TR2/3/3A Clutch Slave Cylinder location when TR3 has a TR6 Gearbox?
RonC
Are you in the process of doing the swap of a TR6 J type overdrive gearbox into a TR3? I am sorting out the rear mount and now looking into the difference in length of the sleeve on the input shaft cover This is associated with depth of spring clutch and diaphragm clutch. I was hoping to discuss with another TR3 owner that has gone through the swap.
Ron
K
karls59tr
Bronze
I'd like to advise you but it was over 20 years ago that I installed the TR6 gearbox so I don't remember which sleve I used? I will be removing the gearbox to install a new clutch but will not be doing that until Spring as i don't have a warm place to work on the car. Hopefully someone else on the forum can advise you. Do you know about fabricating two guide bolts to assist in installing the gearbox?
CJD
The longer snout is for the TR3 finger clutch, and the shorter is for the later TR4+ diaphragm clutch.
Mount the slave cylinder to the same side of the case that it came off. It depends on the slave set-up you will be using, not the transmission type.
RonC
Yes I will use some guide bolts and I understand there is a counter clockwise rotation first to get clutch lever past floor pan. Right now it's getting the clutch and mount sorted out.
I'm considering a custom plate picking up factory mounts on frame, running down small exposed edge on frame beside rolled floor pan then sitting on top of front of cruciform box. Design needs to be contoured to allow speedo cable to curl under, horizontal tail end of solenoid to have clearance and place for exhaust bracket to attach since I'm using frame hole for speedo. Also, can I slip in place or need it in pieces that can be assembled under transmission and still be a strong support. I have looked at the Buckeye site showing a simple mount of 3 pieces.
Further mount design concerns is anti vibration method that meets size and height restrictions.
K
karls59tr
Bronze
Thanks poolboy that's the pic I was looking for. Are you certain that's a TR6 box.... I thought the flange was bigger on the TR6 unless the flange is only wider near the top? Is that a stock clutch slave "rod"?
Graham H
Here is my setup, with the three clutch you must have free-play so the throw out bearing has no contact with the clutch fingers when you are driving. The six has a different setup and I am not sure how it works but as you can see it doesn't have a return spring on the clutch leaver.
Graham
K
karls59tr
Bronze
GrahamView attachment 73976
Graham It looks to me like the anchor plate that holds the return spring has been extended slightly?Did you modify it? I think Randall mentioned this once in a postt hat it needs to be done. Your pic must be the "TR3 clutch cylinder' setup for a TR6 box in a 3 whereas Poolboy and Hamish appear to be using the "TR6 clutch cylinder" setup. I have been using the setup that you show in your picture for years but did not extend or slightly alter that anchor pin. I sometimes became aware of a kind of dragging noise from the clutch area (when I could hear it above the exhaust noise). I believe now from what you have said that the throw out bearing was contacting the clutch fingers when driving! After many years the clutch in my 3 is finally staring to fail. I'm going to replace the clutch in the Spring when the weather is better. I'm going to go with the setup that you use. Once the box is out I'm probably going to see wear at the throw out bearing and clutch fingers. Wonder if the actual clutch disc will have extensive wear??? Thanks for everyone's input (y)
Graham H
That spring anchor plate is the one that was on the car when I got it and no I did not modify it and it works fine.
Graham
RonC
I'm at the stage of sorting out my Girling clutch slave cylinder mounting for the J Type OD install in my TR3A. I have retained the 3 finger TR3 clutch. With the TR6 bell housing casting being thicker this pushes the mounting plate closer to lever arm. What I found was my slave cylinder was previously bolted to the transmission side face of the mounting plate which seems right for pressure when activated has ears of casting against plate. With Graham's above, which seems stock for the TR3A, it has the slave casting on the engine side of mounting plate. This helps me to increase setback from clutch lever and not as much shortening of push rod. I was planning to thread more of rod to get proper adjustment. Also return spring may need shortening?
I'm hoping for input on the install, especially the mounting plate.
