TR2/3/3A Further question re TR3 red ignition light.
karls59tr
Bronze
So the red ignition light was not coming on when I turned the key and cranked for starting. I discovered the the light socket was missing the ground wire so I ran a ground wire from the red light socket to the brass wing nut on the gauge cluster for a good ground. Well the red light came on nice and bright but does not go out after the car is started but stays on? Any thoughts on why that would happen. I am running an alternator so maybe it's an internal fault in the wire in the alternator?
mezy
Depending on your set up. The charge indicator light should not be earthed, it should have power to it when ignition is on
and a wire to the Alternator, this provides a current to the alternator to help kick start it into charging, when the alternator voltage
output is equal to or greater than the voltage from the charge wire it switches the light out.
pull the plug on the alternator and ground the small wire Not the big ones. .
If the light comes on then the alternator is at fault.
K TR2/3/3A Further to changing motor and gearbox mounts. Triumph 1
K TR2/3/3A Further to "plugging the thermostat bypass hose"/ Triumph 25
K TR2/3/3A Further to brake caliper rebuild.... Triumph 2
K For Sale Further Pics of TR3 SU's Triumph Classifieds 0
H Mk.II ratty white one near Ontario,CA--I could investigate further Jaguar 1
K TR4/4A Further to Veneering the Dash.... Triumph 4
K TR2/3/3A Further to Clutch Slave Adjustment...... Triumph 2
K Further to carb cleaning ...careful with SU domes. Triumph 7
K TR4/4A Further to TR3 Body on a TR4 frame? Triumph 2
K TR2/3/3A Further toTR3 "flattening out at 80"..... Triumph 2
K Further to wishbone clearance at steering box... Triumph 1
Number_6 TR2/3/3A Further progress on TR3! Triumph 6
drooartz Going one step further, to modify or switch? Spridgets 50
DerekJ 100-Six Web Site - Further Up-dates Austin Healey 0
DonC1948 TR6 A "CLASSIC" question. Triumph 6
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
D A distributer question on the 1275 engine. Spridgets 7
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
WHT Oil Sump Question For Dougie Austin Healey 0
LD-Ordie Series II gear lube question Rover / Land Rover 3
T TR2/3/3A TR3A Windshield Question Triumph 4
Celtic 77 MGB factory hardtop question... MG 10
D Cam Timing question. Spridgets 11
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
T TR2/3/3A TR3A Disk Brake Question Triumph 10
JPSmit Distributor question Spridgets 0
Bayless Door seal question Spridgets 3
M T-Series TD/TF Steering Free Play Question MG 6
