Will the 1500 & Trans work in a pre 1975 Midget?
RocknTommy
Newby here.
Looking at pre 1975 shells and wondered if my 1975
1500 engine and transmission will swap over without too many issues. What are the differences in the bodies besides the addition of the rubber bumper? Thanks!
Different front crossmember... and a whole bunch of other stuff that makes it very aggravating to swap.
Morris
Most people go the other way... 1275 in a rubber bumper. You won't get any love for the 1500 from this crowd.
Sopwith_Camel
nope you might as well drop a Masda wangkle in at that point!
get a 1275 and 5 speed Gear box!
cheery
steve
aeronca65t
Re: Will the 1500 & Trans work in a pre 1975 Midget?
It's a fairly simple swap if you are willing to do a little fabrication/drilling in the crossmember area. Use the 1500 front mounts. The clutch hydraulic hose should fit.
I'll have a spare 1500 engine & trans (after I pull it from #11) and a '73 rolling chassis, so I will probably put the two together this summer.
Driveshaft and exhaust are different. You'll have to decide if you want to use the 1500 alternator or an older generator.
RocknTommy
RocknTommy
Thanks for the replies and info.
The shell I have needs tons of repair and the rust free or at least less rusty tubs are hard to find here in PA. And when I can locate a 1500 shell, I either get zero replies after asking questions or they are 3000 miles away without photos.
Mine is repairable but was looking to swap rather than spend
many hours and dollars on metal work. There is a 71 rust free tub in the classified so that why I asked.
What about a 1500 spitfire? Your engine would fit right in there.
Morris
What does the 71 tub need? It may be worthwhile to sell the 1500 and start over with the 71. Don't get me wrong, I love my 1500, but it is rust free. Knowing what I know now, I would not spend the kind of time required to repair a bunch of rust on a 1500 if an earlier car was available.
Okay, truth be known, I would not be spend the time to repair a bunch of rust in any car. That's not my kinda work.
RocknTommy
RocknTommy
Am I correct in seeing that the suspension parts are all pretty much the same between the 1275 & the 1500?
I have a ton of new and good swapable parts I have collected over the years. Thanks for all the help.
Morris
Suspension, brakes, and I believe rear-end all interchange quite easily. The 1500 has beefier springs to raise the height and account for the added weight of the battering rams and heavier engine/transmission.
aeronca65t
Yep. Suspension is all pretty much the same. My '78 chassis has a '66 rear and part of the front suspension is from a '67.
The steering rack on 1500 cars is different (slower ratio) but the two types will swap. Radiator is differnt too, but again, you can fit the old rad to a newer car or visa versa.
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
DanLewis Two midgets available: '79 is free [no engine, trans], running '77 $1500 [NFI] Spridgets 1
B 1500 Rattling Trans Cable Strap? Spridgets 5
aeronca65t 1500 Midget engine/trans/etc Spridgets 0
B A Quiet 1500 Trans !?!?! Spridgets 8
B New Memeber 1500 trans in question Spridgets 4
R 1500 Trans VB overhaul kit Spridgets 5
R 78 1500 Midget Trans Question Spridgets 2
C Wanted Spitfire 1500 diff rebuild Triumph Classifieds 0
C LCB header with 1500 single carb inlet manifold Spridgets 1
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
G Spitfire Spitfire 1500 differential whining Triumph 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T MG Midget 1500 crank shaft pulley Spridgets 0
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
G T-Series 1955 mgtf 1500 lites MG 5
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
G 79 Midget 1500 overheating Spridgets 2
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
M Spitfire 1500 LH Door Triumph Classifieds 0
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
R Spitfire Spitfire 1500 Triumph 3
B MGA Solution! 1600 harness in a 1500 MG 1
S For Sale Mg t-series crankshaft tb tc td tf 1250 1500 MG Classifieds 0
R Spitfire 1500 gearbox question Triumph 1
R 1500 gearbox question Spridgets 0
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
A 76 Midget 1500 Oil filter Spridgets 6
M Wanted Twin carb manifold for 1500 Midget or spitfire Spridgets Classified 3
M Rocker feed kit for 1500 from Victoria British Spridgets 0
sparkydave 1500 battery cable colors Spridgets 1
GS67 1500 Operating Temperature Spridgets 2
doc50 Nash Metro w/MGA 1500 discrepancy... Other British Cars 2
doc50 Metro 1500 Has Slack Timing Chain? Other British Cars 20
B 1500 head studs Spridgets 3
DrEntropy For Sale MGA intake manifold [1500] MG Classifieds 0
busybrit For Sale 1960 MGA 1500 Restoration Project for sale. MG Classifieds 2
sparkydave 1500 clutch master Spridgets 4
Steve P. 1500 radiator in an earlier 1275 cross flow Midget? Spridgets 2
P Pristine MG TF 1500 Spotted 0
aseriesspares Spitfire What Gearbox are you using. Spitfire / Midget 1500 Triumph 2
aseriesspares What Gearbox are you using. Midget 1500 Spridgets 5
T Putting a Spitfire 1500 into a 1972 Midget Spridgets 6
