    BCF is a resource offered at no cost to the Little British Car community. We do not require you to pay to play here. However, if you find BCF a useful resource, appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please support the forum with an "optional" low-cost (less than many car club dues) annual upgrade. There are some benefits to upgrading!
Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation
ian_h
Hi
I am trying to help my son get a spitfire 1500 running after a 10 year hibernation but it refuses to play.
When we first got it we drained all fluids and fuel, replaced fuel lines/pump, rebuilt carbs (removed waxstats for alternate type), all new ignition components (plugs,points,condenser, coil,leads) and gapped the tappets. We also checked compression (155/155/155/125 psi, although number 4 did come upot 140 after oiling the bore so may be just stuck ring. We set static timing to 10 degrees before tdc at the point the plugs open for Cyl 1. For the inital carb. set-up the jets are 2 full turns below bridge level and the slow running screw is 1.5 turns after it begins to move the butterfly
It would fire but only run roughly for a short period at high revs on the choke and immediatley die upon opening the throttle. This was exactly the same as before we did all the work.
I assumed we had an inlet manifold leak since there seemed to be plenty of fuel at the carbs (albeit a large vapour lock in the in line fuel filter) so we replaced the manifold. No change.
Having now rechecked fuel flow (good to carbs but still vapour lock in filter), timing, plug lead order and swapped back to old coil it refuses point blank to play. After cranking on the starter for ~5 secs it will fire to disengage starter but not run on. Even a healthy dose of damp start would not elicit any response. Having re checked compression we seem to be down to 60 on cycl 4 but that may be due more to a low battery and slow cranking speed. The plugs seem wet/oily now upon checking but there seems to be a weak spark when held against the engine.
Any insights/ideas greatly appreciated because I am all out of ideas.
Many thanks
Ian
bobhustead
What is showing you vapor lock in the fuel filter? Could be that the new condenser is bad. I would r&r at the entire ignition again, including check of primary wiring for possible leaks. Do the points open to the same gap on each lobe of the shaft?
Bob
I
ian_h
Hi Bob
The clean plastic fuel filter I added just before the fuel pump is full of air although having taken the hose off the fuel line to the front carb it receives a strong flow of fuel with no air bubbles.
How do I check primary wiring for a leak?
Not sure if points open the same on each lube but I wouls imagine that may be a fine tuning point rather than a show stopper for the car to run?
Many thanks
Ian
bobhustead
There is always air at the highest point in a cartridge fuel filter unless the inlet and outlet are perfectly vertical to each other. Examine the wires closely for continuity, and cracks or other signs of possible intermittent shorts. Replace them all prophylactically, including the one in the dist that powers the points. Small bends in dist shafts can cause non-concentric rotation of the lobes (wobble). The dist shaft is 2 pieces. The top one with the lobes spins a bit on the bottom one, held to it only by the advance springs. Loose fit between the shafts can also cause erratic point opening. The movement of the points plate while advancing moves the little cloth covered wire that goes from the end of the coil wire to the points. This could cause short or discontinuity. PS The little points wire in the dist may have conventional insulation. Don't remember.
Bob
Madflyer
Question? how did it run 10 years ago. Look at a vacuum leak check all Vac lines and tighten all bolts at carb and Man.
Bakerman8888
What is your fuel pressure? I experienced the same thing: car would run but not very well. Checked everything: carbs were full of fuel in the bowls, ignition was good, be coil, ignition, carb tuning… all of it. Mine ended up being a dying fuel pump. After 10 years of sitting, especially if you’re using the mechanical pump, I’d be very suspicious of that.
It also sounds like you’re using SU carbs. Spray some part cleaner around the throttle bushing/shaft area when it is running to see if there are air leaks there.
Only running on choke indicates very lean conditions; it happens 2 ways: not enough fuel or too much air. If you still have all the emissions junk in there I’d be checking for cracked lines too as noted above, but my gut says fuel pump. You can’t test it by eye; if you haven’t put a pressure guage on to verify you’re between 2 and 4 psi, get ye to a Harbor Freight and run this test. Or just replace the fuel pump; odds are it is due anyway.
T Spitfire 1979 Triumph Spitfire 1500 Triumph 3
T Spitfire 1979 Triumph Spitfire 1500 rear wheel alignment Triumph 4
A Spitfire TRIUMPH SPITFIRE MKIV 1500 Triumph 2
A Spitfire Triumph Spitfire 1500 Triumph 8
B Spitfire Sellng my 1979 Triumph Spitfire 1500 Triumph 1
Basil Spitfire Triumph Spitfire 1500 Triumph 2
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 1
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
P Spitfire 1979 Triumph Spitfire starts then runs rough Triumph 2
D Wanted WTB: Late Triumph Spitfire Top Frame Triumph Classifieds 8
C Spitfire 1967 Triumph Spitfire Triumph 2
SteveTheBrewer Spitfire Triumph Spitfire Restoration Blog Triumph 22
F Spitfire Triumph Spitfire , what fuel to run Her on with no engine history? Triumph 11
S For Sale Triumph Spitfire Workshop Manual on CD/ROM - 1962 - 1978 Triumph Classifieds 0
D For Sale Custom 1972 Triumph Spitfire [Restoration Project] Triumph Classifieds 0
D For Sale For Sale: 1972 Triumph Spitfire [Restoration Project] Triumph Classifieds 0
N For Sale 1971 to 1980 Triumph Spitfire Bonnet Triumph Classifieds 0
N For Sale 1979 Triumph Spitfire Triumph Classifieds 2
C Wanted triumph spitfire mk2-3 drivers seat bucket Triumph Classifieds 0
M Hello again. I have a 1978 Triumph spitfire. Triumph 17
N For Sale Triumph Spitfire hardtop Triumph Classifieds 2
PAUL161 Spitfire 75 Triumph Spitfire on Craigslist Tulsa Triumph 1
N Wanted Triumph Spitfire mirroe plinth Triumph Classifieds 0
5 Spitfire Triumph Spitfire on Craigs list Triumph 0
K GT6 Triumph Spitfire Cylinder heads.... Triumph 2
spitfun Wanted:Triumph Spitfire race rear spring Racing 2
S Spitfire Triumph Spitfire 74 transmission bellhousing leak Triumph 6
S Spitfire Question on front Hub for a triumph Spitfire. Triumph 4
N Spitfire Triumph Spitfire Brake Response Triumph 13
L Spitfire 1965 Triumph Spitfire MK2 Triumph 4
R Spitfire Triumph Spitfire Frame and Rustproofing Triumph 11
JBann Spitfire Triumph Spitfire mk1 - Height restrictions? Triumph 25
C one very, very quick Triumph Spitfire Racing 9
N Spitfire triumph spitfire? rebodied? Triumph 6
roofman Spitfire Triumph Spitfire seat conversion Triumph 23
B Triumph Spitfire Revolutions Racing 0
Michael Oritt Post-War Other Triumph Herald/Spitfire steering rack Triumph 7
M Spitfire '69 vs '70 Triumph Spitfire rag top Triumph 1
1 Spitfire Triumph Spitfire SAH Lemans Bonnet Triumph 0
W Spitfire Triumph Spitfire market Triumph 9
T TR4/4A Triumph TR4A 1965 price Triumph 8
M For Sale 1971 Triumph Tr6 Triumph Classifieds 0
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
Charlypm For Sale 69 Triumph TR6 Racecar Triumph Classifieds 1
J TR4/4A Vintage Triumph Register Build Codes Triumph 6
J SOLD!! Triumph TR 2 TR 3 windshield stanchion mounting plates Triumph Classifieds 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 9
