TR2/3/3A What temperature of electric fan switch do you use in your radiator?
sammy
Member
I am thinking of getting one of the Wizard radiators with an electric fan for the TR3A. I see it comes with a bung for a temperature probe to turn the fan on. I was wondering at what temperature the fan should turn on? I do not want it running too often and I do not want it not running often enough.
Hamish Racing
depends where the temp boss is
mine is in the metal return from the bottom outlet pipe and is 88/79 c 190/174 f this suite the car well
the engine builder has the boss in the top of the rad and fitted a 92/87c 197/188f version but i think this shows a bit hot on the car temp gauge. this position is also the hottest and doesn't take into account the cooling effect of the rad.
i wanted to know it it was still over hot after the rad had played its part as there would be a difference in air flow between driving and queuing.
this is with a 4lb cap.
i use a 220w fan fitted to rad.
poolboy
Slightly above the Normal Operating Temperature (NOT)...either as indicated on your dash temperature gauge or something written in the Cooling section of your manual or the Thermostat rating.
TFB
I installed the wizard with fan kit in my tr3 about 8 years ,20k miles ago.
No problems.An on/auto manual toggle hidden under my dash works well.
If I roll up to traffic I can turn it on rather than wait for the temp to rise.
I Think on was 185 and off was 175 but I just ordered their tr3 setup.
Tom
J TR4/4A Water temperature and electric fan in a TR4 Triumph 5
T Wanted WTB early TR 4 electric temperature gauge Triumph Classifieds 5
T General TR Request pictures of TR3B & TR4 electric temperature gauges Triumph 15
Jer is it posible to fit an electric temperature gauge ? Spridgets 4
K Smiths Electric Temperature Gauge Triumph 7
C Engine Operating Temperature Austin Healey 21
PDIGIO_6x3 TR6 Temperature Compensators Triumph 3
Michael Oritt Powder Coating Temperature Limit Austin Healey 7
BierRunner TR6 Temperature Gauge Triumph 8
A MGB Stuck water temperature sensor MG 26
R Coolant temperature gauge Spridgets 8
nevets Coolant Temperature Austin Healey 13
longbridgehealey Temperature sender Austin Healey 18
TRclassic3 TR2/3/3A Timing and temperature Triumph 13
B TR2/3/3A TR3 Temperature gauge Triumph 19
B Temperature Sensor Removal Austin Healey 10
R Temperature sensor Help me Austin Healey 18
S Meaning of the ā€˜dotsā€™ under the temperature scale? Austin Healey 3
GS67 1500 Operating Temperature Spridgets 2
N BT7 water temperature sensor removal Austin Healey 13
pkmh How hot can it [temperature gauge] get? Austin Healey 4
R TR2/3/3A Temperature Gauge for 1954 TR-2 & Hand Crank Triumph 17
S BJ7 frozen temperature sensor to block Austin Healey 17
K TR2/3/3A Temperature Gauges Again Triumph 5
S TR2/3/3A Temperature Guage Triumph 3
BN6_2197 Question on correct oil temperature Austin Healey 15
Bugeyze Temperature Austin Healey 14
BN6_2197 Question on Oil Temperature Gauge Austin Healey 1
6 Temperature/Pressure Gauge Spridgets 7
D TR2/3/3A Temperature gauge Triumph 13
K TR2/3/3A Temperature sensor size where it fits in the housing? Triumph 4
K TR2/3/3A Replacement Temperature Gauge Triumph 5
M TR4/4A Temperature and Fuel Gauge Wiring...Help Wanted Please Triumph 6
Michael Oritt Temperature sender fitting at radiator on BN1 Austin Healey 3
R TR2/3/3A Normal vs Max acceptable coolant temperature? Triumph 14
S Air/Fuel Mixture affect on Coolant Temperature? Spridgets 2
Dave Richards Temperature Guage Austin Healey 11
J 1964 AH 3000 operating temperature Austin Healey 10
BN6_2197 BN6 Temperature Issue Austin Healey 12
G TR2/3/3A Routing of TR3 Temperature Gauge Triumph 2
BN6_2197 Oil Temperature Gauge for BN6 Austin Healey 6
andrea Problem with the throttle linkages due hing external temperature Austin Healey 34
DanLewis Thermostatic fan switch that fits Bugeye radiator temperature sensor hole? Spridgets 19
GBT MGB-GT air temperature control valve MG 1
B Path of Oil Pressure/Temperature Lines Spridgets 2
K TR2/3/3A TR3 Temperature Gauge...cost to repair? Triumph 11
Tugboat TR2/3/3A Original T3A Temperature Gauge Triumph 13
Anthony_S temperature gauge....HELP Triumph 18
Nelson "High" temperature adhesive Spridgets 7
L Temperature sensor relocation in BE with A 1275 Spridgets 8
