1275 EN40 Crank
jtaylor3
I have a crank from a 67 Sprite stamped EN40. Car I got it in was a rust bucket with only 32K miles. Bought as part of estate lot and was told by a friend of the man who died that this engine had never been out of the car. Plan was to put that engine in my 69, but when I tore it down to check it out I found the #1 rod journel had been turned 10-20 thousands. Guess it had been out before - Although the engine showed no other signs of rebuild. Anyway, I used the crank from the 69 in rebuild.
Question! - Is this crank of any use to anyone?? Do not want to toss it if it has value to someone.
Stan Kowznofski
IIRC EN40 was a decent crank, don't toss it. If you don't want it I would take it and do some more research. I only live a few miles from you, I am just outside Bellefonte, PA
dklawson
For the Mini Cooper -S, the EN40 crank was/is the one to have. They are supposed to have superior toughness. I assume the same would be true for the Spridget crank.
jtaylor3
jtaylor3
Yes. I understand that it is the one to have for the mini and Spridget. That was why I was going to use it. But I also saw that the hardening process (nitrate?) was lost when they were turned. That is why I asked this one still had value to anyone.
jtaylor3
jtaylor3
I was most surprised that only one journal was turned. Especially on a engine with 32K miles that showed no sighs of ever having been cracked open.
CARSINC WANTED: 1275 Engine Spridgets 0
M 1275 Timing Cover Vent Spridgets 2
drooartz 1275 cruising RPM Spridgets 5
D A distributer question on the 1275 engine. Spridgets 7
abarth69 Innocenti 1275 upgrade path Spridgets 1
D MG Midget 1275 rear oil seal. Spridgets 0
AngliaGT 1275 Engine Value? Spridgets 5
M 1275 Race Clutch Racing 5
drooartz Visual ID of a 1275 Spridgets 14
jehuie SOLVED: Fixing electrics on Morris Minor with 1275 swapped in Spridgets 13
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
jehuie Tuning up a 1275 Spridgets 17
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
BobHaskell Mini Cooper 1275 engine rebuild British Motor Corp 9
S 1275 oil pan removal Spridgets 30
M 1275 too high? Spridgets 2
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
Lin Fan belt for 1275 with alternator Spridgets 4
B Installing cam bearings 1275, can I do it? Spridgets 1
K 1275 Distributors Spridgets 6
T Dampner for a 1275 [damper? dampener?]: recommendations Spridgets 6
T Rebuilding a 1275 for a BE Spridgets 8
R 948 convert to 1275 info Spridgets 13
G Wanted ISO Gearbox for 69 Sprite, 1275 engine Spridgets Classified 2
Rut Bugeye 1275 temp probe placement. Spridgets 8
S 1275 Blueprints Spridgets 7
A Bugeye engine swap, 948 to 1275 Austin Healey 11
M Judson Supercharger On A 1275 Spridgets 6
6 Oil pressure, or lack there of on fresh 1275 Spridgets 13
H Is there any difference in using the 1275 Float Bowl that have a different casting? Spridgets 6
Jim_Gruber 1275 Crankcase capacity is? Spridgets 4
N 1275 cams? Spridgets 2
T matching 1275 to bugeye rad ?? Spridgets 12
T Wanted wanted-- 1275 ribcase shifter and shifter seat cover if possible Spridgets Classified 0
6 1275 Head to block dowel pins Spridgets 10
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
M Proper running temp for 1275 Spridgets 28
M Wanted 1960 Bug eye sprite 1275 ! Austin Healey Classifieds 0
M Wanted 5 speed tranny for my 1275 bug eye Spridgets Classified 0
doc50 Wanted H2 SU carbs / manifold for 1275 1973 MG MIdget Spridgets Classified 3
Jim_Gruber 1275 Damper Pulley Needed Spridgets 16
T How to add a bit more realiability/endurance to a stock 1275 engine rebuild? Spridgets 9
Gerard 1275 piston ID Spridgets 2
Gerard Wanted: 1275 Crankshaft Spridgets 3
T can't find timing marks on 1275 crankshaft pulley/damper Spridgets 8
Rut How much does a 1275 weigh? Spridgets 8
A For Sale Sprite/Midget 1275 clutch cover. Austin Healey Classifieds 0
Rut 1275 rear seal help Spridgets 0
