TR4/4A AAAAUG! anybody got an extra TR4A piston?
Banjo
I was cleaning up the pistons I took out of the TR4A block, and I picked a big chunk outta the parts cleaner pan. I thought, wow, that ring was broken.... no wait... that's a ring land! Crud!
I guess that goes with the marks I found on the big end of the number 2 rod. Looks like a PO in the distant past tried to extract that piston without taking the ring ridge off the top of the cylinder.(The head was removed when I got the car) I took them off yesterday in prep to remove the pistons. I was being very careful because I planned to use the pistons for my rebuild.
I'm betting the noticeable play in the crank bearing on #2 was causing a good knocking noise, and was probably the reason the engine was pulled out of service.
All this to say, now I need a replacement 86mm piston. Stock fare for a 66 TR4A.
Anybody? anybody?
TexasKnucklehead
Some time ago I purchased a set of connecting rods (off ebay) and these were on them. I'm not sure if it's a TR4 piston or 86mm, but I have a set of 4 that I will not be using.
-Funny thing, I ended up not using the connecting rods either. My pistons were rusted solid to the liners. I eventually used a sledge to drive them out, and found the original rods were more 'balanced' (closer in weight) than the ones that came with these pistons. I used new liners and pistons and had new small ends pressed in and reamed by a machine shop. IF you want these pistons, let me know.
Jerry
Banjo
Banjo
That may just be it Jerry.
My screen is a bit dark, is that reading 85.46mm?
I'll double check mine, but I bet that's it.
mallard
If Jerry's piston does not work let me know I got one that measures about the same. I can't throw anything away.
G D would anybody be able to tell the correct way to static time a essex v6 I have tried and failed cheers garth TVR 14
Csarneson Anybody feeling optimistic? Or drunk? Austin Healey 21
Keoke Anybody heard: Austin Healey 9
Got_All_4 General TR Anybody Hear or Use This Hot Spark System? Triumph 10
Csarneson Anybody seen this Front Shock Conversion Kit before? Austin Healey 6
Gerard Anybody have...? Spridgets 9
TRMark General Tech Anybody Using Star Tron Triumph 2
J Anybody driving a 2018 Jaguar XJ? Jaguar 3
J anybody tell me why this thread closed? Austin Healey 4
TR3TR6 TR2/3/3A Anybody else having a bad day! Triumph 31
M TR2/3/3A Does anybody use the oils and lubes from the moss motors site? Triumph 3
TomMull Post-War Other Anybody interested in 10s? Triumph 15
2billydavies TR2/3/3A anybody need a spare rear bumper? Triumph 8
Randy Forbes Healarossa; anybody ever seen, or heard of it? Austin Healey 2
catfood Rivnuts anybody Austin Healey 19
H Joan Baex 1961 flat floor--silver exterior--anybody know what IRS sold it for? Jaguar 0
H TR4/4A Triumph 250-K by Pete Brock--anybody recall how much Brock advertised it for? Triumph 1
K Anybody Try Exactline blades? Restoration & Tools 4
B TR2/3/3A Anybody finish their car in laquer? Triumph 18
64Elan Anybody interested in an Italian Spridgit? Spridgets 3
Gerard Is anybody able to ID these racing/sports seats? Spridgets 0
Gerard Anybody have a steering wheel emblem for '68 Sprite stock steering wheel? Spridgets 11
S Anybody tried this Alternator ? Austin Healey 11
W Anybody have one of these surplus? Spridgets 5
krswen TR2/3/3A Anybody own TR3 TS 59719 L? Triumph 0
krswen Anybody own Series 1 E-type coupe 1E 32257? Jaguar 2
TR4nut TR6 TR6 under dash pics? Anybody? Triumph 9
DNK Wedge Anybody have any "good" adhesive? Triumph 2
B anybody know how and where I can get the cable ends for the heater cable? Spridgets 13
AN5Sprite Anybody Have A Bugeye Fuel Gauge Core To Spare? Spridgets 3
J Anybody need a 1500 motor? Spridgets 2
R July 15 Fairfield Ohio meet anybody going? Spridgets 8
Gerard Does anybody have a busted crank? Spridgets 3
regularman Anybody in Arkansas? Spridgets 2
rkep01 Anybody have one of these available? Spridgets 7
regularman Anybody got any cheap used distributor parts Spridgets 8
M TR2/3/3A Anybody ever dye wool carpet? TR3 Triumph 0
T TR2/3/3A Anybody need a TR3 frame and suspension Triumph 5
T Anybody Want to Play "Identify the Crud"? Triumph 2
DNK Anybody? Triumph 3
DNK Anybody have .. Lotus 1
jdubois Anybody tried these floats? Triumph 7
DNK Anybody need an Eclat Lotus 4
longbridgehealey Does anybody know this car?? Spridgets 0
DNK Anybody... Triumph 12
jdubois TR6 Anybody interested in a TR6 in boxes in MA? Triumph 16
Tr3aguy Anybody got 44k Triumph 16
L Anybody used.... Spridgets 9
S Anybody need a grocery gettery??! Other Cars 10
jjbunn Anybody near Fort Walton Beach, FL ? Jaguar 7
