Recently had my carbs rebuilt. Since the rebuild - if the car sits for more than a couple of days - it is very difficult to start. It's like the car has kept no fuel in the bowls - like it has to pump gas from the tank, through the lines, the pump to the carb bowls until they finally fill up and then the car will sputter and start.
Never did this before - and there are no fuel leaks I can find anywhere.
Could this be a fuel pump problem that is causing some sort of vacuum that is sucking the gas back to the tank?