Ron
Graham H
The clutch slave mounting plate is bolted to the rear of the bell housing so the relation to the clutch lever is the same regardless of the thickness of the casting also the extra thick casting is probably not much more than a sixteenth of an inch. I think the TR2 had the slave mounted at the rear of the mounting plate and it was a shorter unit why they changed it I don't know but you need to make sure your slave is the 3A unit and it should all work well.
Graham
K New Clutch Master/Slave Cylinder Austin Healey 1
K TR2/3/3A Clutch "Long Throw" Slave Cylinder? Triumph 4
WHT Remote Clutch Slave Cylinder Bleed Extension Austin Healey 11
BobHaskell For Sale Clutch Slave Cylinder Bleeder Extension Austin Healey Classifieds 13
R clutch slave cylinder Triumph 11
R Bug-eye clutch slave cylinder and brake cylinder kit interchange Spridgets 1
B MG midget Clutch slave cylinder Spridgets 5
WillR MGB new clutch slave cylinder MG 3
GTP1960 TR2/3/3A Clutch slave cylinder / push rod alignment Triumph 10
trotti Access to the clutch slave cylinder bleed screw Austin Healey 41
F BT7 3000 - Push rod problem on clutch slave cylinder Austin Healey 7
TomChar TR6 '74 Clutch Slave Cylinder location Triumph 8
G MGB Clutch Slave Cylinder MG 34
6 Recommended clutch slave cylinder pushrod clearance Spridgets 6
C 1961 3000 Recommendations for Clutch Slave Cylinder Austin Healey 5
CanberraBJ8 Stripped thread on clutch slave cylinder mount. Options? Austin Healey 9
J T-Series clutch Master cylinder or slave? MG 8
Boink Clutch Slave Cylinder dribble... Spridgets 20
L 1275 Clutch Slave Cylinder to BE Clutch Line Spridgets 14
M TR2/3/3A Position/Adjustment of TR3A Clutch Slave Cylinder Triumph 20
Darrell_Walker TR4/4A TR4A clutch slave cylinder adjustment Triumph 2
Hairyone clutch slave cylinder Spridgets 14
M clutch slave cylinder? Triumph 5
T TR2/3/3A TR3 clutch slave cylinder Triumph 14
A MIDGET 76 1500 CLUTCH SLAVE CYLINDER Spridgets 1
T TR4/4A TR4A clutch slave cylinder Triumph 9
B T-Series Clutch slave cylinder MG 15
mountainman tr 3 clutch slave cylinder Triumph 7
T Any tips on bleeding the clutch slave cylinder? Triumph 6
Bruce_B Anyone have a picture of Clutch Slave Cylinder.... Spridgets 4
JPSmit Qucik Question #1 Clutch slave cylinder Spridgets 2
Michael Oritt Clutch slave cylinder ID help needed Spridgets 3
Michael Oritt Clutch slave cylinder ID help needed Racing 3
MadRiver Speedbleeders for Clutch Slave Cylinder Triumph 3
6 clutch slave cylinder Triumph 2
tony barnhill Clutch Slave Cylinder Spridgets 17
roofman TR6 Tr6 clutch slave cylinder replacement Triumph 11
RedTR3 TR2/3/3A TR3 Clutch Slave Cylinder Adjustment Triumph 3
L T-Series Clutch Slave Cylinder Tubing MG 5
danielnorton After Marke slave cylinder for clutch hydraulics? Spridgets 20
SherpaPilot Clutch Slave Cylinder Mount Position Triumph 4
O Clutch Slave Cylinder Travel Triumph 5
T Clutch slave Cylinder HELP Triumph 3
M TR4/4A TR4 CLUTCH SLAVE CYLINDER Triumph 2
Z Clutch Slave Cylinder Rebuild Austin Healey 3
Z Clutch Slave Cylinder Rebuild Spridgets 2
Slider748 Clutch slave cylinder question. Help! Triumph 8
F clutch slave cylinder Austin Healey 12
W Clutch Slave Cylinder. Triumph 2
Alan_Myers TR4/4A TR4 clutch slave cylinder - stuck! Triumph 14
