D would anybody be able to tell the correct way to static time a essex v6 I have tried and failed cheers garth
Garth
Would anybody be Able to tell me how to static time a essex v6 I have taken distributer out some time ago placed it back won’t start thanks garth
LarryK
Number 1 cylinder at tdc, Check dizzy for correct #1 to that cylinder. Sometimes try 180* off. Move wires if you have to. Use a test light on points to set dizzy also. Have been known to use trial and error.
Grantura_MKI
As said above, but I would remove the valve cover on #1 side and watch the valves “rock” to be sure you are on the correct stroke.
Skinny screw driver also helps as the piston comes up the bore.
LarryK
Did not know how far he could go. Thanks, Grantura_MKI.
G
Garth
Number 1 cylinder at tdc, Check dizzy for correct #1 to that cylinder. Sometimes try 180* off. Mobe wires if you have to. Use a test light on points to set dizzy also. Have been known to use trial and error.
Many thanks👍
Gerard Is anybody able to ID these racing/sports seats? Spridgets 0
Csarneson Anybody feeling optimistic? Or drunk? Austin Healey 21
Keoke Anybody heard: Austin Healey 9
Got_All_4 General TR Anybody Hear or Use This Hot Spark System? Triumph 10
Csarneson Anybody seen this Front Shock Conversion Kit before? Austin Healey 6
Gerard Anybody have...? Spridgets 9
TRMark General Tech Anybody Using Star Tron Triumph 2
J Anybody driving a 2018 Jaguar XJ? Jaguar 3
J anybody tell me why this thread closed? Austin Healey 4
TR3TR6 TR2/3/3A Anybody else having a bad day! Triumph 31
M TR2/3/3A Does anybody use the oils and lubes from the moss motors site? Triumph 3
TomMull Post-War Other Anybody interested in 10s? Triumph 15
2billydavies TR2/3/3A anybody need a spare rear bumper? Triumph 8
Randy Forbes Healarossa; anybody ever seen, or heard of it? Austin Healey 2
catfood Rivnuts anybody Austin Healey 19
H Joan Baex 1961 flat floor--silver exterior--anybody know what IRS sold it for? Jaguar 0
H TR4/4A Triumph 250-K by Pete Brock--anybody recall how much Brock advertised it for? Triumph 1
K Anybody Try Exactline blades? Restoration & Tools 4
B TR2/3/3A Anybody finish their car in laquer? Triumph 18
64Elan Anybody interested in an Italian Spridgit? Spridgets 3
Gerard Anybody have a steering wheel emblem for '68 Sprite stock steering wheel? Spridgets 11
S Anybody tried this Alternator ? Austin Healey 11
W Anybody have one of these surplus? Spridgets 5
krswen TR2/3/3A Anybody own TR3 TS 59719 L? Triumph 0
krswen Anybody own Series 1 E-type coupe 1E 32257? Jaguar 2
TR4nut TR6 TR6 under dash pics? Anybody? Triumph 9
DNK Wedge Anybody have any "good" adhesive? Triumph 2
B anybody know how and where I can get the cable ends for the heater cable? Spridgets 13
AN5Sprite Anybody Have A Bugeye Fuel Gauge Core To Spare? Spridgets 3
J Anybody need a 1500 motor? Spridgets 2
R July 15 Fairfield Ohio meet anybody going? Spridgets 8
Gerard Does anybody have a busted crank? Spridgets 3
regularman Anybody in Arkansas? Spridgets 2
rkep01 Anybody have one of these available? Spridgets 7
regularman Anybody got any cheap used distributor parts Spridgets 8
M TR2/3/3A Anybody ever dye wool carpet? TR3 Triumph 0
T TR2/3/3A Anybody need a TR3 frame and suspension Triumph 5
T Anybody Want to Play "Identify the Crud"? Triumph 2
DNK Anybody? Triumph 3
Banjo TR4/4A AAAAUG! anybody got an extra TR4A piston? Triumph 3
DNK Anybody have .. Lotus 1
jdubois Anybody tried these floats? Triumph 7
DNK Anybody need an Eclat Lotus 4
longbridgehealey Does anybody know this car?? Spridgets 0
DNK Anybody... Triumph 12
jdubois TR6 Anybody interested in a TR6 in boxes in MA? Triumph 16
Tr3aguy Anybody got 44k Triumph 16
L Anybody used.... Spridgets 9
S Anybody need a grocery gettery??! Other Cars 10
jjbunn Anybody near Fort Walton Beach, FL ? Jaguar 7
