Spitfire Electric Fan
R
Richardspur
The prior owner installed an electric cooling fan and is one of many things I am sorting out. There is a switch mounted on the top on the right side of the radiator. There is temperature prob with a long metal wire just hanging in front of the radiator, does anyone know how this is supposed to be installed or where I can find instructions don't know the manufacture.
1974 1500 spit
Platinum
Sounds like you've got the "pig in a poke" for that rig. Have you had the car running? Asking to determine if there's an overheating issue.
Can you post a few pics of the probe and associated "stuff"?
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
longbridgehealey Electric Fan vs. Texas Cooler Austin Healey 21
D Spitfire Electric fan Triumph 3
M TR6 Rimmer Bros. Electric Fan Conversion Triumph 0
M TR6 Dowel Pins, Pulley Adaptor, Revotec Electric Fan Kit Triumph 1
FlyingCat Spitfire Electric Radiator Fan Triumph 10
J TR4/4A Water temperature and electric fan in a TR4 Triumph 5
N Electric fan opinions???? Spridgets 2
B Electric fan Austin Healey 2
rjc157 TR6 Electric fan Triumph 5
J TR2/3/3A Radiator removal ?? electric fan vs original Triumph 7
S TR4/4A electric fan Triumph 6
Joe Reed MGB Removing stuck blade on factory electric cooling fan??? MG 7
R TR4/4A Thinking About an Electric fan Triumph 10
rjc157 Electric radiator fan Austin Healey 11
G TR2/3/3A Electric Fan controllers Triumph 4
R TR6 TR6 Electric Fan Triumph 10
longbridgehealey Electric fan for Bugeye Spridgets 6
sqbsprite TR6 Electric cooling fan switch - where is best location to mount? Triumph 2
GTP1960 TR2/3/3A Electric fan wiring Triumph 11
Rut Electric fan Spridgets 11
Tinkerman electric fan for my TR 3 Triumph 13
This14u Another Electric Fan Thread-What to Buy? Triumph 2
Crankshaft Electric fan question Triumph 19
HealeyRick Electric Cooling Fan Install Austin Healey 5
M Electric cooling fan Triumph 2
A Manual Electric Fan Triumph 6
George Zeck Electric Fan & Tranny coller ??? Spridgets 8
hondo402000 TR6 Electric Fan help needed for TR6 Triumph 5
TR4A_IRS Electric Fan Question Triumph 34
tmc TR2/3/3A Hayden electric fan kit - - TR3A Triumph 15
M TR4/4A TR4A Electric fan wiring ? Triumph 2
BugeyeNJ58 Push or Pull - Electric Fan Spridgets 3
M Electric fan and shroud for a 100 4 Austin Healey 3
R upgrade to electric cooling fan? Spridgets 17
M electric fan ? Triumph 3
C WHICH ELECTRIC FAN BEST FOR 67 3.8 S ? Jaguar 3
bigjones 1500 - electric cooling fan Spridgets 6
eschneider custom electric radiator fan switch Lotus 3
Mark Jones Electric radiator fan replacement options Triumph 3
D Electric Fan Size Spridgets 5
bighealeysource add on electric fan for BN6 Austin Healey 33
OregonTR4A Electric fan woes Triumph 5
K Spitfire Electric Fan- Spitfire Triumph 10
RJS TR4/4A TR4A Cooling Fan Upgrades - Non Electric Triumph 5
mountainman Electric Fan Choice? Triumph 3
mountainman TR2/3/3A TR3 Electric Fan/Reg Fan Triumph 11
deadair TR2/3/3A TR3/4 Electric Fan Conversion Triumph 42
wangdango XKE electric fan brushes? Jaguar 7
mountainman TR2/3/3A TR3 Electric Cooling Fan Triumph 8
Top Bottom
