TR2/3/3A Further to changing motor and gearbox mounts.
karls59tr
Bronze
well it is doable from underneath the car but it's not easy.I found it almost impossible to my fingers into that little heck hole that holds one of the small 1/2"fin thread bolts in. After dropping several lock washers that disappeared forever( don't use a Nyloc nut or you will be there forever and a day winding the nut 1/8' at a time on the fine thread bolt) I ended up securing the lock washer to the nut with a couple of drops of Crazy glue. Use a small vice grip to hold the bolt head still until you can get the nut started. The other mount bolt on the drivers side can be accessed from the top with a ratchet and a couple of long extensions. I found it necessary on the passenger side to cut a bit off the 9/16" stud on the top of the mount in order to get the mount in position and that was with the motor tilted as well. Also I drained the rad in order to remove the rad hose and tube on the drivers side in order to see the motor mount bolt there and access it from the top.When I went to fill the rad after everything was put back together I discovered that I had ripped the short upper hoe at the top middle of the rad by jacking the motor too high and dumped coolant on the ground Fortunately I had a spare hose but that is something to watch out for. Of course as someone else mentioned once you have the front cowl removed for what ever reason, that's the best time to change out the motor mounts as you have good access then. Hope this helps anyone who plans on ttackling this job.
K TR2/3/3A Further to "plugging the thermostat bypass hose"/ Triumph 25
K TR2/3/3A Further to brake caliper rebuild.... Triumph 2
K For Sale Further Pics of TR3 SU's Triumph Classifieds 0
H Mk.II ratty white one near Ontario,CA--I could investigate further Jaguar 1
K TR4/4A Further to Veneering the Dash.... Triumph 4
K TR2/3/3A Further to Clutch Slave Adjustment...... Triumph 2
K Further to carb cleaning ...careful with SU domes. Triumph 7
K TR4/4A Further to TR3 Body on a TR4 frame? Triumph 2
K TR2/3/3A Further toTR3 "flattening out at 80"..... Triumph 2
K Further to wishbone clearance at steering box... Triumph 1
Number_6 TR2/3/3A Further progress on TR3! Triumph 6
drooartz Going one step further, to modify or switch? Spridgets 50
DerekJ 100-Six Web Site - Further Up-dates Austin Healey 0
Gatheringtree TR2/3/3A Changing out the battery liner Triumph 11
A TR6 Changing bulbs in gauges Triumph 27
R Changing BJ7 Differential Ratio Austin Healey 10
T Kilmartin Changing Ownership Austin Healey 2
bighealeysource Changing Steering Box Lube (BN2) Austin Healey 9
R TR2/3/3A Changing to a voltmeter. Triumph 6
red57 Changing Lock Barrels Austin Healey 15
FlyingCat Spitfire Checking/Changing Fluids Triumph 5
N Spitfire Changing Differential oil Triumph 14
jfarris TR2/3/3A Changing rear wheel studs in a later Girling axle Triumph 3
R TR2/3/3A Changing rear seal Triumph 23
C changing ignition light bayonette Austin Healey 2
J Changing Brake Discs on my 63 BJ7 Austin Healey 9
R Rear quarter elliptical suspension changing Spridgets 12
F Changing fuel Austin Healey 6
drooartz MGB Changing clutch hose - tips? MG 13
T ?Changing BE to SU electric fuel pump Spridgets 8
J TR2/3/3A Changing fan belt. Triumph 9
A TR4/4A Changing rear diff seals Triumph 15
R TR4/4A Changing from 4 speed to Overdrive on a TR4 Triumph 18
D TR2/3/3A Changing polarity on TR 3 Triumph 9
O TR2/3/3A Changing Ignition Switches Triumph 5
B Spitfire Changing leaf spring bushing - any tips? Triumph 6
Z TR6 74 TR6 - Changing headlight beam switch issue Triumph 0
M Changing coolant Triumph 14
P Changing Brake Fluid & Brake Pressure Switch Austin Healey 17
bobh Changing Transmission Oil in 10 minutes Triumph 8
P CHANGING TO FRONT DISCs Spridgets 22
Reh Changing things up Triumph 13
af3683 Changing tires on Original TR 3 Wire Wheels Triumph 4
tweety Changing a half axle Spridgets 1
58Custom Any tricks to changing front wheel bearings? Spridgets 7
Stewart Changing crossmember pads MG 2
P Changing the Oil on a 100-4 Austin Healey 81
TRnorwegian Changing clutch master cylinder - peace of cake? Triumph 10
M Brakes are terrible. Any tips on changing calliper Spridgets 14
