General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump
B
Buffer
Hi All
I have just taken the cam shaft out of my 1275 MIdget engine and it has a slot drive for the oil pump. The Cam I am (was) replacing it with has a 3 point star drive on it.
Does anyone know if when I pulled the replacement Cam out from the front is it likely there is some sort of adaptor stuck to the oil pump which didn't come out with the cam? Or is there some kind of adaptor I can buy in the UK which will convert the 3 pointed star to a slot drive on my current oil pump? Finally I thought about changing the old pump to a star drive but certainly the pictures the retailers show don't seem to have the correct end on them.
I was asking because it would just be extra work to get to the oil pump to see if something may have been left on it when I pulled the replacement cam out.
Many Thanks
Buffer
B
Buffer
Well I have answered my own question but I will put it on here as someone else will probably want to know some time.
Yes you can replace a slot drive cam with a star drive cam but you need to change the oil pump and make sure you have the little pump drive adaptor from the donor engine to go into the end of the cam. In my case it was stuck to the pump when I pulled the cam out from the front and this made things look a little confusing.
Hope this helps someone.
JPSmit
not a 1275 owner but, thanks! I appreciate the collective knowledge of this place
D MG Midget 1275 rear oil seal. Spridgets 0
doc50 Wanted H2 SU carbs / manifold for 1275 1973 MG MIdget Spridgets Classified 3
A For Sale Sprite/Midget 1275 clutch cover. Austin Healey Classifieds 0
jmayzer 1275 Midget Bentley Shop Manual Download Spridgets 1
Steve P. 1500 radiator in an earlier 1275 cross flow Midget? Spridgets 2
M Wiper motor connector removal - 1275 Midget Spridgets 4
F MG Midget 1275 oil leak Spridgets 7
R 1275 midget equivalent replacement radiator Spridgets 13
T Single Weber Redline carb for stock Midget 1275 Spridgets 12
K 1275 Midget motor/trans into a 75 Spitfire? Spridgets 3
G Midget 1275 comp. Spridgets 16
G 72 Midget 1275 Spridgets 3
G 72 midget 1275 intake manifold Spridgets 1
lbc_newbie 1275 Midget, Sprite Timing Tape Kit Spridgets 2
NardisCNC 1275 for 66 Midget - Which one?? Spridgets 3
Steve P. 1275 in a later [1500] Midget? Spridgets 1
jbowlby Roller release bearing for 1275 Midget Spridgets 20
B 1275 exhaust on MKI Midget [1098] Spridgets 3
dingleberry3343 74 midget 1275 oil galley plug Spridgets 6
Thor Putting in 1275 motor into 1500 Midget Spridgets 4
S T-Series MG Midget 1275 Reverse Light Switch - Help Needed MG 1
S MG Midget 1275 Gearbox Oil - Help Needed MG 3
nathandarby67 WANTED: S.U. HS2 Dashpots [Midget 1275] MG 3
CARSINC WANTED: 1275 Engine Spridgets 0
M 1275 Timing Cover Vent Spridgets 2
drooartz 1275 cruising RPM Spridgets 5
D A distributer question on the 1275 engine. Spridgets 7
abarth69 Innocenti 1275 upgrade path Spridgets 1
AngliaGT 1275 Engine Value? Spridgets 5
M 1275 Race Clutch Racing 5
drooartz Visual ID of a 1275 Spridgets 14
jehuie SOLVED: Fixing electrics on Morris Minor with 1275 swapped in Spridgets 13
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
jehuie Tuning up a 1275 Spridgets 17
BobHaskell Mini Cooper 1275 engine rebuild British Motor Corp 9
S 1275 oil pan removal Spridgets 30
M 1275 too high? Spridgets 2
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
Lin Fan belt for 1275 with alternator Spridgets 4
B Installing cam bearings 1275, can I do it? Spridgets 1
K 1275 Distributors Spridgets 6
T Dampner for a 1275 [damper? dampener?]: recommendations Spridgets 6
T Rebuilding a 1275 for a BE Spridgets 8
R 948 convert to 1275 info Spridgets 13
G Wanted ISO Gearbox for 69 Sprite, 1275 engine Spridgets Classified 2
Rut Bugeye 1275 temp probe placement. Spridgets 8
jtaylor3 1275 EN40 Crank Spridgets 5
S 1275 Blueprints Spridgets 7
