Benz electric window battle
Platinum
After about a decade with the right rear window in Diesela taped up with aluminum duct tape, decided to take it apart and FIX it. Got the regulator out to find it all bent from straining against a window track felt that had been more like a C-clamp than a seal. Four hours of faffin' around with a 16-oz "soft blow" hammer, pry-bars, silicone lubes and bearing grease. Disassembled the motor, lubed it and tested with a 12V power supply. Got it all back together again and went to complete the "Ten Times Test"... five cycles through and on number six it stalled half-way up. Thumped the inner panel a couple times and it completely closed. Pulled the switch back out and will NOT attempt to use that window again. Problem solved. :devilgrin:
Gliderman8
Try resetting the ECU code for a non-operating window... oh wait, you have to get the reset code from the dealer :crazyeyes:
Platinum
Local "dealer" seems to have dropped all models made before 1989.
Can you imagine?!?
JPSmit
I may have pointed you in the direction of these before but, this guy is a genius.
LarryK
Most dealers don't want anything 10 yrs or older, except to sell. Places here charge double time for older cars.
Platinum
Not so much genius as experienced. I've seen a couple of his videos.
Diesela's regulators are the alloy type, managed to beat this one back into submission. I'm certain the motor is tired, the brushes are down to nubbins.
We didn't take in anything (usually) built after 1985, work was by the hour, book times were only a suggestion.
A guy with a Corniche convertible INSISTED we fix the intermittent wiper feature, diagnosed it to be the timer device. A $600 "black box" (likely just a 555 timer chip and input/output plug) 5"x5"x3"... it was seemingly put in at factory before dash and windshield were installed. Explained to him it'd be easier to just flick the wipers on and off again. In the end it cost him over $2K for me to R&R the facia and instruments to swap out that box. He was happy as a clam to pay up. 🤷
Popeye
Bronze
Sounds like an adventure - alloys can become quite brittle, and breaking them is no fun.
However, I was under the impression that Mercedes did a good job of parts support for older models. (Assume at a price!) Is this not the case? (Given an infinitely deep wallet, can one buy a new window regulator?)
Platinum
They're available, but: that window is seldom used, my twisting and beating were judiciously applied so as to NOT crack the thing, the alloy would either be straightened or there'd have been a wood "clothes prop" to keep the glass in position as I hunted down a used one. 😉
As it is, the thing works so far. Now I may be inspired to fix the A/C, its only been dysfunctional for a decade. 😏
I just got a replacement console A/C & heater control from an Ebay ad a few weeks ago. That requires pulling half the dash apart to deal with! Maybe I can find the faulty wiring for the radio while I'm in there. That's got about ten splices in four extra feet of junk wires and "wire nuts" as connections.
LarryK
R-134a conversion is not cheap, R-12 is like gold.
Platinum
LarryK
I watch craigslist and have been buying 12. $30 a can.
Platinum
I'll need to pay attention to CL then. Rather just change out the receiver-dryer and vacuum it down than go thru the drill (and expense) of conversion to 134a. We'll see.
DrEntropy W123 Benz recurring problem Other Cars 16
JPSmit Late night Benz [no pics] Other Cars 3
C FS: 2003 Mercedes Benz CL600 with Extended Warranty Other Cars 0
aeronca65t Mercedes Benz Fintail Other Cars 6
N Jaguar XF VS Mercedes-Benz E class Jaguar 1
NutmegCT 1971 Mercedes-Benz 250 Spotted 1
DrEntropy Benz lockout... Other Cars 3
NutmegCT Mercedes-Benz E320 Other Cars 7
texas_bugeye Look what parked next to my baby benz! Spotted 0
PC around the Benz Other Cars 2
weewillie HEY DOC here's a benz for you Other Cars 9
Harry_Ward Mercedes Benz SCL600? Other Cars 12
Sherlock Dodge Sprinter [aka Mercedes-Benz Van] Other Cars 5
AndreL TR6 Conversion to electric fuel pump Triumph 14
Guido36 Electric Power Steering Austin Healey 2
Martinld123 Electric Fuel Pump Austin Healey 6
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
R Spitfire Electric Fan Triumph 2
J Electric Ready? Electric Upgrades of All Sizes 3
Basil Remember the Royal Electric E-Type Electric Upgrades of All Sizes 0
Gliderman8 Electric classic cars Electric Upgrades of All Sizes 22
B Intermittent Loss of Electric Power Austin Healey 18
Taftster MGB Electric Gauges Read High, Any guesses? MG 5
R Electric fuel pump wiring Spridgets 4
Patrick67BJ8 Low-Profile Electric Puller Fans Austin Healey 51
Simmo General Tech Electric Cooling Fans. Are they a problem? Triumph 19
Rob Glasgow New Fangled Electric Overdrive Austin Healey 9
R Rewind electric motor Restoration & Tools 3
JPSmit Electric Midget Spridgets 1
M TR6 Electric Powered Rack & Pinion. Triumph 4
longbridgehealey Electric Fan vs. Texas Cooler Austin Healey 21
D Spitfire Electric fan Triumph 3
B TR4/4A Mechanical fuel pump vs electric Triumph 16
M TR6 Rimmer Bros. Electric Fan Conversion Triumph 0
M TR6 Dowel Pins, Pulley Adaptor, Revotec Electric Fan Kit Triumph 1
K TR2/3/3A An Electric TR3 ?? Triumph 3
Lin Electric Relay Placement Austin Healey 11
nevets interesting article about converting classic cars to electric power Austin Healey 7
FlyingCat Spitfire Electric Radiator Fan Triumph 10
M The electric E Jaguar 1
J TR4/4A Water temperature and electric fan in a TR4 Triumph 5
N Electric fan opinions???? Spridgets 2
P electric clutch Austin Healey 1
M TR2/3/3A Electric Fuel Pump Sound Triumph 7
Geo Hahn General Tech Emergency Electric Fuel Pump Triumph 29
B Electric fan Austin Healey 2
T Wanted WTB early TR 4 electric temperature gauge Triumph Classifieds 5
T General TR Request pictures of TR3B & TR4 electric temperature gauges Triumph 15
rjc157 TR6 Electric fan Triumph 5
J Spitfire Electric brake switch issue Triumph 5
