Spitfire Triumph Spitfire , what fuel to run Her on with no engine history?
FASTWAY
Hi , ive recently bought a 1972 Triumph Spitfire , ive been told shes had an engine rebuild and is now kitted up to run on unleaded , however there is no paperwork to back this up , the engine has covered 97K , doesnt look like its been rebuilt but a compression test at a garage 2 years ago showed a perfect 150 across all four cylinders...without stripping her down , is there anyway of telling which is the best fuel for Her?...thanks
DavidApp
Here in the US I try to stick to Ethanol free fuel at for my TR3A which I know does not have hard valve seats. What fuel options do you have in the UK?
David
F
FASTWAY
Hi DavidApp , really just unleaded petrol , which is fine if the cars been converted , if not then a lead substitute added to the unleaded petrol , but when your not sure of the engine its a hard call to make....
LarryK
I drove a 1973 Triumph GT6 for 10+ yrs on unleaded fuel. Was not babied driven. Took head off once for a valve problem, but seats were never recessed or worn. According to the then dealer the seats were already hardened in anticipation of mods for performance.
DavidApp
I was going to have the seats done when I rebuilt my motor but the shop seemed unsure of the process so I decided that as I was unlikely to be doing 1000s of miles I was better off leaving the seats standard rather than the shop learning on my head.
David
LarryK
Very smart decision. If the shop cannot do Triumph, they can't do much. Same process as any iron head.
Madflyer
How many grades of gas do you have? Here on the West coast and in some State's , there can be as many as five. On the East side of Nevada they try to push 85, but car mag. say do not use. In Oregon they have 87 with Ethanol and 89 with out. Union 76 stations just a few sell racing fuel 98. A simple rule the higher the number the slower the burn that adds power and less heat. Just adding fuel additive ever other tank or so won't hurt either. Madflyer Cheers Mate
LarryK
You cannot use the 85 in the Spit. Not made for 15% ethonal. Never use methanol as it deteriorates fuel lines and pumps and carbs. 89 is a safe bet. I always use 93 in my old cars. All the blends have injection cleaners that really are not good in old carbs. Racing fuel is good for racing if you change timing, plugs and retune. But has no additives. Use the least amount of fuel addditives as pump gas has enough additives and the bottles you buy have a percentage of alcohol (water). If you change plugs and have a red tint, you have more than enough additives.
F
FASTWAY
Thanks all of you , i think every other tank i will put some lead substitute in since i dont have enough engine history , do any of you ever use anything like redex every now and then on an old car?
LarryK
Unless you are going to race it, additive not necessary. I also belong to SCCA and we do fuel checks for lead. Not allowed per rules.
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 0
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
P Spitfire 1979 Triumph Spitfire starts then runs rough Triumph 2
D Wanted WTB: Late Triumph Spitfire Top Frame Triumph Classifieds 8
C Spitfire 1967 Triumph Spitfire Triumph 2
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
SteveTheBrewer Spitfire Triumph Spitfire Restoration Blog Triumph 22
S For Sale Triumph Spitfire Workshop Manual on CD/ROM - 1962 - 1978 Triumph Classifieds 0
D For Sale Custom 1972 Triumph Spitfire [Restoration Project] Triumph Classifieds 0
D For Sale For Sale: 1972 Triumph Spitfire [Restoration Project] Triumph Classifieds 0
N For Sale 1971 to 1980 Triumph Spitfire Bonnet Triumph Classifieds 0
N For Sale 1979 Triumph Spitfire Triumph Classifieds 2
C Wanted triumph spitfire mk2-3 drivers seat bucket Triumph Classifieds 0
M Hello again. I have a 1978 Triumph spitfire. Triumph 17
N For Sale Triumph Spitfire hardtop Triumph Classifieds 2
PAUL161 Spitfire 75 Triumph Spitfire on Craigslist Tulsa Triumph 1
N Wanted Triumph Spitfire mirroe plinth Triumph Classifieds 0
5 Spitfire Triumph Spitfire on Craigs list Triumph 0
K GT6 Triumph Spitfire Cylinder heads.... Triumph 2
T Spitfire 1979 Triumph Spitfire 1500 Triumph 3
T Spitfire 1979 Triumph Spitfire 1500 rear wheel alignment Triumph 4
spitfun Wanted:Triumph Spitfire race rear spring Racing 2
S Spitfire Triumph Spitfire 74 transmission bellhousing leak Triumph 6
S Spitfire Question on front Hub for a triumph Spitfire. Triumph 4
N Spitfire Triumph Spitfire Brake Response Triumph 13
L Spitfire 1965 Triumph Spitfire MK2 Triumph 4
A Spitfire TRIUMPH SPITFIRE MKIV 1500 Triumph 2
R Spitfire Triumph Spitfire Frame and Rustproofing Triumph 11
JBann Spitfire Triumph Spitfire mk1 - Height restrictions? Triumph 25
A Spitfire Triumph Spitfire 1500 Triumph 8
C one very, very quick Triumph Spitfire Racing 9
N Spitfire triumph spitfire? rebodied? Triumph 6
roofman Spitfire Triumph Spitfire seat conversion Triumph 23
B Triumph Spitfire Revolutions Racing 0
Michael Oritt Post-War Other Triumph Herald/Spitfire steering rack Triumph 7
M Spitfire '69 vs '70 Triumph Spitfire rag top Triumph 1
B Spitfire Sellng my 1979 Triumph Spitfire 1500 Triumph 1
1 Spitfire Triumph Spitfire SAH Lemans Bonnet Triumph 0
W Spitfire Triumph Spitfire market Triumph 9
Basil Spitfire Triumph Spitfire 1500 Triumph 2
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J For Sale Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 0
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
J TR4/4A Vintage Triumph Register Build Codes Triumph 6
J SOLD!! Triumph TR 2 TR 3 windshield stanchion mounting plates Triumph Classifieds 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 9
C For Sale 1963 Triumph TR3b-TCF Triumph Classifieds 5
tr6nitjulius General TR 1/1/2024 in TRIUMPH Triumph 0
