General TR Anybody Hear or Use This Hot Spark System?
charleyf
It is probably not fair to compare a similar one ( true spark) to this one. But the True Spark totally died on me about 170 miles from home and 15 miles from my destination.
I replaced it with a rebuilt points unit and will NEVER EVER go back to a new electronic unit. I suspect that the failure may have been due to the use of copper plug wires. But it died and left me sitting on the side of the road.
Got_All_4
Got_All_4
I love the Petronix in my TR3. It made a world of difference in performance. I do carry points just in case because it is a mechanical device so at some point it will fail. I bought a set for my TR250 2 years before the restoration was complete and I could never get it to run right and concluded it was bad out of the box. Warranty was up so I was stuck with it. Being these are a 1/3 the price I was willing to give it another chance. Plus I'm thinking of my 69 TR6 too which I just started the tear down for it's restoration.
Sarastro
I have never been a big fan of Pertronix, and I'm even less of a fan of these cheapo copies. There is just no way you can shoehorn a capacitive-discharge electronic ignition circuit entirely into a little module like that without making some big compromises in the design. I think a better option is one of the units with an external electronics module. If the nonoriginal appearance bothers you, you could mount it somewhere out of sight, and, with a little cleverness with the wiring, it would be hard to tell that it's not an original setup.
Given all that, the Pertronix appears to be a decent-quality component. I've heard nothing but bad things about those copies, mostly poor reliability.
I had a Crane XR700 in my Bugeye Sprite. I liked the unit, but the shutter that goes in the distributor didn't fit well. I ended up making my own on my little lathe, not exactly an option for many people. I now have a 123Ignition distributor in my Porsche. It isn't cheap, but it works well, and I like knowing that I have the right advance curve. I am considering getting one of these, with the programmable advance, for my TR4A. I have to confess to using a Pertronix in the Porsche for a while. I had no problems with it.
TR250Guy
I have been using the hot spark unit for 4 years of flawless operation. I would not call it a cheapo copy. I would call pertronix an overly priced unit.
Geo Hahn
I'm going to try one in the one car I have that is negative ground. I'll mount it to a spare base plate so it ans the points are simple drop-in substitutions.
Got_All_4
Got_All_4
I carry an extra set of points in the glove box in my TR3 and I run Petronix now. If Hot Spark works as good as TR250GUY says, then it's cheap enough to keep an extra Hot Spark in the glove box. Both would be under 100 bucks but Petronix depending on who you get it from would be over 200 bucks.
Got_All_4
Got_All_4
Looks like I'm going to try one of those Hot Sparks. Went out to go to the store Thursday and the Tr250 would not start. Popped the bonnet and there was a black wire hanging off the coil. Took the distributor off and the Petronics wires wrapped around the roter. Not happy as $100 out the window. For kicks giggles I took a 32nd inch cutoff wheel and cut the module apart to get to a 1/8" of wire sticking out. Soldered both back on and to my surprise it worked. Don't trust it now for long time driving so I'm ordering 2 of those Hot Sparks. Install both to test them and save the one for my 69 TR6 Restoration.
I was concerned when I installed it originally that the wires were too flexible. So I took a #8 ring terminal, pulled the insulator off, used the screw that Petronics gives you to hold the base to the distributor. Then I ran a very thin wire through the terminal end and used the thin wire as a tie down. Don't know how that could have failed.
Geo Hahn
I'm going to try one in the one car I have that is negative ground...
Just a follow-up. I installed it in my spare distributor (Jaguar) and have driven for a couple of weeks including 100°+ drives. Performs just fine.
The idle speed is steadier with this, suggesting there is a bit of wobble in the shaft of the other distributor. Idle wavering doesn't matter much but may be an indicator of what is happening at high RPMs.
I have always used points and would have probably never have tried an electronic trigger but for the $39 price tag.
One drawback is that it appears to come only in the negative ground version, hence of no use in my TRs.
Got_All_4
Got_All_4
Glad it worked out for you. i never posted my experience but I didn't get far. pulled the 250 in the working garage. Checked to make sure I had the correct Ohms in my coil and I did but it doesn't recommend voltage over 13.7 volts at any RPM. I was well over that. It said to install a 1.4 Ohm ballast resister between the coil + and the Hot Spark red terminal. Don't know where to get this resister.
