Spitfire Fuel Pump and Fittings | Rimmer Bros <
Also note that some of the replacement fuel pumps have a less than stellar reputation.
Bench test: If you can get a tube onto the inlet port on the pump into a container of fuel and work the lever by hand, it should pump.
Tom
R TR2/3/3A Fuel pump? Triumph 8
AndreL TR6 Conversion to electric fuel pump Triumph 14
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
D TR4/4A TR4a Fuel Pump Triumph 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
D MGB Fuel Pump MG 2
Martinld123 Electric Fuel Pump Austin Healey 6
S TR2/3/3A Fuel Pump??? Triumph 14
D Fuel Pump Ticking but Not Pumping Austin Healey 8
A Spitfire Spitfire Fuel pump issues Triumph 5
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
S fuel pump upgrade Spridgets 0
S Sprite Fuel Pump Upgrade Austin Healey 1
F TR4/4A New to forum - Rebuilt Fuel Pump and weeping float bowl Triumph 9
P XJ12 Fuel pump relay 85 Jaguar 4
petnatcar Fuel Pump Upgrade Austin Healey 2
R Electronic Conversion on an SU Fuel Pump? Restoration & Tools 2
T TR6 Fuel pump lines Triumph 2
1 TR2/3/3A TR3 Fuel Pump Thread Type? Triumph 4
R Electric fuel pump wiring Spridgets 4
T SU Fuel Pump Mounting Austin Healey 5
D TR2/3/3A More Fuel pump questions. Triumph 10
Donald1107 59 TR3A Fuel Pump Triumph 48
BobHaskell SU Fuel Pump Pressure Austin Healey 1
Cutrog1 Fuel Pump Ticking Austin Healey 13
MGTF1250Dave T-Series MG TF fuel line from tank to pump MG 3
S SU fuel pump servicing Austin Healey 4
71TR6 TR2/3/3A AC Fuel Pump Lever Triumph 10
E MGB 1965 mgb fuel pump removal MG 2
D For Sale Su fuel pump Other British Classifieds 5
D For Sale Su fuel pump Austin Healey Classifieds 5
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
vette A Quiet SU Fuel Pump Austin Healey 2
A TR4/4A AC Fuel Pump stuff Triumph 11
AngliaGT Fuel Pump Problems Spridgets 2
B SU Fuel Pump Parts Austin Healey 8
B TR4/4A Mechanical fuel pump vs electric Triumph 16
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
J TR4/4A Fuel pump saga Triumph 4
longbridgehealey Fuel pump racing, no gas Austin Healey 26
D General TR Fuel filter before the pump. Triumph 2
T 66 Austin Healey fuel pump replaced Austin Healey 30
C Well I Tried with a new SU fuel pump British Motor Corp 0
T TR2/3/3A Questions on fuel pump installation Triumph 7
sundown TR6 Fuel pump Triumph 10
