Spitfire Electric Fan- Spitfire
K
KSIS
Who has fitted a electric fan to their Spit and what did you use. I went trudging through the junk yard today and came home with a narrow Geo Metro fan but it looks too tall. What would you recommend?
I haven't done this. I was just thinking about replacing the old 4-blade with a new plastic style. We don't have very many junk yards in CO. either.
I agree with Andy. We never had any issues with cooling with my wife's MkIII at least here in Virginia.
Scott
Gareth Thomas states in his Triumph Tuning Manual that, "a mechanical fan robs 7hp at 5500 rpm"
search ebay for "electric radiator fans"
I was hoping to find a good donor in the junk yard. 10 buck seems like a good price to me. I thinking because I am running a 1300, dual SU's header,stainless exhaust. I would like to tweak horse power with out cracking the engine open.
That will be later when I find a 1300 to put on a stand and build.
That sounds significant. What's it, about 10% ?
The thing I noticed the most after removing the big red 13 blade fan from my TR6 was that during the process of shifting the engine speed did not drop off as much during that interval that the clutch was depressed. I contribute that to the elimination of air resistance on the crank.
I used a fan out of a fiat x-19 mounted with some strap steel to the front of the radiator. It's running backwards but it works. It also fits under the fabbed up radiator shields I have. It's actually the same fan that's on the last Spits, the one with the rad that leans forward.
FWIW
I like the idea of the X-19. they just got one in at the Pick-n-Pull.
One big problem with cooling a Spitfire is the lack of a decent shroud around the fan. The fan won't draw air through the radiator because it spills in around the side of they fan. Spit tends to overheat in slow traffic on hot days. I think a later model plastic fan with a close fitting shroud may take care of it. I haven't found one pre-made so it would have to be fabricated.
Most of the electric aftermarket fans have somewhat of a shroud built into the fan. I found a SPAL fan that was perfect, but not cheap. A trip to the salvage yard with a tape measure should help. The problem I foresee is that the space between the water pump and radiator isn't very deep. You may need to tilt the radiator for extra clearance.
I got mine from Moss. The smallest one they sell. Its really really powerful... I actually had to raise my idle for when it kicks on it was causing enough of a draw that it bogged the engine down. Its been a really good thing here in FL, but the temp probe it came with was a hunk-o-junk.
I also relocated mine to be a pusher fan... as this way it gives SOME sort of anti-rock protection to my slanted, close to the ground, radiator.
L Spitfire Spitfire electric fan installation... Triumph 11
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
R Spitfire Electric Fan Triumph 2
longbridgehealey Electric Fan vs. Texas Cooler Austin Healey 21
D Spitfire Electric fan Triumph 3
M TR6 Rimmer Bros. Electric Fan Conversion Triumph 0
M TR6 Dowel Pins, Pulley Adaptor, Revotec Electric Fan Kit Triumph 1
FlyingCat Spitfire Electric Radiator Fan Triumph 10
J TR4/4A Water temperature and electric fan in a TR4 Triumph 5
N Electric fan opinions???? Spridgets 2
B Electric fan Austin Healey 2
rjc157 TR6 Electric fan Triumph 5
J TR2/3/3A Radiator removal ?? electric fan vs original Triumph 7
S TR4/4A electric fan Triumph 6
Joe Reed MGB Removing stuck blade on factory electric cooling fan??? MG 7
R TR4/4A Thinking About an Electric fan Triumph 10
rjc157 Electric radiator fan Austin Healey 11
G TR2/3/3A Electric Fan controllers Triumph 4
R TR6 TR6 Electric Fan Triumph 10
longbridgehealey Electric fan for Bugeye Spridgets 6
sqbsprite TR6 Electric cooling fan switch - where is best location to mount? Triumph 2
GTP1960 TR2/3/3A Electric fan wiring Triumph 11
Rut Electric fan Spridgets 11
Tinkerman electric fan for my TR 3 Triumph 13
This14u Another Electric Fan Thread-What to Buy? Triumph 2
Crankshaft Electric fan question Triumph 19
HealeyRick Electric Cooling Fan Install Austin Healey 5
M Electric cooling fan Triumph 2
A Manual Electric Fan Triumph 6
George Zeck Electric Fan & Tranny coller ??? Spridgets 8
hondo402000 TR6 Electric Fan help needed for TR6 Triumph 5
TR4A_IRS Electric Fan Question Triumph 34
tmc TR2/3/3A Hayden electric fan kit - - TR3A Triumph 15
M TR4/4A TR4A Electric fan wiring ? Triumph 2
BugeyeNJ58 Push or Pull - Electric Fan Spridgets 3
M Electric fan and shroud for a 100 4 Austin Healey 3
R upgrade to electric cooling fan? Spridgets 17
M electric fan ? Triumph 3
C WHICH ELECTRIC FAN BEST FOR 67 3.8 S ? Jaguar 3
bigjones 1500 - electric cooling fan Spridgets 6
eschneider custom electric radiator fan switch Lotus 3
Mark Jones Electric radiator fan replacement options Triumph 3
D Electric Fan Size Spridgets 5
bighealeysource add on electric fan for BN6 Austin Healey 33
OregonTR4A Electric fan woes Triumph 5
RJS TR4/4A TR4A Cooling Fan Upgrades - Non Electric Triumph 5
mountainman Electric Fan Choice? Triumph 3
mountainman TR2/3/3A TR3 Electric Fan/Reg Fan Triumph 11
deadair TR2/3/3A TR3/4 Electric Fan Conversion Triumph 42
wangdango XKE electric fan brushes? Jaguar 7
