1275 Engine Value?
AngliaGT
I have a 1275 engine leftover from my Midget.
It's a core engine that doesn't run.
Anyone know what it might be worth?
JPSmit
can't imagine it is worth a lot. couple hundred max?
AngliaGT
AngliaGT
Thanks - I don't expect a lot of money for it,
but it'd be nice to get something out of,as I
hauled this cross-country when we moved here.
It's also on a roll-around dolly,making it easier
to move.
Pythias
I have an extra 1098... I took it out when I started misfiring on one of the cylinders. I believe it's either a burnt valve, or faulty head gasket. .. Come and get it... FREE.
SaxMan
Is it stuck, or just doesn't run? Might be a good deal for someone whose 1275 is getting tired but doesn't want to take their car off the road for an extended period of time. And, I just may happen to know of someone in that situation.
R Value of rebuilt 1275 Engine, new clutch & rib trn Spridgets 6
CARSINC WANTED: 1275 Engine Spridgets 0
D A distributer question on the 1275 engine. Spridgets 7
BobHaskell Mini Cooper 1275 engine rebuild British Motor Corp 9
G Wanted ISO Gearbox for 69 Sprite, 1275 engine Spridgets Classified 2
A Bugeye engine swap, 948 to 1275 Austin Healey 11
T How to add a bit more realiability/endurance to a stock 1275 engine rebuild? Spridgets 9
V Wanted rebuildable 1275 engine Spridgets Classified 0
AngliaGT Picking up a 1275 Engine Spridgets 6
T 1275 engine oil pressure warning light? oil filter warning light?? Spridgets 4
R 1275 engine with SU HIF single carb Spridgets 9
T Weber for a 1275 cc engine? Spridgets 6
DanLewis 1275 engine and ribcase transmission $750 [NFI] Spridgets 0
M Help me ID a couple of bolts on my 1275 engine... Spridgets 5
C 1275 fuel injected mini engine in a sprite? Spridgets 7
Trevor Jessie 948 engine with a 1275 head question. Spridgets 3
B MG Motor - 948 parts or 1275 engine MG 1
I Bugeye 1275 engine conversion questions Spridgets 3
A best year for 1275 engine? Spridgets 3
M 1275 Engine Rebuild - Especially Hap! Spridgets 11
6 1275 engine compression Spridgets 2
6 1275 engine compression Austin Healey 2
mccalebr Hap's 1275 engine builds for Ray and Drew Spridgets 15
Bruce_B Source for Motor Mounts for 1275 engine? Spridgets 4
C 1500 to 1275 engine conversion Spridgets 21
athenssprite How to differentiate 1275 engine vs smaller Spridgets 5
racingenglishcars 1275 Marina engine Spridgets 23
M 1275 Engine Paint Schemes? Spridgets 7
Bruce_B Painting 1275 engine - Questions Spridgets 44
Bruce_B 1275 Engine Rebuild - It starts this weekend! Spridgets 19
B Oil cooler engine adapters for a 1275 Spridgets 10
Bruce_B 1275 Engine Returned from Machine Shop Spridgets 12
B 1275 Engine Rebuild Cost Spridgets 6
Banjo in need of a 1275 engine Spridgets 6
George Zeck 1098 v. 1275 engine transplant ?? Spridgets 13
D Swapping 948 for 1275 engine Spridgets 11
A Distributor 1275 engine Spridgets 2
klutterbutt 1275 on an engine stand MG 14
nathandarby67 Head swap for 1275 engine? MG 4
M 1275 Timing Cover Vent Spridgets 2
drooartz 1275 cruising RPM Spridgets 5
abarth69 Innocenti 1275 upgrade path Spridgets 1
D MG Midget 1275 rear oil seal. Spridgets 0
M 1275 Race Clutch Racing 5
drooartz Visual ID of a 1275 Spridgets 14
jehuie SOLVED: Fixing electrics on Morris Minor with 1275 swapped in Spridgets 13
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
jehuie Tuning up a 1275 Spridgets 17
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
