1275 oil pan removal
sgg
Hi I am new to the forum, I have a problem with a 1275 1973 midget I aquired, it has continuos blue smoke coming from exhaust when warm, I have checked the usual breasthercase pipe and proceeded to take the head off and investigate but it looks a good engine rebuild but the gasket was blowing between 2 and 3 cylinders , I suspect it is a ring issue maybe stuck or broke, maybe he didnt bed it in properly and retighten, anyways my first question is I have taken all sump bolts out but she wont budge as I want to remove the pistons for inspection, have I missed something else or does it just need a good pry, maybe the timing cover bolts need slacking , hope not, this is my first midget, my other 2 are jags which I am much more familiar with, there is a story behind this one as there usually is with it being overfilled with oil as the oil filler tube had been incorrect;y installed, prior to this overfilling there was no issue with the engine smoking, at first I thought it would just burn off as oil was going into the exhaust which leads me to believe it is rings.
Thanks in advance for any help with this one.
Platinum
Pan is likely just well sealed/glued on. More concerning is the blow-by at cylinders 2 & 3. Is the head surface true? Sounds like a bodged rebuild, unfortunately the best thing would be to do a total tear-down.
No telling what else may have been done without attention to good workman-like practices.
Platinum
And welcome to the Forum! Let us know what you find.
S
sgg
Thanks for that, it does look straight the head I have used a good straight edge to check, I am hoping for ring issues which I know can happen if it wasnt bedded in properly or stood for a long while without bedding in which it was. Ill be be a bit more adventurous with the pry bars.
Mickey Richaud
As a bit of an aside, be sure to post your Midget-specific questions over on the "Spridget" (Sprite/Midget) side. There are tons of folks there with particular experience with your car model.
And welcome indeed!
JPSmit
I know more about my 1500 but, I am pretty sure this could also be a PCV issue.
If you don't mind let me move this to the Spridget forum and see what they say.
RickF
There is a brass plug in the head right between cylinders 2 & 3 which recedes into the head and allows the gasket to fail between those two cylinders. Check to be sure the plug is flush with the head surface. If it has receded even a few thousandths of an inch it can cause this problem.
Also, if the engine was overfilled with oil it may smoke for some time until all of the excess oil is burned out of the muffler and tail pipe. You have already torn the engine down, but this may be the cause of the oil smoke.
Rick
S
sgg
Ok no worries sorry I didn't see that listing originally
S
sgg
Rick
I will check that again, they did seem flush, when she gets to temp she starts to choke out on tick over , that's why I suspected the rings. I put a new head gasket on as they are reasonably priced and tightened her all up and ran her for 30 mins same problem, took the head back off and it is all fine , there is oil coming from joint off manifold as I left this dry jointed where it connected to down pipe that is why I suspected rings but might be wrong, I just thought if I could get the pistons out and inspect the rings I will have all the evidence in front of me which I will do tonight, if it not that I will look to have the head checked I guess and I will post images that might help diagnosis.
S
sgg
Latest update that is concerning, released the sump and removed 3 of the four pistons, all seem in perfect condition including the head, I have attached photos to see if enyione can throw light on this, I have not checked the pressure release valve and that is the last thing to do, everything else seems ok. not sure what I am missing or just old age is creeping in haha.
Boink
Bronze
Just looked at your head shot and it looks OK.
As an aside, and per Rick's post above, I was going to post this below (though probably not an issue for you)... but I had similar symptoms with my Bugeye (with a 1275). After much frustration (sputtering and smoke), I pulled the head... and, by-golly, there was the problem. A blanking plug in the head had recessed just a bit (maybe less than a millimeter) and that brass plug crosses the head-gasket fire-rings of cylinders 2 and 3. The moment the engine became even a little bit warm, the leaking between cylinders began. So, I took the opportunity to re-build the head and all was resolved.
Photo #1 - freshly pulled head
Photo #2 - gasket removed and depth of problem revealed
Photo #3 - a before and after-machining shot (with all blanking plugs circled, though only one was replaced).
Lastly, I temporarily had some serious smoke when I tried a PCV unit on the car, with a bit too much suction to the crankcase... and finally bailed on that unit.
S
sgg
As an aside, I was going to post this (though probably not an issue for you)... but I had similar symptoms with my Bugeye (with a 1275). After much frustration (sputtering and smoke), I pulled the head... and, by-golly, there was the problem. A blanking plug in the head had recessed just a bit (maybe less than a millimeter) and that brass plug crosses the fire-rings of cylinders 2 and 3. The moment the engine became even a little bit warm, the leaking between cylinders began. So, I took the opportunity to re-build the head and all was resolved.
Thanks for that, what is peculiar is the head gasket was exactly shot like yours in the exact same place, I have attached the photos, but when I inspected the head as you can see it is a really straight head, it is a newly reconditioned engine and I cannot find fault, I thought maybe it had been bedded in and not retightened but I checkedthe torque and they were ok, so really running out of solutions here, I only have left the pressure release valve or help is always available at hogwarts, haha
haha
Boink
Bronze
Hmmm... not sure. Perplexing why the gasket is black between 2 and 3 (and has a bit of a worn look where it is silver). There is an odd marring (?) on the head at that blanking plug too (which also shows on the gasket). Given that the head is supposedly OK in that location, is the block itself OK in that same spot? BTW, I presume that if the entire engine was renewed that the head was crack-tested before/during all that.
Given that wear look on the gasket and head at the site of the blanking plug, I'm still suspicious of that problem. I believe the Rick (above) reports that even a recession of a few thousands of a inch will create a difficulty (though mine was much more).
