Kilmartin Changing Ownership
twas_brillig
See: > Kilmartin Automotive Sheetmetal <
Gosh dang!
Update to KAS Future - 14th February 2022
Since our decision to close KAS has been made public, we have been inundated with enquiries/orders and the desire for KAS to be able to continue on.
We are now in deep consultation with a keen and enthusiastic purchaser.
At this point in time all is progressing well, with their aim to carry on the business under the same name/ location with a lengthy transition and to keep producing the same lines.
To our valued clients-
After many years of making parts we have decided to call it a day!
We will be taking & filling orders from current stock up to the 31st May 2022 and closing up on the 30th June 2022.
Thanking everybody for all the years of friendship and support during the journey.
Kind regards from John, Greg & Gordon - your KAS team.
HealeyPassion
Very good news! I've purchased any number of things from them over the years... high quality. Our hobby would be significantly impacted if we lost them...IMHO.
T Kilmartin Adjustable Front Shock Mount Plates - Installation Instructions Austin Healey 0
T Kilmartin Healey 6000 Austin Healey 0
HealeyPassion Kilmartin Front Suspension Gussets Austin Healey 4
F TR2/3/3A KAS-Kilmartin outer sills with bow to match door Triumph 4
Jake For Sale FS: BN1/BN2 Kilmartin Chassis Repair Parts, New Austin Healey Classifieds 2
55modified Anyone install one of these [100S Kilmartin pieces] for fresh air in your footbox? Austin Healey 14
T Kilmartin rear inner fenders Austin Healey 2
C Inner Sill Assembly Should i spend extra money on kilmartin brand??? Austin Healey 4
Patrick67BJ8 Kilmartin Radiator Fan Shroud Austin Healey 4
oxford kilmartin sills Austin Healey 1
A Kilmartin Parts [Sills] Austin Healey 5
C Kilmartin Sheet Metal parts availability Austin Healey 7
K TR2/3/3A Further to changing motor and gearbox mounts. Triumph 1
Gatheringtree TR2/3/3A Changing out the battery liner Triumph 11
A TR6 Changing bulbs in gauges Triumph 27
R Changing BJ7 Differential Ratio Austin Healey 10
bighealeysource Changing Steering Box Lube (BN2) Austin Healey 9
R TR2/3/3A Changing to a voltmeter. Triumph 6
red57 Changing Lock Barrels Austin Healey 15
FlyingCat Spitfire Checking/Changing Fluids Triumph 5
N Spitfire Changing Differential oil Triumph 14
jfarris TR2/3/3A Changing rear wheel studs in a later Girling axle Triumph 3
R TR2/3/3A Changing rear seal Triumph 23
C changing ignition light bayonette Austin Healey 2
J Changing Brake Discs on my 63 BJ7 Austin Healey 9
R Rear quarter elliptical suspension changing Spridgets 12
F Changing fuel Austin Healey 6
drooartz MGB Changing clutch hose - tips? MG 13
T ?Changing BE to SU electric fuel pump Spridgets 8
J TR2/3/3A Changing fan belt. Triumph 9
A TR4/4A Changing rear diff seals Triumph 15
R TR4/4A Changing from 4 speed to Overdrive on a TR4 Triumph 18
D TR2/3/3A Changing polarity on TR 3 Triumph 9
O TR2/3/3A Changing Ignition Switches Triumph 5
B Spitfire Changing leaf spring bushing - any tips? Triumph 6
Z TR6 74 TR6 - Changing headlight beam switch issue Triumph 0
M Changing coolant Triumph 14
P Changing Brake Fluid & Brake Pressure Switch Austin Healey 17
bobh Changing Transmission Oil in 10 minutes Triumph 8
P CHANGING TO FRONT DISCs Spridgets 22
Reh Changing things up Triumph 13
af3683 Changing tires on Original TR 3 Wire Wheels Triumph 4
tweety Changing a half axle Spridgets 1
58Custom Any tricks to changing front wheel bearings? Spridgets 7
Stewart Changing crossmember pads MG 2
P Changing the Oil on a 100-4 Austin Healey 81
TRnorwegian Changing clutch master cylinder - peace of cake? Triumph 10
M Brakes are terrible. Any tips on changing calliper Spridgets 14
theleisure Changing Out Front Bushings Spridgets 5
R Changing Motor Mounts Triumph 6
