Smiths Electric Temperature Gauge
karls59tr
Bronze
Messages
2,702
Reaction score
44
I'd like to upgrade the temp gauge in my TR3 to one of these units. Anyone know how they operate in terms of where they would connect to the cooling system? It wouldn't use the same gas filled tube system as the original but what would it use?
Andrew Mace
Messages
6,262
Reaction score
19
Normally, they'd use a sending unit, which would locate pretty much exactly where the original sender/tube would go. And most all of the electrical gauges (at least those from a TR4 to more or less match your other gauges) would have a voltage stabilizer in the circuit as well.
K
karls59tr
Bronze
Messages
2,702
Reaction score
44
Some time ago I mentioned on his forum about an experience I had with my TR3 overheating. The bypass hose had blown but I hadn't realized it until I popped the hood some time later. I had lost about a gallon of coolant but the temp gauge never registered the higher temperature! I removed the gauge and tested it in boiling water and the gauge registered the higher temp. Any ideas on why the gauge wouldn't register when it was really needed? If the bypass hose blows and there is no coolant surrounding the gas tube then the gauge isn't going to register the coolant loss.Is this correct?
TR3driver
Great Pumpkin - R.I.P
Messages
19,540
Reaction score
14
Well, the bulb certainly has to get hot for the gauge to read hot. But even without liquid coolant in the thermostat housing, it would still get hot by either conduction through the metal, or by the steam going by (assuming there was any coolant at all in the engine).
Last time I popped a bypass hose, the engine never did actually overheat. Instead the hose sprayed coolant all over and I pulled over for the water coming out of the vents in the hood. I'm guessing that something similar happened to you.
PS, the same problem applies to the electric gauge; the bulb of the sending unit has to get hot for the gauge to read hot.
TR3driver
Messages
19,540
Reaction score
14
Indeed, the early TR4 temp gauge looks nearly identical to the TR3 gauge. And as Andy notes, the sender screws into the same hole; and you need a voltage "stabilizer" in the circuit.
However, aftermarket gauges usually don't require a VS, so you need to know what you've got. The temp sender needs to match the gauge as well, they aren't all the same.
Andrew Mace
Messages
6,262
Reaction score
19
Well, you'd think so, but it's not always the case. Years ago, I had a Saab 99 that would slowly lose coolant (ultimately turned out to be water pump and housing, a true PITA, but I digress....). Yes, to some extent, the temp. gauge would hint at problems. However, the electric fan switch was mounted very high on the radiator. Once the coolant level dropped below that switch, it would not sense the ever hotter coolant, so the fan didn't kick in. Very frustrating! :wall:
smaceng
Messages
1,163
Reaction score
Many times I have heard reports that the driver said that the temperature gauge reading went up, and the driver was concerned, but did not stop to investigate. then the temp reading went down, and the driver thought all was well. Some time later, the engine blew. Just as was said above, once the water turns from liquid to vapor, the temperature sensor no longer provides an accurate reading (too low) and a false sense of security. If one wanted belt and suspenders (foolish, just watch the gauge), you could add a temperature sensor as used on air cooled engines.
Scott in CA
K
karls59tr
Bronze
Messages
2,702
Reaction score
44
In my case I would have expected the temp gauge to read unusually high when unbeknownst to me the bypass hose is pissing coolant all over the ground and the gauge is reading normal giving me no indication that there is a problem. The only thing foolish is to watch a temperature gauge that reads normal when the engine is overheating.
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
S WANTED: Healey BN1 "Smiths" Fuel Gauge (Dead or Alive) Austin Healey Classifieds 3
nichola TR6 Smiths volt gauge needle barely moves Triumph 25
T Wanted Smiths fuel gauge for Mk 1 Bugeye Sprite [FG2530/31] Spridgets Classified 1
RAC68 Calibrate Smiths Tachometer Austin Healey 12
B For Sale Austin Healey 100 Smiths Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer Austin Healey Classifieds 0
angelfj1 TR2/3/3A Restoring Smiths heaters as fitted to a 1959 Triumph TR-3A Triumph 4
Jim_Gruber Source for Smiths Gauges in UK I believe Spridgets 7
D Smiths Heater rebuild. Restoration & Tools 1
D TR2/3/3A Smiths Heater rebuild. Triumph 2
T TR2/3/3A Smiths Heater Checkout Triumph 7
B Smiths RVI Positive Ground Tachometer Bench Test ? Austin Healey 24
drambuie Converting a smiths clock to positive ground Austin Healey 12
J Help with Smiths heater. Other British Cars 4
W 100-4 Smiths heater clips Austin Healey 11
G help id this smiths speedo Other Cars 2
Tinkerman Jaeger and Smiths Speedometers Triumph 5
luke44 TR2/3/3A TR3 Smiths Heater Plate Triumph 3
RJS Smiths PCV Valve Differences? Triumph 2
M Smiths Fuel Tank Sending Unit Austin Healey 3
R smiths guage problem- need advice Austin Healey 4
M Smiths fuel tank sending unit Triumph 1
C Smiths or Lucas Gauge? Triumph 8
58Custom New! Schematic for Smiths RVI tachometer Spridgets 9
Tinkerman Smiths Heater Lables Triumph 11
angelfj1 New WIKI regarding Smiths Heaters Triumph 0
angelfj1 Link to Smiths Heater Article Now Fixed Triumph 0
angelfj1 How To Restore a Smiths Heater Restoration & Tools 8
angelfj1 Smiths Heater - Completely Restored Triumph 3
angelfj1 Weekend Project- Smiths Heater Restoration Triumph 13
amcboy A little about Smiths gauges... Triumph 31
angelfj1 Smiths heater Parts Triumph 8
tosoutherncars NOS Smiths gauges: Bugeye? Spridgets 4
TR674 Smiths Speedo Triumph 9
B Smiths Dual Guage Repair Spridgets 13
wkilleffer MGB Question about the Smiths temp. gauge- 74 MGB MG 19
coldplugs Be thankful [Re Lucas, Smiths, SU, et al Other British Cars 10
dklawson Needed - 4" Chrome Smiths Bezel Triumph 4
A Brighter Smiths Instrument Bulbs --- Any ideas? Austin Healey 25
S Which Smiths heater in '65 AC Cobra? Other British Cars 5
T T-Series smiths or arnolt heater installation in an MGTD MG 1
Kira Smiths Clocks Pre 1950 Other British Cars 6
G Tacho Smiths RVI2401/00EN needed MG 0
G SMITHS SPEEDOMETERS MG 2
J Smiths Tachometer MG 8
AndreL TR6 Conversion to electric fuel pump Triumph 14
Guido36 Electric Power Steering Austin Healey 2
Martinld123 Electric Fuel Pump Austin Healey 6
DrEntropy Benz electric window battle Other Cars 13
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
Top Bottom
