Gearbox Identification
Editor_Reid
Platinum
Could someone please positively identify this gearbox?
It came out of long-term storage in a garage where there were several cars stored long-term: a BN2 Healey, a 1960 Lotus Elite, and 240Z race car, a Model T, a 1949 Chrysler, and a very low-production Lotus race car (1 of 17, or something like that).
Thanks.
Michael Oritt
Yes, it looks exactly like the MGA 3-synch box that was in both of my Elva's, the Courier and the sports racer.
John--what did you put in the google search box--the numbers shown in the photo?
Editor_Reid
Editor_Reid
Platinum
Really? With that same shape to the bell housing with those large cut-outs?
Yeah. I tried searching "22H34" and got no where. Likewise searching "22H34 gearbox" was also no joy.
There are none that look like it at the link, but maybe I'll try the MG Forum anyway.
red57
It does look a lot like the MGA boxes shown in the link John found but the one difference I see is the vertical throw-out arm. The MGA Twin cam box shows a raised boss about where a slave cylinder could mount but I don't see a hole with a raised ridge around it for the arm to come out? The large cut outs in the bellhousing may be modifications 'cause I don't see where the starter would bolt up.
Michael Oritt
Ah yes.
Nice catch.
I seem to recall buying a transmission out of a Metropolitan--it had a boss for the slave cylinder on top. I was using an annular clutch with its own cylinder so it was no matter.
Editor_Reid
Editor_Reid
Platinum
MOWOG 1H3150 from the first photo.
Good eye! I was focused on the more easily readable numbers. That said, it also says 1H3150 in the 7th photo, and it also has 4 B 60 making me wonder if it was made in April 1960. Either way, I've written to the MGA Guru for his assessment.
And strange about those bell housing cut-outs. They don't look "home made."
Editor_Reid
Editor_Reid
Platinum
I checked with Barney the MGA Guru and he says, "MG ZA or ZB Magnette. 10-spline input shaft, top mounted slave cylinder, straight up shifter."
Thanks John for mentioning him which gave me the idea to contact him directly. Now I just need to find a buyer ... but how many MG ZA or ZB Magnettes can there be ... and how many need a gearbox ... and are willing to buy one in unknown condition?
Seems like I might own it for a long time.
Michael Oritt
Reid--
If you look at the photo ending in 61 you will see at the bottom what I think is the inward side of a second boss to accept a secondary cylinder, and the more I think about it the more I seem to recall that the transmission I purchased from a Nash Metro guy had two bosses--one on top as does yours and one low and on the right side as is often found. As to the two big cutouts I can only think that either this transmission was mounted in a car with longitudinal rails that required narrowing of the bell housing or perhaps there were simply fractures in the casting and someone with a diegrinder /sawzall decided to perform radical surgery to head off the cracks.
At some point you should pull off the side plate and see if perhaps there is a CR and/or square-cut gear set installed. That, in and of itself, would be valuable.
Editor_Reid
Editor_Reid
Platinum
Now another guy says it's correct for a TVR Grantura. There's the answer to a great trivia question in this episode: What do the MG ZA and the TVR Grantura have in common?
steveg
TVR wouldn't have had a major component, such as a transmission, that was unique to a TVR! According the the TVR Grantura Wikipedia page, total production for all three models was 800, using a variety of engines and transmissions.
Editor_Reid General MG Gearbox Identification MG 2
T Unusual gearbox identification Spridgets 1
Michael Oritt MGB MGB gearbox identification points MG 1
TR6BobNF Gearbox Identification - Help Triumph 5
M_Pied_Lourd Gearbox Identification Triumph 17
R gearbox identification help & required gearbox oil Spridgets 4
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
F Sprite Gearbox Spridgets 5
E Gearbox problem Other Cars 0
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
K TR2/3/3A Further to changing motor and gearbox mounts. Triumph 1
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
BN6_2197 Gearbox/Overdrive Removal Austin Healey 25
AHS Side-Shift Gearbox Austin Healey 3
D Gearbox Dipstick (BT7) Austin Healey 3
K TR2/3/3A A gearbox additive? Triumph 3
C Gearbox oil British Motor Corp 3
JFS Wedge Stripped gearbox filler hole thread Triumph 3
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
R 100 Motor and Gearbox Available Austin Healey 2
K TR2/3/3A Clutch Slave Cylinder location when TR3 has a TR6 Gearbox? Triumph 16
W BN1 Gearbox First Motion Shaft Austin Healey 0
K TR2/3/3A TR6 Gearbox in a TR3.....Use a TR6 clutch disc and pressure plate or Triumph 7
KellyRob BMC GEARBOX 1960 British Motor Corp 2
Hamish Racing TR2/3/3A Gearbox - can you spot the problem ? Triumph 17
C TR2/3/3A TR3 Gearbox Problem Triumph 10
D MGA with T9 gearbox on a tow dolly MG 9
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
S Add ZDDP to gearbox oil? Austin Healey 29
R TR6 Gearbox slips out of 3rd gear Triumph 14
K For Sale Triumph TR4 & 4A Gearbox anti vibration attachment Triumph Classifieds 0
K TR4/4A The 4A gearbox anti rattle contraption? Triumph 5
Lin Gearbox Oil Austin Healey 4
R TR6 Proper alignment of gearbox front cover plate Triumph 3
BN6_2197 How regular should I change the gearbox oil? Austin Healey 5
R TR6 Gearbox rebuild issues Triumph 8
S Steering Peg in Steering Gearbox Austin Healey 13
K Gearbox Throw-out pin and gasket question Austin Healey 8
BN6_2197 Replacing gearbox switch of the overdrive system Austin Healey 10
R Spitfire 1500 gearbox question Triumph 1
R 1500 gearbox question Spridgets 0
AH67 59 xk150 gearbox Jaguar 6
G Wanted Non Overdrive gearbox wanted Austin Healey Classifieds 0
Bayless Started adapting the datsun gearbox today Spridgets 46
G Wanted ISO Gearbox for 69 Sprite, 1275 engine Spridgets Classified 2
W XKs Motorsport gearbox rebuild fiasco Jaguar 5
V TR2/3/3A I have a doubt about the gearbox Triumph 10
