Hey there Guest! If you enjoy BCF and find our forum a useful resource, if you appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please consider supporting with an "optional" low-cost annual subscription.
Number 1 cylinder at tdc, Check dizzy for correct #1 to that cylinder. Sometimes try 180* off. Move wires if you have to. Use a test light on points to set dizzy also. Have been known to use trial and error.
As said above, but I would remove the valve cover on #1 side and watch the valves “rock” to be sure you are on the correct stroke.
Skinny screw driver also helps as the piston comes up the bore.
Number 1 cylinder at tdc, Check dizzy for correct #1 to that cylinder. Sometimes try 180* off. Mobe wires if you have to. Use a test light on points to set dizzy also. Have been known to use trial and error.
A friendly reminder - be careful what links you click on here. If a link is posted by someone you don't know, or the URL looks fishy, DON'T CLICK. Spammers sometimes post links that lead to sites that can infect your computer, so be mindful what you click.
(Click X in the upper-right to dismiss this notice)
