1275 Timing Cover Vent
MJinCO
On a 1275 has the timing chain cover vent can been known to get clogged with junk and prevent the sump venting properly?
Pat MM
Yes. The metal material in there gets gunked up and eventually becomes a big plug. Another issue is from an incorrect valve cover cap that isn’t vented, not allowing air flow into the engine.
M
MJinCO
I've had a continual oil leak problem and suspect this might be much of the cause as I had it happen once on a 924 Porsche. On it the vent went directly into the sump cavity and I couldn't get the fitting out of the block so after draining oil I reverse flushed it several times with a gallon of diesel, it worked perfectly. I'm not sure about that method here considering the diesel would have to go back thru the timing chain galley hole, but probably worth a try rather than tearing apart the entire front end. After doing this it best to get the oil pressure pumped up before restarting.
The PO of this car spent a lot of money on race motor goodies, but ignored some of the basics like a poor block surfacing job and then using a metal head gasket.. Head gaskets lasted about 15 minutes of run time, a composite one worked perfectly.
C Wanted Timing gear cover 1275 Spridgets Classified 2
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
T can't find timing marks on 1275 crankshaft pulley/damper Spridgets 8
jaegzie I have no timing marks anywhere on my 1275. Spridgets 14
TulsaFred Timing Gear positioning on 1275 Spridgets 7
R 1275 timing/ carb pistion sticking Spridgets 3
lbc_newbie 1275 Midget, Sprite Timing Tape Kit Spridgets 2
Jer Stroboscopic Timing - 1275 cc Spridgets 10
T Double row timing chains - worth doing on a 1275? Spridgets 17
nathandarby67 1275 Timing advice Spridgets 12
SilentUnicorn 1275 timing chain question Spridgets 2
CARSINC WANTED: 1275 Engine Spridgets 0
drooartz 1275 cruising RPM Spridgets 5
D A distributer question on the 1275 engine. Spridgets 7
abarth69 Innocenti 1275 upgrade path Spridgets 1
D MG Midget 1275 rear oil seal. Spridgets 0
AngliaGT 1275 Engine Value? Spridgets 5
M 1275 Race Clutch Racing 5
drooartz Visual ID of a 1275 Spridgets 14
jehuie SOLVED: Fixing electrics on Morris Minor with 1275 swapped in Spridgets 13
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
jehuie Tuning up a 1275 Spridgets 17
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
BobHaskell Mini Cooper 1275 engine rebuild British Motor Corp 9
S 1275 oil pan removal Spridgets 30
M 1275 too high? Spridgets 2
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
Lin Fan belt for 1275 with alternator Spridgets 4
B Installing cam bearings 1275, can I do it? Spridgets 1
K 1275 Distributors Spridgets 6
T Dampner for a 1275 [damper? dampener?]: recommendations Spridgets 6
T Rebuilding a 1275 for a BE Spridgets 8
R 948 convert to 1275 info Spridgets 13
G Wanted ISO Gearbox for 69 Sprite, 1275 engine Spridgets Classified 2
Rut Bugeye 1275 temp probe placement. Spridgets 8
jtaylor3 1275 EN40 Crank Spridgets 5
S 1275 Blueprints Spridgets 7
A Bugeye engine swap, 948 to 1275 Austin Healey 11
M Judson Supercharger On A 1275 Spridgets 6
6 Oil pressure, or lack there of on fresh 1275 Spridgets 13
H Is there any difference in using the 1275 Float Bowl that have a different casting? Spridgets 6
Jim_Gruber 1275 Crankcase capacity is? Spridgets 4
N 1275 cams? Spridgets 2
T matching 1275 to bugeye rad ?? Spridgets 12
T Wanted wanted-- 1275 ribcase shifter and shifter seat cover if possible Spridgets Classified 0
6 1275 Head to block dowel pins Spridgets 10
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
M Proper running temp for 1275 Spridgets 28
M Wanted 1960 Bug eye sprite 1275 ! Austin Healey Classifieds 0
