HSTRL Static Display Reopens
Twosheds
For immediate release:
Dr. John Herrera, Chief Boffin of the famous and highly regarded High Speed Triumph Research Laboratory's Soggy Bottom Facility, made the following announcement to the press.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]The Static Display Area at HSTRL's Soggy Bottom Facility has reopened. As many of you know, the area was closed after the loss of the 1950 GMC Service Station Truck and the Mark 2 Spitfire. Thanks to the loan of this beautiful... [here Dr. Herrera seemed to become confused. ED] er... MG Midget, the area is now open once again! [/QUOTE]
Official Mascot Felix Holstein is Chairman of the Static Display as before.
The public may tour the Static Display Area as well as the Laboratory and Annex by prior arrangement.
G D would anybody be able to tell the correct way to static time a essex v6 I have tried and failed cheers garth TVR 14
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
BN6_2197 BN6 Static Timing Austin Healey 2
J TR6 73 TR6 Static Timing Questions Triumph 6
S Wanted MGB Static Seat/Shoulder Belts MG Classifieds 0
C Static timing before engine start up Spridgets 4
Jim_Gruber Static Timing a 948 in a BE Spridgets 12
B Static timing Austin Healey 8
C Static Ignition Timing Austin Healey 1
af3683 TR2/3/3A Set Static Timing on TR3B - Car Runs Poorly Triumph 27
M Test light to set static timing Triumph 39
af3683 TR2/3/3A TR3B Static Timing Triumph 28
T 100M Static Timing Austin Healey 0
I How do you static time a 948? Spridgets 4
mrv8q TR2/3/3A TR3 Static timing; point of confusion. Triumph 16
B Radio Static Austin Healey 4
MadRiver TR5/TR250 TR250 Static Timing Triumph 8
Tabcon Pertronix Static Timing? Triumph 15
H TR2/3/3A TR3A Timing [Static or Dynamic ?] Triumph 10
MGTF1250Dave TR2/3/3A TR3 Static Timing with Pertronix Ignition Triumph 5
dklawson Spitfire Spitfire Static Timing, Conflicting Data? Triumph 9
jjbunn Static Timing: 12*BTDC or 8*BTDC ? Triumph 17
MTribe setting static timing with pertronix ignitor Triumph 0
MTribe how to adjust static timing? Triumph 8
T static timing with electronic ignition? Triumph 10
I TR6 69 TR6 static vs moving timing - what is better? Triumph 6
T MGB Static timing a MGB w/ a Crane Electronic Ignition MG 5
Daimlerdb18 Timing light timing versus static test lamp MG 7
startech47 Static timing a 1979 Midget Spridgets 4
mrstinson Renew Dizzy and Static Timing Spridgets 15
P Static Timing Austin Healey 3
R Pertronix ignition and static timing MG 22
T How 2 remove "static" and white dust ? Restoration & Tools 8
A General MG 2022 Car Display Geelong MG Car Club MG 2
Guido36 Healey 3000 cutaway display engine Austin Healey 12
Michael Oritt Display ads in posts? Austin Healey 2
Boink Display at Portland ABFM Rover / Land Rover 2
Editor_Reid Healey Hundred Needed for Car Display in Arkansas Austin Healey 0
Shinsen774 MGB Need MGB LE for Show Display in Virginia 9-20-09 MG 6
ncbugeye Display of Restored Classic Cars in Raleigh NC Austin Healey 6
ddrumman Login name vs. display/username name. MG 22
simpzimmer walnut display cracks Restoration & Tools 4
S Tiger Window Display.......................... Sunbeam (Rootes) 4
G Overdrive display light Triumph 8
