1500 radiator in an earlier 1275 cross flow Midget?
Steve P.
Still cobbling together this Midget (1973) from parts. The original cross flow radiator is
in rough shape. I have a radiator in much better condition from a 1500 and while
there are some differences it looks like it will bolt in. The 1500 radiator is larger and
should provide better cooling.
Has anyone done this, and if so what were the challenges? TIA
Steve
Billm
I have never tried it but if you want a radiator that came out of a '71 (in San Diego) you can have it (needs a small repair)
BillM
nomad
Steve
Steve, I'm running one in my 1500 Datsun engined midget. I have the fresh air inlet on the side that the early MG 1500 radiator sticks into so I flipped it over. Had the local rad shop cover the one large outlet and put in a small tube to go to a BMC overflow can. I have been filling it through the top hose. I also cut some large holes in the front shroud with a hole saw to let air flow through the side extension of the 1500 Midget radiator. Keeps my Datsun engine cool at 80+MPH and 100 degrees outside. If you have the early steering rack as I do you will have to modify the housing to raise it a bit to clear the fatter early rack.
Kurt.
DanLewis 1500 cc MG Midget Radiator in a Bugeye??? Spridgets 5
R difference between instal of 1500 radiator in 1275 Spridgets 3
middie Converting from US to UK radiator in a late 1500 Spridgets 10
bigjones Recommendations for radiator hoses - 1500 Spridgets 8
tosoutherncars Midget 1500 radiator question Spridgets 11
C Wanted Spitfire 1500 diff rebuild Triumph Classifieds 0
C LCB header with 1500 single carb inlet manifold Spridgets 1
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
G Spitfire Spitfire 1500 differential whining Triumph 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T MG Midget 1500 crank shaft pulley Spridgets 0
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
G T-Series 1955 mgtf 1500 lites MG 5
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
G 79 Midget 1500 overheating Spridgets 2
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
M Spitfire 1500 LH Door Triumph Classifieds 0
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
R Spitfire Spitfire 1500 Triumph 3
B MGA Solution! 1600 harness in a 1500 MG 1
S For Sale Mg t-series crankshaft tb tc td tf 1250 1500 MG Classifieds 0
R Spitfire 1500 gearbox question Triumph 1
R 1500 gearbox question Spridgets 0
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
A 76 Midget 1500 Oil filter Spridgets 6
M Wanted Twin carb manifold for 1500 Midget or spitfire Spridgets Classified 3
M Rocker feed kit for 1500 from Victoria British Spridgets 0
sparkydave 1500 battery cable colors Spridgets 1
GS67 1500 Operating Temperature Spridgets 2
doc50 Nash Metro w/MGA 1500 discrepancy... Other British Cars 2
doc50 Metro 1500 Has Slack Timing Chain? Other British Cars 20
B 1500 head studs Spridgets 3
DrEntropy For Sale MGA intake manifold [1500] MG Classifieds 0
busybrit For Sale 1960 MGA 1500 Restoration Project for sale. MG Classifieds 2
sparkydave 1500 clutch master Spridgets 4
P Pristine MG TF 1500 Spotted 0
aseriesspares Spitfire What Gearbox are you using. Spitfire / Midget 1500 Triumph 2
aseriesspares What Gearbox are you using. Midget 1500 Spridgets 5
T Putting a Spitfire 1500 into a 1972 Midget Spridgets 6
AN5Sprite T-Series 1955 TF 1500 For Sale This Spring MG 3
JPSmit 1500 slave cylinder question Spridgets 0
bigjones Vacuum advance on a 1500 Spridgets 13
