1098 & 1275 Oil Pans-- Same or Different?
No, not even close, the only one that interchanges is the 948 and the early 1.75" main journal 1098, all else are unique to themselves. I know this because we always ran the Winer Circle race oil pans, and found out years ago, what would interchange and what would not, even though the 1098 10CC motor and the 1275 has the same main jornal sizes the main caps and oil pans are different.
Thanks! I'm going through the list as i get ready to swap a 1275 in for my 1098 (10cc) and I wondered if I'd be able to reuse the chromed oil pan that the PO installed on the 1098. mmm, chrome.
sorry, guess I should've done a search first
All 948 and 1098 oil pans will interchange. Whether 1.75" or later 2.00" 1098 mains. 948/1098 and 1275 will not interchange. The reason is the rear main bearing cap. 1275's are just a bit wider. Compare the cork gasket inserts of the 948/1098 and 1275. 1275 has two different lengths. 948/1098 has two the same length.
Now, that being said, there are some differences between the 948 and 1098 oil pans. They have to do with the difference in the crankshaft stroke and the attendant arc that the rod follows. The 1098 oil pan is "thinner" along the pan rails. If you are using an aftermarket rod that is "Straigh-cut" for cap removal across the cap rather than diagonal, you have to use the 1098 oil pan on a 1098 or the rods will tap the oil pan near the distributor side rail. That is where all the shaping is made in the block and the pan. Occasionally, when using a Carillo rod, one will also find interferences on the manifold side rail. Not much, but sometimes one has to grind away the block in a few places.
Put a 1098 oil pan beside a 948 and one can see the difference in the thickness/widths of the raised boss front to rear on the oil pan rails. It is subtile, but it is distinctive in a few places.
Got some pictures of the two pans side by side, but can't figure out the upload routine.
HTH, Mike Miller
M Differences in Slave Cylinders for 948/1098 & 1275 Spridgets 5
Colin8 1098/1275 Crankshaft Pulley - Damper Spridgets 3
jvandyke head gasket 1098 vs 1275 Spridgets 1
theleisure 1098 to 1275 swap list Spridgets 8
R Carb differences 1098 and 1275? Spridgets 6
T Checklist of changes to swap 1098 for 1275 Spridgets 9
B 1275 exhaust on MKI Midget [1098] Spridgets 3
T 1275 donor for the Bugeye or stay with 1098? Spridgets 11
Bruce_B 1275 with 1098 Transmission Spridgets 13
George Zeck 1098 v. 1275 engine transplant ?? Spridgets 13
R Extra 948 and 1098 Engines Spridgets 9
JimLaney 1098 stuck lifters problems Spridgets 5
F Tightening the idler pulley bolt on a 1098 Spridgets 2
Gerard 1098 10CC rear main seal conversion Spridgets 4
B 1098 motor Spridgets 2
F Swapping out original 1098 distributor to electronic Spridgets 13
Gerard 1098 "10CC" rear main Spridgets 0
C 1098 engine Spridgets 5
MY66AH 1098 Rebuild Spridgets 11
Gerard 1098 10CC crankshaft Spridgets 14
J Bad News 1098 Spridgets 14
Pythias 1098 worth saving? Spridgets 29
Gerard 1098 master cylinder springs Spridgets 0
A 1098 Oil Consumption Spridgets 11
T 1098 angry cc's of fury is enough to... Spridgets 4
britndablood FS 1098 with rib case in North Carolina Spridgets 0
scoutll Spin on Oil Filter conversion on a 1098 Spridgets 11
M 1098 engine core-need it ? Spridgets 10
Michael Oritt 948 or 1098 Race Engine wanted Racing 3
jlaird Need a 1098 timeing chain cover. Spridgets 12
M Found this in my 1098 Spridgets 14
M Do 1098 motors have fuel pumps ? Spridgets 8
M best 1098 motor to rebuild Spridgets 6
NardisCNC 1098 Distributor Cap Question.... Spridgets 7
D '66 1098 Midget,,,how hard to fix partial floor? Spridgets 7
Colin8 1098 Pistons Spridgets 0
T 1098 valve clearance - .012 cold? Spridgets 1
T Spin-on conversion options for a 1098 Spridgets 2
N Clutch Wanted 1098 motor 1964 Sprite Mkll Spridgets 4
T Tips on pulling a Bugeye 1098 & smooth case trans Spridgets 7
Jim_Gruber Thermostat Housing for 1098 Spridgets 21
jvandyke 1098 vent tube Spridgets 77
Luke_Healey Weber DCOE 45 OK on a 1098 CC engine? Spridgets 2
Luke_Healey How to make my own 1098 radiator-to-waterpump hose Spridgets 19
Luke_Healey Professional troubleshooting for my 1098?? Spridgets 31
jvandyke 1098 exhaust options Spridgets 43
Luke_Healey Will this oil filter convertor work on my 1098? Spridgets 14
tony barnhill 1098 Cam Spridgets 17
Jayrz 1098 available Denver Spridgets 2
P proper ignition wires for 1098 CG...??? Austin Healey 2