That wasn't the big problem After I installed it and upon start up it ran like crap. Re-set the timing because the pick up is in a different place and that didn't help. Thought I ruined it because of the high voltage and re-installed the Petronics. It ran worse. Heard a creaking noise in the valve cover and discovered that the #1 valve spring broken. That's the second one in 2 years. Don't know what's going on here. Drove it 20k miles after restoration so what's causing this. Got to figure that out first and fix then I'll report back on my Hot Spark experience.
Instal
D Anybody ever hear of...... Jaguar 1
G D would anybody be able to tell the correct way to static time a essex v6 I have tried and failed cheers garth TVR 14
Csarneson Anybody feeling optimistic? Or drunk? Austin Healey 21
Keoke Anybody heard: Austin Healey 9
Csarneson Anybody seen this Front Shock Conversion Kit before? Austin Healey 6
Gerard Anybody have...? Spridgets 9
TRMark General Tech Anybody Using Star Tron Triumph 2
J Anybody driving a 2018 Jaguar XJ? Jaguar 3
J anybody tell me why this thread closed? Austin Healey 4
TR3TR6 TR2/3/3A Anybody else having a bad day! Triumph 31
M TR2/3/3A Does anybody use the oils and lubes from the moss motors site? Triumph 3
TomMull Post-War Other Anybody interested in 10s? Triumph 15
2billydavies TR2/3/3A anybody need a spare rear bumper? Triumph 8
Randy Forbes Healarossa; anybody ever seen, or heard of it? Austin Healey 2
catfood Rivnuts anybody Austin Healey 19
H Joan Baex 1961 flat floor--silver exterior--anybody know what IRS sold it for? Jaguar 0
H TR4/4A Triumph 250-K by Pete Brock--anybody recall how much Brock advertised it for? Triumph 1
K Anybody Try Exactline blades? Restoration & Tools 4
B TR2/3/3A Anybody finish their car in laquer? Triumph 18
64Elan Anybody interested in an Italian Spridgit? Spridgets 3
Gerard Is anybody able to ID these racing/sports seats? Spridgets 0
Gerard Anybody have a steering wheel emblem for '68 Sprite stock steering wheel? Spridgets 11
S Anybody tried this Alternator ? Austin Healey 11
W Anybody have one of these surplus? Spridgets 5
krswen TR2/3/3A Anybody own TR3 TS 59719 L? Triumph 0
krswen Anybody own Series 1 E-type coupe 1E 32257? Jaguar 2
TR4nut TR6 TR6 under dash pics? Anybody? Triumph 9
DNK Wedge Anybody have any "good" adhesive? Triumph 2
B anybody know how and where I can get the cable ends for the heater cable? Spridgets 13
AN5Sprite Anybody Have A Bugeye Fuel Gauge Core To Spare? Spridgets 3
J Anybody need a 1500 motor? Spridgets 2
R July 15 Fairfield Ohio meet anybody going? Spridgets 8
Gerard Does anybody have a busted crank? Spridgets 3
regularman Anybody in Arkansas? Spridgets 2
rkep01 Anybody have one of these available? Spridgets 7
regularman Anybody got any cheap used distributor parts Spridgets 8
M TR2/3/3A Anybody ever dye wool carpet? TR3 Triumph 0
T TR2/3/3A Anybody need a TR3 frame and suspension Triumph 5
T Anybody Want to Play "Identify the Crud"? Triumph 2
DNK Anybody? Triumph 3
Banjo TR4/4A AAAAUG! anybody got an extra TR4A piston? Triumph 3
DNK Anybody have .. Lotus 1
jdubois Anybody tried these floats? Triumph 7
DNK Anybody need an Eclat Lotus 4
longbridgehealey Does anybody know this car?? Spridgets 0
DNK Anybody... Triumph 12
jdubois TR6 Anybody interested in a TR6 in boxes in MA? Triumph 16
Tr3aguy Anybody got 44k Triumph 16
L Anybody used.... Spridgets 9
S Anybody need a grocery gettery??! Other Cars 10
