Speedbleeders for Clutch Slave Cylinder
MadRiver
Bronze
Howdy all:
Going to tackle my clutch slave cylinder in the near future. Anyone happen to know what size Speedbleeder will fit a TR250 slave cylinder? Same as the brakes?
Thanks!
MGTF1250Dave
Re: Speed-bleeders for Clutch Slave Cylinder
Aloha Bill,
The TR3 uses 3/8 x 24 for all the brake and clutch hydraulic connections. the part number is SB3824HD or SB3824HD SS in stainless steel. I suspect the the same applies for all the TRs through the TR6. I addition to speed bleeds, I recommend you get their bleeding bag, it is like an IV bag. It is clear, lies flat under the car, an not tip over and is sealed so the fluid bled into it won't be contaminated by dirt, etc.
DNK
You can picked them up at NAPA too. Different part #. Just go in and cross reference them. Have 1 on both the 6 and the 8.
Never heard about the bag though. Nifty!
MadRiver
MadRiver
Bronze
Thanks guys! I'm a huge believer in the product, and have them on the brakes for the 250 and Tiger -- haven't done the other cars simply because I haven't gotten around to it. Just couldn't recall the size! :smile:
I too recommend the product to one and all.
B.
T What size speedbleeders for Bugeye? Spridgets 2
Lutz Kramer Clutch is disengaging slowly Austin Healey 13
Turbozinke TR2/3/3A Varying clutch engagement Triumph 6
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
Govtslug TR6 Clutch Problem Triumph 21
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
AUSMHLY Clutch Pedal Freeplay Austin Healey 18
T General Tech Clutch trouble Triumph 12
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
AUSMHLY Clutch Stalls Engine Austin Healey 16
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
T Spitfire Clutch fork and hydraulic cylinders Triumph 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
Lin Brake/Clutch Fluid Austin Healey 11
R TR2/3/3A Clutch Petal Adjustment Triumph 2
KVH General Tech New Clutch Installation--TR4A Triumph 5
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
D Clutch Fork Pin Removal Austin Healey 4
Michael Oritt Clutch Linkage Austin Healey 19
M 1275 Race Clutch Racing 5
G MGB 1978 MGB clutch is out..! MG 39
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
B Spridget with a Tilton Race Clutch Racing 1
AUSMHLY Clutch Pilot Bush: NOS vs Aftermarket Austin Healey 8
T Clutch Pedal Engagement Point Austin Healey 1
TR6Canuck For Sale 72 TR6 clutch and transmission Triumph Classifieds 4
K TR2/3/3A Clutch slave "return spring"? Triumph 3
vintagemechanic Recommended clutch kits Jaguar 3
K TR2/3/3A Clutch Master Cylinders? Triumph 1
R TR2/3/3A Clutch Engagement Triumph 31
S TR2/3/3A Clutch pushes hard when engine is hot Triumph 4
T TR2/3/3A TR3A clutch problem Triumph 15
S MGB 1978, replacing the clutch. MG 3
S MGB clutch replacement MG 7
K TR2/3/3A Clutch "Long Throw" Slave Cylinder? Triumph 4
D BJ7 Clutch Austin Healey 6
K TR2/3/3A An Unusual Brake and Clutch MC Set Up? Triumph 2
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
