Electric fuel pump wiring
rossco
Please check my work. 59 Bugeye, positive ground. SU Pump is bolted to frame. Is that my ground? Wire goes from screw terminal to ignition switch white terminal. Is that it or do I need something to the control box and/or coil?
RickF
That should do it!
R
rossco
Can I just run my fuel pump hot wire to the white wire terminal at the fuse block? It's easier than crawling up under the dash!
AndreL TR6 Conversion to electric fuel pump Triumph 14
Martinld123 Electric Fuel Pump Austin Healey 6
B TR4/4A Mechanical fuel pump vs electric Triumph 16
M TR2/3/3A Electric Fuel Pump Sound Triumph 7
Geo Hahn General Tech Emergency Electric Fuel Pump Triumph 29
johnrip Wedge tr7 electric fuel pump Triumph 2
Got_All_4 General TR Electric fuel pump for in my possibles bag Triumph 12
M TR2/3/3A Electric Fuel Pump Installation Triumph 12
T ?Changing BE to SU electric fuel pump Spridgets 8
T TR2/3/3A Location for electric fuel pump? Triumph 21
tinman58 TR2/3/3A Electric fuel pump questions. Triumph 5
Coyote1 General Tech Is there a quiet electric fuel pump Triumph 11
Gliderman8 TR6 Mounting location for electric fuel pump on TR6 Triumph 42
Gliderman8 More electric fuel pump questions... Triumph 6
Gliderman8 Electric fuel pump install help... please Triumph 24
L Best electric fuel pump for Weber DGV carb Spridgets 10
L Electric fuel pump for Weber DGV carb Austin Healey 3
bigjones Installing electric fuel pump Spridgets 34
M electric fuel pump power supply? Triumph 14
tban52 Electric fuel pump Triumph 5
wangdango TR6 76 TR6 electric fuel pump? Triumph 3
pjsmetana Electric Fuel Pump or carry a spare Mechanical? Triumph 15
RedTR3 TR2/3/3A TR3 Fuel Pump: Mechanical vs. Electric Triumph 14
jaegzie hooking up electric fuel pump Spridgets 7
veale001 Mechanical or Electric Fuel pump? Triumph 15
drooartz Running fuel lines/electric pump Spridgets 20
M_Pied_Lourd Old Electric Fuel Pump Question Triumph 15
Gliderman8 TR6 TR6 Fuel electric pump? Triumph 14
tosoutherncars Weber DGV, cont'd... Electric fuel pump install Spridgets 19
sparkydave Electric fuel pump question Spridgets 13
T Electric fuel pump question Triumph 29
emann Electric Fuel Pump Spridgets 6
bluemiata90 electric fuel pump....rear or engine compartment Triumph 7
J Power for electric fuel pump Spridgets 4
B BE Electric Fuel Pump Q Spridgets 22
D TR4/4A Electric Fuel Pump for TR4 Triumph 5
P Electric Fuel Pump for Bugeye??? Spridgets 12
S Electric Fuel Pump vs. Mechanical Pump Triumph 18
B Electric fuel pump for a bugeye - Questions. Spridgets 13
roofman Facet electric fuel pump - need advice Triumph 15
hondo402000 electric fuel pump installation Triumph 5
P TR4/4A TR4A Electric Fuel Pump Installation Triumph 7
K more electric fuel pump ?s MG 8
T Electric vs Mechanical fuel pump? Triumph 3
T AC Electric fuel pumps - time for some schooling.. Triumph 10
L Electric fuel pumps Lotus 10
J electric fuel pumps Austin Healey 9
Guido36 Electric Power Steering Austin Healey 2
DrEntropy Benz electric window battle Other Cars 13
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
