Electric Cooling Fan Install
HealeyRick
The Big Healey cooling system is quite adequate when used according to its design parameters ... 50 degree damp, foggy spring days in England. Add some additional heat from a typical stateside summer day, or worse yet a warmed over V-8 motor, and you'll find yourself spending some nervous moments staring at your Smiths dual gauge.
When doing my motor swap, I had added cooling rows to the recored radiator and installed a Texas Kooler mechanical fan. And on the possible eventuality that wouldn't be enough and I'd need an auxiliary electric fan, I wired in a 130 amp alternator.
My set-up cooled fine when the car was in motion, but began to overheat in traffic or at idle. The mechanical fan has a couple of problems. First, when you most need it, it's loafing along at idle. And second, because of the vee-shaped crossmember of the chassis, the fan only covers about 2/3 of the radiator core. And that crossmember also makes it tough to design a fan schroud that will cover the entire rad core.
So the search was on for a suitable auxiliary electric fan. When it comes to engines, I subscribe to "There's no substitute for cubic inches" theory. And when it comes to fan motors, "There's no substitute for CFMs." Trouble is, putting a big Cubic Ft/Min fan in a Healey is like putting in a big cubic inch engine ... there are packaging issues ... not much extra space.
What finally produced the best numbers was this 14" Maradyne fan: https://www.thewedgeshopstore.com/products/Maradyne-14in-Electric-Fan.html It puts out over 2000 cfms, draws low amps and is only 3.32" deep. And at 14", it will cover just about the entire front of the core to push air through:
I used some drilled stock to make some brackets that mount to the top and bottom bolts on the radiator sides
and had to push out the cross brace to get sufficient clearance for the motor: https://www.britishcarforum.com/bcforum/u...Hack#Post856756 You should also undo the three bolts holding the shroud to the upper crosspiece as they are likely to pull through when jacking out the crossbrace. Reinstall after you've established the appropriate clearance.
I wired in a Derale adjustable fan controller: https://www.summitracing.com/parts/DER-16759/ , set to kick the aux. fan in at 190 degrees.
The Maradyne fan can be used as a pusher from in front of the radiator or a puller from behind. It comes set up as a puller and to make it work as a pusher, you need to flip the fan blade over AND reverse the polarity of the fan motor wiring. The instructions kind of overlooked the second part and I was less than happy when I first installed the fan and watched the temp climb to 230 degrees. I was even less happy when I walked to the front of the car and felt the tremendous airflow BLOWING OUT THROUGH THE GRILLE! After taking everything apart and fixing that little problem, the fan now triggers at 190 and blows plenty of cool air through the rad and it seems to be sitting there pretty well at idle. This is what it looks like installed:
Hope this is helpful to those of you fighting overheating.
Lin
Rick,
Did you keep the mechanical fan, or is the electric fan a replacement rather than a supplement?
Lin
HealeyRick
HealeyRick
Lin,
So far I've kept the mechanical fan. The car was cooling fine on just the mechanical as I was driving at speeds over 30 mph. The electric is just to act as an auxiliary once speeds start to drop and the temp climbs. I've read differing opinions as to whether a pusher fan installed with a puller will "fight" each other, but so far it seems to be working ok with both Time will tell.
bighealeysource
Bronze
Hey Rick,
Got a pusher fan on my 100M along with a larger capacity radiator and Texas cooler fan. Have not had to use it until this recent awful heat wave and then only if I get stuck in traffic or stop lights. Then I turn it on - set up a toggle switch under the dash - and the pusher will keep it from running hot. But if not switched on in this 95+ heat, engine will start to creep up from its normal 160 to wards 190 or 200 quickly if stuck at a stand still. Think the larger radiator and Texas cooler work great under normal circumstances.
Regards,
Mike
Healey_Z
Hey Rick, looks like a practical set up. I have pretty much the same thing on my ride, with the fan tied to a correct looking toggle.
Joe Reed MGB Removing stuck blade on factory electric cooling fan??? MG 7
sqbsprite TR6 Electric cooling fan switch - where is best location to mount? Triumph 2
M Electric cooling fan Triumph 2
R upgrade to electric cooling fan? Spridgets 17
bigjones 1500 - electric cooling fan Spridgets 6
RJS TR4/4A TR4A Cooling Fan Upgrades - Non Electric Triumph 5
mountainman TR2/3/3A TR3 Electric Cooling Fan Triumph 8
johnrip Wedge Electric cooling fan TR7 Triumph 6
Cyberpyr8 Powering the electric cooling fan Triumph 18
71tr electric cooling fan Triumph 11
Simmo General Tech Electric Cooling Fans. Are they a problem? Triumph 19
H 2500M Came Originally With Electric Cooling Fans? TVR 19
AndreL TR6 Conversion to electric fuel pump Triumph 14
Guido36 Electric Power Steering Austin Healey 2
Martinld123 Electric Fuel Pump Austin Healey 6
DrEntropy Benz electric window battle Other Cars 13
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
R Spitfire Electric Fan Triumph 2
J Electric Ready? Electric Upgrades of All Sizes 3
Basil Remember the Royal Electric E-Type Electric Upgrades of All Sizes 0
Gliderman8 Electric classic cars Electric Upgrades of All Sizes 22
B Intermittent Loss of Electric Power Austin Healey 18
Taftster MGB Electric Gauges Read High, Any guesses? MG 5
R Electric fuel pump wiring Spridgets 4
Patrick67BJ8 Low-Profile Electric Puller Fans Austin Healey 51
Rob Glasgow New Fangled Electric Overdrive Austin Healey 9
R Rewind electric motor Restoration & Tools 3
JPSmit Electric Midget Spridgets 1
M TR6 Electric Powered Rack & Pinion. Triumph 4
longbridgehealey Electric Fan vs. Texas Cooler Austin Healey 21
D Spitfire Electric fan Triumph 3
B TR4/4A Mechanical fuel pump vs electric Triumph 16
M TR6 Rimmer Bros. Electric Fan Conversion Triumph 0
M TR6 Dowel Pins, Pulley Adaptor, Revotec Electric Fan Kit Triumph 1
K TR2/3/3A An Electric TR3 ?? Triumph 3
Lin Electric Relay Placement Austin Healey 11
nevets interesting article about converting classic cars to electric power Austin Healey 7
FlyingCat Spitfire Electric Radiator Fan Triumph 10
M The electric E Jaguar 1
J TR4/4A Water temperature and electric fan in a TR4 Triumph 5
N Electric fan opinions???? Spridgets 2
P electric clutch Austin Healey 1
M TR2/3/3A Electric Fuel Pump Sound Triumph 7
Geo Hahn General Tech Emergency Electric Fuel Pump Triumph 29
B Electric fan Austin Healey 2
T Wanted WTB early TR 4 electric temperature gauge Triumph Classifieds 5
T General TR Request pictures of TR3B & TR4 electric temperature gauges Triumph 15
rjc157 TR6 Electric fan Triumph 5
J Spitfire Electric brake switch issue Triumph 5
johnrip Wedge tr7 electric fuel pump Triumph 2
