Group statistics
Members:
19
Threads:
5
41
Discussions:
1
Photos:
Latest posts
Latest photos
Group events
Electric Upgrades of All Sizes
Electric Ready?
jcw67spitfire
Just looking for some opinions and personal experiences on small electrical repairs. I went ahead and ordered a new starter solenoid/relay but haven't installed it yet, The old one with the push button on the back looks fine and sounds strong, and I assume it is the original one for our1967 Spitfire MK2. I'm debating going ahead and changing it out for the new one (if nothing else, to make sure it works properly), or just letting the old one ride until is goes kaput! I'm not sure whether to expect it to kind of putter out gradually toward the end and offer up a few more volts to turn the starter motor, or whether it will just Bite the Bullet all at once at some unexpected time. So far, besides a Pertronix electonic ignition in the Delco Demy, I've put in new coil and plug wires, a new coil, a new ignition and key, and one new inline fuse (I think I put a 30 amp fuse in there where the original might have been a 35 amp one). I'm also thinking of going ahead and ordering a new control unit (dynamo voltage regulator) in case the one in there now suddenly fails us. Yea, I guess I could be going overboard, but then I worry about some of these parts that will fit Spitfire MK1s and MK2s from '62 to early '67 being harder to find or going out of stock all together. What do some of y'all think about having some basic electrical tools and extra components along for the ride, and anybody have any interesting stories about electrical repairs out on the roadways, either with the right part that you happened to have with you, or rigged-up temporary fixes that got you back to the garage? Oh, and for those of you also owning a 60 something Triumph auto, what do you think I can expect to be a weak point in the electrical system I might expect to need attention soon?
NutmegCT
Just my two cents, but over the years I've found modern "replacements" have low quality, most likely due to their not being made in USA or UK. Not always of course, but dodgy replacements have driven me toward seeking NOS or "well preserved" OS.
Unless I'm doing a long trip (coast to coast, for example ...), for electrical I only take a multimeter, ignition wires and a battery replacer with cables, and a few bulbs. Have to admit, seems that when I take a supply of whatever ... that whatever part never needs work.
Tom M.
John Turney
I carry
  • a multimeter,
  • a jumper cable with short pieces on the ends that can be switched out to match whatever the existing connections and a 30-amp inline fuse, with spare fuses.
  • a cap
  • a rotor The only thing I recall replacing on the road was a distributor rotor, and it was for someone else's car.
  • some fuses
  • some bulbs
  • a couple of spark plugs
  • points, condenser, and other distributor parts, even though I have a Crane system
  • jump starter.
AndreL TR6 Conversion to electric fuel pump Triumph 14
Guido36 Electric Power Steering Austin Healey 2
Martinld123 Electric Fuel Pump Austin Healey 6
DrEntropy Benz electric window battle Other Cars 13
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
R Spitfire Electric Fan Triumph 2
Basil Remember the Royal Electric E-Type Electric Upgrades of All Sizes 0
Gliderman8 Electric classic cars Electric Upgrades of All Sizes 22
B Intermittent Loss of Electric Power Austin Healey 18
Taftster MGB Electric Gauges Read High, Any guesses? MG 5
R Electric fuel pump wiring Spridgets 4
Patrick67BJ8 Low-Profile Electric Puller Fans Austin Healey 51
Simmo General Tech Electric Cooling Fans. Are they a problem? Triumph 19
Rob Glasgow New Fangled Electric Overdrive Austin Healey 9
R Rewind electric motor Restoration & Tools 3
JPSmit Electric Midget Spridgets 1
M TR6 Electric Powered Rack & Pinion. Triumph 4
longbridgehealey Electric Fan vs. Texas Cooler Austin Healey 21
D Spitfire Electric fan Triumph 3
B TR4/4A Mechanical fuel pump vs electric Triumph 16
M TR6 Rimmer Bros. Electric Fan Conversion Triumph 0
M TR6 Dowel Pins, Pulley Adaptor, Revotec Electric Fan Kit Triumph 1
K TR2/3/3A An Electric TR3 ?? Triumph 3
Lin Electric Relay Placement Austin Healey 11
nevets interesting article about converting classic cars to electric power Austin Healey 7
FlyingCat Spitfire Electric Radiator Fan Triumph 10
M The electric E Jaguar 1
J TR4/4A Water temperature and electric fan in a TR4 Triumph 5
N Electric fan opinions???? Spridgets 2
P electric clutch Austin Healey 1
M TR2/3/3A Electric Fuel Pump Sound Triumph 7
Geo Hahn General Tech Emergency Electric Fuel Pump Triumph 29
B Electric fan Austin Healey 2
T Wanted WTB early TR 4 electric temperature gauge Triumph Classifieds 5
T General TR Request pictures of TR3B & TR4 electric temperature gauges Triumph 15
rjc157 TR6 Electric fan Triumph 5
J Spitfire Electric brake switch issue Triumph 5
johnrip Wedge tr7 electric fuel pump Triumph 2
exfed12825 General Tech Electric Power Steering With Fail Safe MG 0
Jer is it posible to fit an electric temperature gauge ? Spridgets 4
Got_All_4 General TR Electric fuel pump for in my possibles bag Triumph 12
Michael Oritt Electric tachometer connections--No Healey content Austin Healey 7
M TR2/3/3A Electric Fuel Pump Installation Triumph 12
J TR2/3/3A Radiator removal ?? electric fan vs original Triumph 7
T ?Changing BE to SU electric fuel pump Spridgets 8
S TR4/4A electric fan Triumph 6
Joe Reed MGB Removing stuck blade on factory electric cooling fan??? MG 7
KVH TR4/4A Electric Overdrive Lever Switch Triumph 3
mgedit TR2/3/3A Electric Powered TR3 Triumph 8
O Electric choke problem. Jaguar 0
