How do you static time a 948?
JPSmit
7aqwM2Y" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"> </embed></object>
Billm
Find the timing mark on the crank pulley-
Put a chalk mark on the timing mark-
Look under the car and align that chalk mark with the biggest pointer of the 3 down there-
Take off the distributor cap and loosen that 7/16 clamp bolt that is about 1 1/4" long-
turn the distributor clockwise until the points "just" open (it is easier to tell this if you have a test light hooked to the small wire on the side of the dist- when the light lights up then the points have opened)(this is with ignition "on")-
Now tighten that bolt and start the engine.
This will get you "close-enough" to start the car, you will want to do a future timing when the car is running and warmed-up some.
BillM
I
ichthos
I am working on oil pressure and fixing the water valve, then I will give it a shot. How were you able to save the YouTube video? Thanks to both of you for your help.
Kevin
Jim_Gruber Static Timing a 948 in a BE Spridgets 12
G D would anybody be able to tell the correct way to static time a essex v6 I have tried and failed cheers garth TVR 14
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
BN6_2197 BN6 Static Timing Austin Healey 2
J TR6 73 TR6 Static Timing Questions Triumph 6
S Wanted MGB Static Seat/Shoulder Belts MG Classifieds 0
C Static timing before engine start up Spridgets 4
B Static timing Austin Healey 8
C Static Ignition Timing Austin Healey 1
af3683 TR2/3/3A Set Static Timing on TR3B - Car Runs Poorly Triumph 27
M Test light to set static timing Triumph 39
af3683 TR2/3/3A TR3B Static Timing Triumph 28
T 100M Static Timing Austin Healey 0
mrv8q TR2/3/3A TR3 Static timing; point of confusion. Triumph 16
B Radio Static Austin Healey 4
MadRiver TR5/TR250 TR250 Static Timing Triumph 8
Tabcon Pertronix Static Timing? Triumph 15
H TR2/3/3A TR3A Timing [Static or Dynamic ?] Triumph 10
MGTF1250Dave TR2/3/3A TR3 Static Timing with Pertronix Ignition Triumph 5
dklawson Spitfire Spitfire Static Timing, Conflicting Data? Triumph 9
jjbunn Static Timing: 12*BTDC or 8*BTDC ? Triumph 17
MTribe setting static timing with pertronix ignitor Triumph 0
MTribe how to adjust static timing? Triumph 8
T static timing with electronic ignition? Triumph 10
Twosheds HSTRL Static Display Reopens Triumph 0
I TR6 69 TR6 static vs moving timing - what is better? Triumph 6
T MGB Static timing a MGB w/ a Crane Electronic Ignition MG 5
Daimlerdb18 Timing light timing versus static test lamp MG 7
startech47 Static timing a 1979 Midget Spridgets 4
mrstinson Renew Dizzy and Static Timing Spridgets 15
P Static Timing Austin Healey 3
R Pertronix ignition and static timing MG 22
T How 2 remove "static" and white dust ? Restoration & Tools 8
sim looking for 2 valve spring kippers for a 948 Spridgets 3
sim 948 aluminum head gasket Spridgets 2
R Extra 948 and 1098 Engines Spridgets 9
R 948 convert to 1275 info Spridgets 13
M 948 Cylinder Block Studs - Sequence on Cylinder Block Spridgets 4
M 948 Engine Rebuild Question Spridgets 0
M Vacuum Line on a 948 Spridgets 4
A Bugeye engine swap, 948 to 1275 Austin Healey 11
pbraun For Sale Free 948 and smooth case Spridgets Classified 0
M 948 Engine ID help Spridgets 3
apbos Turbo 948 engine? Spridgets 3
F Ribbed case tranny in 948 bugeye Spridgets 2
J New Guy 948 ribcase question Spridgets 6
M Timing Chain on 948 Rebuild Spridgets 1
Jim_Gruber What is the correct Radiator Cap for a 948 with a Downflow Radiator Spridgets 4
M 948 Side Cover Needed Spridgets 0
M Need Advice On 948 Engine Rebuild Spridgets 7
