TR2/3/3A TR3 Gearbox Problem
Coombie
I am currently busy with the restoration of a TR3, using components from various different sources. After installation of the gearbox, there was a problem with second gear jumping out under the slightest load. I removed the gearbox, and stripped it down, and ascertained that there was excessive end float between gears. This I addressed by installing a thick shim, to bring the end float to that specified. On re-installation of the gear box, it is now virtually impossible to engage first gear unless extreme force is applied to the gear lever.
Has anyone any suggestions as to what may be the problem, and as to how it may be resolved?
Geoff Coombe
Fish Hoek
Western Cape
Republic Of South Africa
CJD
The popping out of gear is normally caused by a weak or missing ball detent in the top cover. The synchronized gears are pretty insensitive to end play in general. American cars actually have cups machined into the sliding hubs, which are used to hold the tranny in gear. Popping out of gear in an american car is normally a sign of worn sliding hubs or a shifter not fully reaching in gear. The British box hubs have no such cups in the synchronizer hubs, and they depend on the ball detents to hold the box in gear. The end play would have to be off 1/4" or so to cause popping out of gear not related to the detents.
I am not sure where you could fit a shim, but I suspect that caused the first gear issue. I can't know for sure unless you can relate it to the parts diagram in the manual.
sp53
I am not a great tranny rebuilder, and the last one I rebuilt popped out of second going down hills about a year after the rebuild plus I could feel the whole tranny getting sloppy; it is a little noise. I contribute the popping out of second on the springs and balls on that slider dealie. I pick through the ones I had and used the best. I probably should have used new aftermarket, but that is a big different story. Anyways, when I pull it out, I will purchase new springs and balls. Mine goes into first and reverse fine, but sometimes I need to go into second then straight into first.
Sounds like you should take out what you put in for distance float piece and check the shifting tower ball and springs and slid deal spring and balls. Me, I would replace the slider springs inside the trans on the slider deal and omit the float washer and see what happens. if you have an extra shifting tower try that. These are old units that have been driven hard and hung up wet. Some say the type of oil you put in makes a difference also.
C
Coombie
Thanks for the prompt response I'll give it a try.
Regards, Geoff.
C
Coombie
Appreciate your speedy reply. Will crack on - I know I've been putting off the inevitable, the box will have to come out!
mr.tr3
Hello
If you took apart the first gear you may have put it together incorrectly. It has a ball and plunger in the assembly that can only work right if it correctly installed. When you look at it there are three ball and springs and there is a space that lines up in the assembly that has to be inline with the ball and plunger or it will not shift or is very hard to make it shift.
regards Barry
mctriumph
The best approach is to convert to 5 speeds with the Supra /Eaglegate conversion (that I now own)
the best place for a tr3 tranny is under the bench waiting for the day when a Tr3 is a million $ car.
K TR2/3/3A Clutch Slave Cylinder location when TR3 has a TR6 Gearbox? Triumph 16
K TR2/3/3A TR6 Gearbox in a TR3.....Use a TR6 clutch disc and pressure plate or Triumph 7
L TR2/3/3A TR2000/2500 gearbox on a TR3 ? Triumph 2
S TR2/3/3A TR3 Gearbox Dipstick Question on oil level Triumph 18
RandyInUtah TR2/3/3A TR3 gearbox fluid levelsI Triumph 4
Got_All_4 TR6 Looking for a reverse gear for my tr6 gearbox for my tr3 Triumph 7
CJD TR2/3/3A TR4 Gearbox in the TR3...Finally! Triumph 3
CJD TR4/4A TR3/4 Gearbox Input Shaft Triumph 8
T TR2/3/3A TR3 Gearbox Top Cover OD Switch Locations Triumph 6
W TR2/3/3A TR3 Gearbox overhaul Triumph 3
K TR2/3/3A TR6 gearbox on TR3: re clutch slave adjustment. Triumph 13
Brinkerhoff TR6 TR6 OD gearbox installed in TR3 ? Triumph 11
Moseso TR2/3/3A What could be binding? TR3 Gearbox/OD Triumph 5
RedTR3 TR2/3/3A TR3 Replacement Gearbox Triumph 20
ekamm TR2/3/3A tr3 steeering gearbox Triumph 14
RedTR3 TR2/3/3A TR3 Gearbox Big Leak Triumph 2
T TR6 TR6 gearbox into a TR3 - what should I know? Triumph 9
RedTR3 TR2/3/3A Source of TR3 Gearbox Leak? Triumph 6
R TR2/3/3A TR3 Timminge Triumph 11
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
J For Sale TR2 TR3 Tie Member Triumph Classifieds 0
S TR2/3/3A tr3 valve spring compressor Triumph 5
