TR6 Fuel pump
sundown
Ok, I would like to know the right way to remove the fuel pump? I spent about 2hrs and some cut knuckles trying to remove those 2 nuts. Also I would like to post a photo of the pump how can I do that. Thanks
TR3driver
Great Pumpkin - R.I.P
I've not done it on a TR6; but on TR2-4 you need the magic tool
Look closely, this shows it on one of the nuts
poolboy
I use small stuff....1/4" drive ratchet wrench,6 inch extension and what was it .....1/2 or 7/16" socket ?
Now that you have it off, clean the threads and use fresh nuts. Then you can finger tighten the nuts and just use a tool for the the final turn. Removal will be easier too.
sundown
sundown
Thanks guys, I going to run a die over the threads to clean them up. Get some new nuts and give it a try.
TuffTR250
Is it best to use new regular nuts and lock washers, or new narrow nylok nuts, since not a lot of room on the stud for nut and lock washer? Thanks!
Bob
poolboy
I don't see why that wouldn't work if you can find nyloc jam nuts; but I still use a flat washer, a lock washer and nut.
If you need more room during installation, you can avoid pressing the pump right up against the engine which will expose just enough of the stud to get the hardware started.
Same technique is useful when mounting ZS carbs on the TR6 manifold.
poolboy
Giving that more thought...it's going to get pretty hot, right there close to the engine.
I'm not sure what temperature nylocs can withstand.
dklawson
See the page linked below.
The standard material used in Nylocks is good to 250 oF. There is a higher temperature material available for special order. Since the exhaust is not near the fuel pump, and the engine should not get much hotter than the coolant, standard Nylocks should be OK for the fuel pump mount.
Nylock Spec. Link
R TR2/3/3A Fuel pump? Triumph 8
AndreL TR6 Conversion to electric fuel pump Triumph 14
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
D TR4/4A TR4a Fuel Pump Triumph 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
D MGB Fuel Pump MG 2
Martinld123 Electric Fuel Pump Austin Healey 6
S TR2/3/3A Fuel Pump??? Triumph 14
D Fuel Pump Ticking but Not Pumping Austin Healey 8
A Spitfire Fuel Pump Triumph 5
A Spitfire Spitfire Fuel pump issues Triumph 5
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
S fuel pump upgrade Spridgets 0
S Sprite Fuel Pump Upgrade Austin Healey 1
F TR4/4A New to forum - Rebuilt Fuel Pump and weeping float bowl Triumph 9
P XJ12 Fuel pump relay 85 Jaguar 4
petnatcar Fuel Pump Upgrade Austin Healey 2
R Electronic Conversion on an SU Fuel Pump? Restoration & Tools 2
T TR6 Fuel pump lines Triumph 2
1 TR2/3/3A TR3 Fuel Pump Thread Type? Triumph 4
R Electric fuel pump wiring Spridgets 4
T SU Fuel Pump Mounting Austin Healey 5
D TR2/3/3A More Fuel pump questions. Triumph 10
Donald1107 59 TR3A Fuel Pump Triumph 48
BobHaskell SU Fuel Pump Pressure Austin Healey 1
Cutrog1 Fuel Pump Ticking Austin Healey 13
MGTF1250Dave T-Series MG TF fuel line from tank to pump MG 3
S SU fuel pump servicing Austin Healey 4
71TR6 TR2/3/3A AC Fuel Pump Lever Triumph 10
E MGB 1965 mgb fuel pump removal MG 2
D For Sale Su fuel pump Other British Classifieds 5
D For Sale Su fuel pump Austin Healey Classifieds 5
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
vette A Quiet SU Fuel Pump Austin Healey 2
A TR4/4A AC Fuel Pump stuff Triumph 11
AngliaGT Fuel Pump Problems Spridgets 2
B SU Fuel Pump Parts Austin Healey 8
B TR4/4A Mechanical fuel pump vs electric Triumph 16
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
J TR4/4A Fuel pump saga Triumph 4
longbridgehealey Fuel pump racing, no gas Austin Healey 26
D General TR Fuel filter before the pump. Triumph 2
T 66 Austin Healey fuel pump replaced Austin Healey 30
C Well I Tried with a new SU fuel pump British Motor Corp 0
T TR2/3/3A Questions on fuel pump installation Triumph 7