S
sgg
Just to track what had happened, I purchased the car and did a body restoration as most of the mechanics were complete including a new engine and gearbox, all new mechanical parts, started the engine when I first got it using a can and no issues, about a year later when completed the car restoration and ready for final fire up, I noticed the oil level was low so topeed her up and thought at the time it was a lot to bring her to correct level (about a litre) when I fired her back up after a few ignition problems and opting for new elctronic version she was smoking like mad, removed rocker cover to see oil spewing into chamber, so drained oil and refilled her using the capacity reccomended, found out that the dipstick tube was incorrectly installed and not hammered home, assuming it was just oil entry into exhaust ran her for a good hour thinking she might burn the oil off but to no avail, so stripped her and found the head gasket blowing between 2 and 3 yet no signs what so ever off the head or block being at fault and no problem prior to being overfilled so opted to check pistons and all ok, It could be a minor crack but I am assuming that overfilling would not cause that, thats why I was wondering about the relief valve which is meant to be relieving the pressure when cold??? I even did a compression tst and that was fine too. Rememeber I have fitted a new gasket and that has not blown as I inspected the head again so it seems like pressure build up maybe.
Boink
Bronze
Whew... perplexing. Bold to pull the pistons so soon. :smile: Also, good that you ran it for awhile to be sure that there wasn't oil in the exhaust to be burned off. Compression fine. Hmmm. Presuming that valves are properly opening/closing (nothing sticking and I would presume that checking compression would confirm that too), I'm at a bit of a loss. Still... why does that spot look odd.
S
sgg
Well it seems such a small engine compared to the jags I work on so just wanted to be confident of what I had in front of me as I didn't do the recon, yet it seems a good job , if you look at the head plugs yiu mentioned they are absolutely spot on , I just thought he might not of tightened it down in the correct sequence which caused the initial blown gasket, I would of continued trying to burn the oil off but it was choking up when hot. I hope someone can throw light on this.
Boink
Bronze
SaxMan
I'm another "victim" of the blanking plug taking out the head gasket and causing a huge compression loss in the #2 & #3 cylinders. I had my head pulled and rebuilt. If you search this forum, there are posts about the fix to the blanking plug issue. IIRC, it is fixed by putting in a threaded brass bolt and then having a machine shop grind the bolt until it is flush with the head surface. I've put about 12,000 miles on the car since that repair, and no problems at all.
Boink
Bronze
The shop that re-built my head (new valves, guides, flattening/smoothing, grinding, etc.) used a threaded blanking plug. Like you, never had a problem since.
D MG Midget 1275 rear oil seal. Spridgets 0
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
6 Oil pressure, or lack there of on fresh 1275 Spridgets 13
T 1275 engine oil pressure warning light? oil filter warning light?? Spridgets 4
Rut 1275 oil pump, camshaft adapter Spridgets 2
Jim_Gruber Looking for Oil Tube for a 1275 Spridgets 12
F MG Midget 1275 oil leak Spridgets 7
T 1275 transmission oil leak Spridgets 2
Rut 1275 oil change Spridgets 6
I 1275 spin on oil filter unit and pipe for sale? Spridgets 8
theleisure 1098 & 1275 Oil Pans-- Same or Different? Spridgets 4
C 1275 ran without oil for 5 miles... Spridgets 30
abarth69 1275 PCV valve and oil leak Spridgets 7
EVSpriteGuy Oil for 1275 ribbed case tranny??? Spridgets 1
O 1275 oil pressure--NOT! Spridgets 5
dingleberry3343 74 midget 1275 oil galley plug Spridgets 6
R 1275 leak @ oil pump Spridgets 5
Bruce_B Oil Galley plugs and 1275 rebuild question Spridgets 2
B Oil cooler engine adapters for a 1275 Spridgets 10
P 1275 Oil Filter?? Spridgets 22
Kurtis 1275 Oil Filter Change on a Bugeye... Spridgets 10
S MG Midget 1275 Gearbox Oil - Help Needed MG 3
CARSINC WANTED: 1275 Engine Spridgets 0
M 1275 Timing Cover Vent Spridgets 2
drooartz 1275 cruising RPM Spridgets 5
D A distributer question on the 1275 engine. Spridgets 7
abarth69 Innocenti 1275 upgrade path Spridgets 1
AngliaGT 1275 Engine Value? Spridgets 5
M 1275 Race Clutch Racing 5
drooartz Visual ID of a 1275 Spridgets 14
jehuie SOLVED: Fixing electrics on Morris Minor with 1275 swapped in Spridgets 13
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
jehuie Tuning up a 1275 Spridgets 17
BobHaskell Mini Cooper 1275 engine rebuild British Motor Corp 9
M 1275 too high? Spridgets 2
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
Lin Fan belt for 1275 with alternator Spridgets 4
B Installing cam bearings 1275, can I do it? Spridgets 1
K 1275 Distributors Spridgets 6
T Dampner for a 1275 [damper? dampener?]: recommendations Spridgets 6
T Rebuilding a 1275 for a BE Spridgets 8
R 948 convert to 1275 info Spridgets 13
G Wanted ISO Gearbox for 69 Sprite, 1275 engine Spridgets Classified 2
Rut Bugeye 1275 temp probe placement. Spridgets 8
jtaylor3 1275 EN40 Crank Spridgets 5
S 1275 Blueprints Spridgets 7
A Bugeye engine swap, 948 to 1275 Austin Healey 11
M Judson Supercharger On A 1275 Spridgets 6
