Spitfire 1975 Spitfire 1500 shifting problems when hot
wmeans8776
Ive spent the past 2 years working on a 1975 Spitfire I saved from the scrap yard. I actually saved a 1974 at the same time, but It’s still waiting it’s turn…
Anyway, I went through the overdrive tranny and it actually wasn’t too bad. Cutting a long story short, the tranny is back in, I’ve put about 25 miles on the car and it has been shifting perfectly through all gears around the neighborhood…
but wait, there’s more…
I decided to go a little further to the local fuel station (about 5 miles) and everything was fine on the way there. However, after getting fuel and jumping back on the road, it wouldn’t shift into second and was very hard into first and third . I just wanted to get it home, so just milked it. after getting into the garage and letting the car cool, it shifts fine again…
I did install a new exhaust which runs straight down the middle of the car and is tucked up in so it’s as high as possible and doesn’t hang down. I wonder if that exhaust is getting the tranny too hot and causing the shifting problems.
Thoughts? Seen anything like this before?
Trevor Triumph
When you say hard... Is there gnashing of teeth? What about hot but engine not running? When was the clutch hydraulic fluid changed and bled?
T.T.
W
wmeans8776
All new hydraulics (slave, master and line). Engine is running at normal temps. After a little more playing , it definitely only happens after everything gets good and hot. I pulled the trsnny cover and the trsnny itself is getting pretty hot.
I got some exhaust wrap and am going to pull it and wrap it to see what happens.
charlie74
What kind of fluid did you use in the transmission? I had difficulty shifting my TR6 OD transmission after trying 30 weight non-detergent oil in it. After I switched back to gear oil (yellow metal friendly GL-4) the transmission was back to normal…
W
wmeans8776
First thing I'd check is the oil level in the gearbox. Also, I'm curious: Did you get to try the overdrive? If so, did it engage and disengage ok?
Good questions. Rebuilt tranny and I’m using 70/80 gear oil filled to the brim (but not overfiull.
the solenoid doesn’t pull overdrive in. It does click mildly, so I think it’s bad…
bobhustead
If your engine is running on the edge of too hot, stopping the exhaust radiating heat by wrapping it could put the operating temp above where you want it. A barrier that leaves the exhaust exposed but blocks it from the hydraulics could be preferable.
Bob
Bakerman8888
I’d start with the clutch fluid myself. It sounds like it has absorbed water over time and is boiling off at operating temps, hampering the cylinder motion to engage the fork. Exhaust wrap might help, but ultimately if your clutch fluid is compromised you’re gonna want to address the root before other stuff breaks (like your master or slave piston).
I recently did an overdrive swap-in and used MTL due to the instructions of the gearbox rebuilder calling for a 30W non-detergent type lube. It was quite simply too light for good shifts and overdrive engagement. After about 30-40 miles OD would get ultra sketchy. Switched to MT-90 and it shifts cleaner and OD works like a dream. Oil weight matters, especially in the OD gearbox.
Clean your OD filters if you haven’t. The cover is located in a ridiculous place; 6 bolts drop the OD filter cover which sits directly above the exhaust pipe… you need to at least loosen up part of the exhaust for access.
If your solenoid clicks, that component is probably fine. My first look on the OD issue would be the filters under that cover. This involves draining fluid and dropping part of the exhaust for access again, but is otherwise pretty straight forward. There is a filter behind the cover and another inside a plug behind the cover (no special tool needed to open the plug, just use a needle nose to grip the holes). Check out a part diagram to make sure you’re pulling the plug for the filter, not the pressure relief valve.
It’s also possible there are other things causing OD to be sad, but this is a simple thing to try before giving up on it. Clean the filters in a container of gas, blow them dry, then give it a try. You might be lucky. Mine was getting extra crabby, so when I switched weight I also took the time to check the filters in the OD. Even on a fresh rebuild with about 2k miles there was a lot of crap in them.
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
P For Sale 1975 Spitfire for sale Triumph Classifieds 0
R For Sale 1975 Spitfire engine Triumph Classifieds 1
roofman Spitfire 1975 Spitfire overdrive question Triumph 6
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
D MGB 1975 MGB 20 Years Resurrection MG 1
J TR6 1975 TR6 Alternator Advance/Retard spring(s) Triumph 1
Sherlock 1982 Ford F150 stepside vs 1975 Triumph TR7 Other Cars 4
humanoid For Sale - Haynes Trimumph TR7 (1975-1981) Automotive Repair Manual Triumph Classifieds 0
humanoid For Sale - Haynes Triumph TR7 (1975-1979) Owners Workshop Manual Triumph Classifieds 0
F TR6 1975 TR6 runs lean Triumph 11
M TR6 Early vs newer pdwa for Tr6 1975. Triumph 3
D For Sale 1975 Tr6 for Sale Triumph Classifieds 0
D Spitfire 1975 Spit resurrection Triumph 4
David Townsend MGB 1975-80 MGB Roadster Fine Art Prints MG 0
O MGB 1975 MGB No Fuel to the filter MG 2
M TR6 1975 TR6 Backfire from Carbs, running Lean - Help! Triumph 9
DrEntropy Dated as 1975 Racing 2
RJS TR4/4A 1975 Triumph British Racing Green Paint Code Triumph 4
D 1975 bricklin in tonawanda, ny Spotted 5
Tinkerman 1975 MOSS price sheet Triumph 9
AngliaGT OT - 1975 Suzuki T500 Titan British Motorbikes 1
M TR6 1975 TR6 wheel alternates Triumph 1
S TR6 1975 TR6 won't start Triumph 3
S MGB-GT need help on an mgb gt 1975 MG 3
T Wedge 1975 TR7 DHC in SoCal Triumph 3
T Wedge Cheap 1975 TR7 coupe Triumph 1
D MGB 1975 MGB Won't Crank MG 7
B MG Expansion Tank Thermostat Housing 1975 Spridgets 3
shemp4 water pump on 1975 midget Spridgets 3
bmurphy7369 The basic Lucas/OPUS 1975 xj6 era principles??? Jaguar 9
6773 fuel tank 1975 midget Spridgets 3
Steve 1975 Midget on Craigslist Spridgets 0
bmurphy7369 Wiring help needed badly... 1975 XJ6 Crane setup.. Jaguar 8
bmurphy7369 XJ6 SII 1975 with Crane Ignition dies when warm Jaguar 10
bmurphy7369 1975 XJ6C Stromberg water choke, now engine tuning Jaguar 1
B Any Body Have 1975 wiper arms? Spridgets 1
RocknTommy Will the 1500 & Trans work in a pre 1975 Midget? Spridgets 11
M MGB 1975 MGB MG 4
S MGB-GT 1975 Engine in '71 mgb gt MG 2
Monark192 MGB 1974.5 MGB vs. 1975 model. Which to keep? MG 19
F TR6 Carburetors 1975 TR6 Triumph 33
S TR6 1975 TR6 no horn Triumph 5
S MGB 1975 MGB Overdrive rear seal MG 2
S 1975 with an interesting leak MG 10
A TR6 1975 TR6 Ventilated Rotors Triumph 12
1 MGB 1975 MGB MG 15
Thor Can the 1976 plus radiator fit 1975 midget & Spridgets 7
A TR6 Speed Bleeders for 1975 TR6 Triumph 2
W TR6 How to change oil filter on a 1975 TR6 Triumph 13
