Spitfire Spitfire Fuel pump issues
afoster
Hello I am new to owning a British car and I am in the process of rebuilding the engine. The fuel pump however seems to have quit on me. I had bought a 1-5 psi electric fuel pump to put on it. My question is mounting locations for it do I keep it under the hood (bonnet) or put it in the trunk. If I do put it under the hood will it have proper clearance on the firewall from the inner fenders when hood closes. I was possibly thinking of putting it on the firewall right under the clutch master cylinder. Any help would be appreciated.
Thanks
Administrator
Boss
Welcome to the BCF! Since you are asking. specific technical question related to your Spitfire (I assume), I'm moving this thread to our Triumph forum where you are likrly to get more responses. If you are reading this now, you are in the Triumph forum.
Do come back to the New Member forum however and post a brief introduction!
Platinum
If there's a place close to the tank and as low as possible without being exposed to road hazard damage, that's where it would go if it were up to me. Rear so it "pushes" the fuel, low so it has less chance to lose prime if sitting unused for periods of time.
Sarastro
I agree with Dr. E re location.
However, the 1-5 PSI spec is a little wide. 1 PSI might not raise the fuel to the carbs and 5 PSI will almost certainly flood the carbs. You want the pressure at the carbs to be 3-3.5 PSI max. You should check the pressure to see what the pump is putting out, and go from there.
I use a pump that puts out about 6-7 PSI and a Holley regulator to lower it to 2 PSI.
F Spitfire Spitfire 1500 Mechanical Fuel Pump & Spacer Triumph 6
F Spitfire Triumph Spitfire , what fuel to run Her on with no engine history? Triumph 11
TomMull Post-War Other Herald [or Spitfire] fuel pipe Triumph 5
N Spitfire Spitfire fuel issues Triumph 3
S Spitfire 78 Spitfire fuel problems Triumph 5
S Spitfire Spitfire Fuel line filters Triumph 7
B Spitfire Spitfire fuel line Triumph 4
T Spitfire Spitfire fuel pumps Triumph 6
frankenstang57 Spitfire spitfire fuel line plumbing? Triumph 7
W Spitfire fuel economy for 68 spitfire Triumph 6
TheAssociate Spitfire Spitfire Fuel Filter Triumph 21
Jerseygirl Spitfire Spitfire fuel gauge Triumph 13
78Z Spitfire dimensions of the Spitfire fuel tank? Triumph 2
L Spitfire New Acquisition, 1976 Spitfire Triumph 5
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 1
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
A Spitfire Spitfire Diff Pinion Seal? Triumph 2
3798j General TR Spitfire up in the Tree Triumph 2
E Spitfire '69 Spitfire hard top Triumph 2
D For Sale 1966 Spitfire 4 MK 2 for sale, Triumph Classifieds 1
R For Sale Spitfire MKIII projects Triumph Classifieds 0
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
G Spitfire Spitfire 1500 differential whining Triumph 6
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
P Spitfire 1979 Triumph Spitfire starts then runs rough Triumph 2
Lairhead52 Wanted 78 Spitfire instrument panel lights / lenses Triumph Classifieds 3
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
R Spitfire Turn signal wiring Spitfire Triumph 5
S Spitfire Spitfire 1296 engines Triumph 1
D Wanted WTB: Late Triumph Spitfire Top Frame Triumph Classifieds 8
C Spitfire 1967 Triumph Spitfire Triumph 2
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
T For Sale One Owner 1969 Spitfire for sale Triumph Classifieds 0
Dnickels Spitfire Spitfire lighting issues Triumph 4
SteveTheBrewer Spitfire Spitfire Rebuild Update Triumph 5
Basil Spitfire 74 Spitfire Barn Find Triumph 1
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
B Spitfire Mk3 seat rails Triumph Classifieds 0
M Spitfire 1500 LH Door Triumph Classifieds 0
P Spitfire Bits Triumph Classifieds 1
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
FlyingCat Wanted 1980 Spitfire Rear Bumper Triumph Classifieds 2
SteveTheBrewer Spitfire Triumph Spitfire Restoration Blog Triumph 22
