Spitfire What Gearbox are you using. Spitfire / Midget 1500
aseriesspares
Hi Guys,
I am building myself a track Midget 1500 but appear to have hit a bit of a wall when it comes to the gearbox.
Engine wise, for anything performance i have had to ring companies in the US as the UK do not seem that keen on the Triumph engine. We build a lot of performance A-Series engines at work but fancied a change, and cannot wait to get the Midget out.
My question, have any of you built a performance 1500, if so, what gearboxes, or gear sets did you use?
If it was a road build i would go the Ford 5-Speed route as we have with the A-Series, but with this being a track car i am keen to keep it a 4 speed.
Just curious to see what is available and if you have any experiences yourselves?
Many thanks,
Rob
number6
I would suggest quantum mechanics.com. They specialize in transmissions and rear ends. They should be able to help you.
Tom S.
aseriesspares What Gearbox are you using. Midget 1500 Spridgets 5
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
F Sprite Gearbox Spridgets 5
E Gearbox problem Other Cars 0
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
K TR2/3/3A Further to changing motor and gearbox mounts. Triumph 1
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
BN6_2197 Gearbox/Overdrive Removal Austin Healey 25
AHS Side-Shift Gearbox Austin Healey 3
D Gearbox Dipstick (BT7) Austin Healey 3
K TR2/3/3A A gearbox additive? Triumph 3
C Gearbox oil British Motor Corp 3
JFS Wedge Stripped gearbox filler hole thread Triumph 3
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
R 100 Motor and Gearbox Available Austin Healey 2
K TR2/3/3A Clutch Slave Cylinder location when TR3 has a TR6 Gearbox? Triumph 16
W BN1 Gearbox First Motion Shaft Austin Healey 0
K TR2/3/3A TR6 Gearbox in a TR3.....Use a TR6 clutch disc and pressure plate or Triumph 7
KellyRob BMC GEARBOX 1960 British Motor Corp 2
Hamish Racing TR2/3/3A Gearbox - can you spot the problem ? Triumph 17
C TR2/3/3A TR3 Gearbox Problem Triumph 10
D MGA with T9 gearbox on a tow dolly MG 9
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
S Add ZDDP to gearbox oil? Austin Healey 29
R TR6 Gearbox slips out of 3rd gear Triumph 14
K For Sale Triumph TR4 & 4A Gearbox anti vibration attachment Triumph Classifieds 0
K TR4/4A The 4A gearbox anti rattle contraption? Triumph 5
Lin Gearbox Oil Austin Healey 4
R TR6 Proper alignment of gearbox front cover plate Triumph 3
BN6_2197 How regular should I change the gearbox oil? Austin Healey 5
R TR6 Gearbox rebuild issues Triumph 8
S Steering Peg in Steering Gearbox Austin Healey 13
K Gearbox Throw-out pin and gasket question Austin Healey 8
BN6_2197 Replacing gearbox switch of the overdrive system Austin Healey 10
R Spitfire 1500 gearbox question Triumph 1
R 1500 gearbox question Spridgets 0
AH67 59 xk150 gearbox Jaguar 6
G Wanted Non Overdrive gearbox wanted Austin Healey Classifieds 0
Bayless Started adapting the datsun gearbox today Spridgets 46
G Wanted ISO Gearbox for 69 Sprite, 1275 engine Spridgets Classified 2
Editor_Reid General MG Gearbox Identification MG 2
Editor_Reid Gearbox Identification Austin Healey 12
W XKs Motorsport gearbox rebuild fiasco Jaguar 5
V TR2/3/3A I have a doubt about the gearbox Triumph 10
C Side-Change Gearbox Stuck in Top Gear Austin Healey 43
R Gearbox and Overdrive Oil Level Austin Healey 18
W Find gearbox rebuild [2nd synch shot] South. California Jaguar 1
