MGB clutch replacement
Svcmangler
Member
Good morning everyone, I have a 1978 MGB, can the clutch be replaced by removing the transmission from under the car? I don't have an engine lift to pull the engine and transmission out as an assembly. Thanks for any help you can offer
drooartz
As far as I know, you have to remove the engine to replace the clutch.
PAUL161
It's easier if you pull them as a unit. I would buy, rent or borrow a lift. I think it can be done from below if the car is raised and removing the rear cross-member from the chassis. But the engine must be supported in it's present position, it will not support it's self when the transmission is disconnected or cross-member is out. PJ
Platinum
Best to pull the engine/trans as one unit, for sure. The trans will NOT be easily removed from underneath. It's asking for more trouble than it's worth, TRUST ME! I hate to be a "Debbie Downer" here but it truly is a lot less work and frustration if both come out & back in together.
Bob Claffie
I have on a couple occasions removed an engine and tranny (MGB) and engine (Corvette) using a come along and a maple tree branch. Not pretty but serviceable. Only downside, the previously mentioned tree is in my front yard and gathered a LOT of attention.
maynard
If your car doesn't have an overdrive, it can be done without removing the engine. I helped do mine at John Twist's. But you need a lift.
Platinum
And a sling to keep engine & firewall from meeting. Doing it without a proper car lift, on your back is no job worth attempting. Rent an engine crane and do it "by the book."
JPSmit
I have a hoist the you might be able to borrow - there a re a couple of issues, 1. it is deeply buried in my shed, 2. I have no way to get it to you 3. The covid and 4. winter
On the other hand I do need to dig it out in slightly warmer weather to drop the engine into the Vauxhall after which I will return the hoist to its owner. (who is in Guelph and conned me into storing it at my house :D ) - so if you aren't in a hurry maybe we can sort something out.
PM me
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
Marvin Gruber Clutch replacement on BJ8 Austin Healey 5
R TR6 Clutch Replacement Triumph 6
PatGalvin TR5/TR250 Clutch Replacement Recommendations Triumph 4
P Clutch replacement question British Motor Corp 1
RedTR3 Clutch Replacement Triumph 9
R clutch push rod replacement question Spridgets 6
BoneIdle T-Series Clutch replacement MG 17
philman saab 900 clutch replacement Other Cars 6
J Clutch replacement Spridgets 17
A trf clutch replacement Triumph 31
roofman TR6 Tr6 clutch slave cylinder replacement Triumph 11
J Spitfire Clutch Slave and master replacement , 78 Spitfire Triumph 13
A Clutch Replacement + Rear Crank Oil Seal Replace? Austin Healey 8
Scott_Hower T-Series Clutch hose replacement MG 32
TR_Jim Clutch shaft replacement Triumph 2
johnrip Wedge tr7 5 speed clutch replacement Triumph 1
P mastercylinder, brake & clutch replacement Austin Healey 20
K TR4/4A Clutch Replacement on TR4A. need advice Triumph 11
G Clutch Master Cylinder Replacement Austin Healey 6
MGTF1250Dave TR2/3/3A TR3 CLUTCH FRICTION DISC REPLACEMENT Triumph 9
C TR6 Request for more advice on a TR-6 clutch replacement Triumph 4
Turbozinke TR2/3/3A Varying clutch engagement Triumph 6
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
Govtslug TR6 Clutch Problem Triumph 21
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
AUSMHLY Clutch Pedal Freeplay Austin Healey 18
T General Tech Clutch trouble Triumph 12
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
AUSMHLY Clutch Stalls Engine Austin Healey 16
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
T Spitfire Clutch fork and hydraulic cylinders Triumph 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
Lin Brake/Clutch Fluid Austin Healey 11
R TR2/3/3A Clutch Petal Adjustment Triumph 2
KVH General Tech New Clutch Installation--TR4A Triumph 5
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
D Clutch Fork Pin Removal Austin Healey 4
Michael Oritt Clutch Linkage Austin Healey 19
