Usual 1275 rear main oil leak question
kswpe
I know this has been discussed a million times with multiple suggestions. Have a 1275 with the air pump, etc. removed with a frustrating leak at rear main bearing area). Tried everything, with and without PCV valve, vent from time chain cover, several different connections. Even tried Gerard's seal. Strange thing that may trigger a hint is that, while running, there is almost no leak but as soon as I turn it off it leaks a lot and for several hours. Any ideas?
C TR4/4A TR4A running warmer than usual Triumph 19
M Clutch problem, a little different than usual Spridgets 8
Gerard Tach wiring... [not the usual] Spridgets 7
dklawson Re-awakening an Engine - Not Quite the Usual ? Triumph 5
swift6 Not your usual cooling problem... Triumph 5
M Not the usual oil leak Austin Healey 15
DrEntropy Another rant over "the usual suspects!" MG 22
AUSMHLY Quality control, from the usual suspects Austin Healey 16
CARSINC WANTED: 1275 Engine Spridgets 0
M 1275 Timing Cover Vent Spridgets 2
drooartz 1275 cruising RPM Spridgets 5
D A distributer question on the 1275 engine. Spridgets 7
abarth69 Innocenti 1275 upgrade path Spridgets 1
D MG Midget 1275 rear oil seal. Spridgets 0
AngliaGT 1275 Engine Value? Spridgets 5
M 1275 Race Clutch Racing 5
drooartz Visual ID of a 1275 Spridgets 14
jehuie SOLVED: Fixing electrics on Morris Minor with 1275 swapped in Spridgets 13
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
jehuie Tuning up a 1275 Spridgets 17
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
BobHaskell Mini Cooper 1275 engine rebuild British Motor Corp 9
S 1275 oil pan removal Spridgets 30
M 1275 too high? Spridgets 2
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
Lin Fan belt for 1275 with alternator Spridgets 4
B Installing cam bearings 1275, can I do it? Spridgets 1
K 1275 Distributors Spridgets 6
T Dampner for a 1275 [damper? dampener?]: recommendations Spridgets 6
T Rebuilding a 1275 for a BE Spridgets 8
R 948 convert to 1275 info Spridgets 13
G Wanted ISO Gearbox for 69 Sprite, 1275 engine Spridgets Classified 2
Rut Bugeye 1275 temp probe placement. Spridgets 8
jtaylor3 1275 EN40 Crank Spridgets 5
S 1275 Blueprints Spridgets 7
A Bugeye engine swap, 948 to 1275 Austin Healey 11
M Judson Supercharger On A 1275 Spridgets 6
6 Oil pressure, or lack there of on fresh 1275 Spridgets 13
H Is there any difference in using the 1275 Float Bowl that have a different casting? Spridgets 6
Jim_Gruber 1275 Crankcase capacity is? Spridgets 4
N 1275 cams? Spridgets 2
T matching 1275 to bugeye rad ?? Spridgets 12
T Wanted wanted-- 1275 ribcase shifter and shifter seat cover if possible Spridgets Classified 0
6 1275 Head to block dowel pins Spridgets 10
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
M Proper running temp for 1275 Spridgets 28
M Wanted 1960 Bug eye sprite 1275 ! Austin Healey Classifieds 0
M Wanted 5 speed tranny for my 1275 bug eye Spridgets Classified 0
doc50 Wanted H2 SU carbs / manifold for 1275 1973 MG MIdget Spridgets Classified 3
