948 or 1098 Race Engine wanted
Michael Oritt
A friend is looking for a 948 or 1098 race engine with quality internal parts (pistons, con rods, etc). If anyone has any leads please send me a PM.
Michael, I might have a lead on one as well, we had all the goodies to build a stomper 1098 here for some time, billet crank, Carrillo rods, Venolia pistons, 1.5 Titan roller rockers, Tabor Comptune cylinder head, all the right stuff. We could put it together or maybe sell it as kit. Bottom line, it's been lying here for 3+ years, and my buddy who owns it all stays too busy with his business to go racing, so he might let it go. He also has a budget 948 Bob Griffin BHP race engine here as well, used to be John Salisbury Sr. motor, not as fancy, pretty bacis actually, dome pistons though, probably can be bought cheap, I'm sure sure it needs to be gone thru, but thats about all I know on it.
Michael Oritt
Michael Oritt
All--
I believe a fresh, fully assembled engine has been located.
Hap, I told him to call you even before I posted the original message and assume you and he spoke.
Thanks in any case for the quick responses.
R Extra 948 and 1098 Engines Spridgets 9
M Differences in Slave Cylinders for 948/1098 & 1275 Spridgets 5
sim looking for 2 valve spring kippers for a 948 Spridgets 3
sim 948 aluminum head gasket Spridgets 2
R 948 convert to 1275 info Spridgets 13
M 948 Cylinder Block Studs - Sequence on Cylinder Block Spridgets 4
M 948 Engine Rebuild Question Spridgets 0
M Vacuum Line on a 948 Spridgets 4
A Bugeye engine swap, 948 to 1275 Austin Healey 11
pbraun For Sale Free 948 and smooth case Spridgets Classified 0
M 948 Engine ID help Spridgets 3
apbos Turbo 948 engine? Spridgets 3
F Ribbed case tranny in 948 bugeye Spridgets 2
J New Guy 948 ribcase question Spridgets 6
M Timing Chain on 948 Rebuild Spridgets 1
Jim_Gruber What is the correct Radiator Cap for a 948 with a Downflow Radiator Spridgets 4
M 948 Side Cover Needed Spridgets 0
M Need Advice On 948 Engine Rebuild Spridgets 7
M 948 Pulley Nut Size Spridgets 1
M Engine Stand - What Bolts Recommended for 948 Spridgets 3
Jim_Gruber Shift Points for Bugsys 948 w Cooper S Head Spridgets 3
M 1275 to 948 Generator Swap - Need Input Please Spridgets 4
Jim_Gruber Static Timing a 948 in a BE Spridgets 12
Jim_Gruber Question on 948 Head Torque Specs - Before I break something please Spridgets 3
Jim_Gruber Coolant Bypass Nipple on 948 Welded Closed - Advice needed Spridgets 7
B Reinstalling 948 engine Spridgets 7
AN6-TX 948 Thermostat Housing Spridgets 11
certifiedcarnut 948 front brake shoes warning Spridgets 5
certifiedcarnut pipe between front brake wheel cylinders on 948 midget [drum brakes] Spridgets 4
SD Bugeye Are there any of us with 948 builds left? Spridgets 13
M 948 clutch hydraulic line Spridgets 7
bugedd So I drove my first 948 Bugeye...... Spridgets 25
D wtb 948 exhaust manifold Spridgets 3
D 948 Oil Cap Spridgets 5
Trevor Jessie 948 engine with a 1275 head question. Spridgets 3
D 948 clutch kit Spridgets 2
B 948 flywheels? Spridgets 8
6 Valve adjustment stock 948 Spridgets 11
longbridgehealey speedo cable 948 to 1275 Spridgets 2
I source for used 948 oil pan Spridgets 4
longbridgehealey another 1275 from 948 question Spridgets 3
longbridgehealey generator from 948 Bugeye Spridgets 2
B MG Motor - 948 parts or 1275 engine MG 1
7 948 sprite chewed the number three rod bearing MG 10
L Ribcase transmission with 948 engine Spridgets 8
I Bugey 948 engine rebuild gone wrong - need help Spridgets 12
I Bugeye 948 ignition timing help please Spridgets 8
I bugeye 948 rebuilt engine - no oil pressure, Spridgets 7
Sarastro Improved clutch on a 948? Spridgets 7
I How do you static time a 948? Spridgets 4
