TR2/3/3A Gearbox clutch adjustment.
karls59tr
Bronze
My clutch pedal is getting farther down towards the floor before it engages. I am due for a new clutch setup as it has been awhile since I have replaced it. The gearbox shifts well and what I would like to do is finish out the summer with it and replace it in the winter months. Here is my question: Do I need to adjust the slave cylinder rod or the master cylinder rod to raise the contact point where the pedal engages? Because I always get this mixed up...am I to turn the rod in towards the cylinder or do I back it out away from the cylinder? My mild dyslexia always gets me in these situations.:smile:
CJD
Adjust the master cylinder rod to get full travel and still allow the piston to fully return. Then, adjust the slave rod according to the book. I can elaborate either if you need it.
If the pedal is dropping, then in all likelihood the piston seal for the master is slowly dying. But you may be able to adjust it to get through the summer.
K TR2/3/3A TR6 gearbox on TR3: re clutch slave adjustment. Triumph 13
K TR2/3/3A Clutch Slave Cylinder location when TR3 has a TR6 Gearbox? Triumph 16
K TR2/3/3A TR6 Gearbox in a TR3.....Use a TR6 clutch disc and pressure plate or Triumph 7
K TR2/3/3A Clutch for gearbox swap Triumph 14
K TR2/3/3A Clutch and Gearbox Sleeve Differences. Triumph 12
V TR4/4A Triumph TR4 A clutch assembly and gearbox Triumph 6
F Spitfire Finally Mobile! Now Grind/Rubbing from Clutch, Gearbox Or? Triumph 5
pakiwi Clutch / Gearbox issue Spridgets 6
J Clutch pressure plate very close to gearbox Spridgets 3
ecurie_ecosse Clutch/Gearbox. Spridgets 10
martx-5 Gearbox Clutch Release Fork Triumph 2
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
F Sprite Gearbox Spridgets 5
E Gearbox problem Other Cars 0
K TR2/3/3A Further to changing motor and gearbox mounts. Triumph 1
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
BN6_2197 Gearbox/Overdrive Removal Austin Healey 25
AHS Side-Shift Gearbox Austin Healey 3
D Gearbox Dipstick (BT7) Austin Healey 3
K TR2/3/3A A gearbox additive? Triumph 3
C Gearbox oil British Motor Corp 3
JFS Wedge Stripped gearbox filler hole thread Triumph 3
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
R 100 Motor and Gearbox Available Austin Healey 2
W BN1 Gearbox First Motion Shaft Austin Healey 0
KellyRob BMC GEARBOX 1960 British Motor Corp 2
Hamish Racing TR2/3/3A Gearbox - can you spot the problem ? Triumph 17
C TR2/3/3A TR3 Gearbox Problem Triumph 10
D MGA with T9 gearbox on a tow dolly MG 9
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
S Add ZDDP to gearbox oil? Austin Healey 29
R TR6 Gearbox slips out of 3rd gear Triumph 14
K For Sale Triumph TR4 & 4A Gearbox anti vibration attachment Triumph Classifieds 0
K TR4/4A The 4A gearbox anti rattle contraption? Triumph 5
Lin Gearbox Oil Austin Healey 4
R TR6 Proper alignment of gearbox front cover plate Triumph 3
BN6_2197 How regular should I change the gearbox oil? Austin Healey 5
R TR6 Gearbox rebuild issues Triumph 8
S Steering Peg in Steering Gearbox Austin Healey 13
K Gearbox Throw-out pin and gasket question Austin Healey 8
BN6_2197 Replacing gearbox switch of the overdrive system Austin Healey 10
R Spitfire 1500 gearbox question Triumph 1
R 1500 gearbox question Spridgets 0
AH67 59 xk150 gearbox Jaguar 6
G Wanted Non Overdrive gearbox wanted Austin Healey Classifieds 0
Bayless Started adapting the datsun gearbox today Spridgets 46
G Wanted ISO Gearbox for 69 Sprite, 1275 engine Spridgets Classified 2
