Need Advice On 948 Engine Rebuild
mxp01
All:
I've torn down a 948 engine. It looks surprisingly good on the inside, but I'm a bit of a novice. I'm in Nashville, TN and i want to take the block to someone for a professional opinion regarding a possible re-bore of the cylinders. Any recommendations as to the type of shop I should be looking for?
Thanks,
Mike Pennell
P
Paul McGuffin
I would dump the 948 cc and find a 1275 cc or a late 1100 cc with the 2” main bearings. That’s just my opinion.
Paul
All:
Thanks,
Mike Pennell
SD Bugeye
My experience with 948
so my case I got free engine and free machining
I love my little 948 added a bunch of nice parts nice isky cam set h2 carbs
nice 12g big valve head header
it runs great approx 18,000 miles on it now. No plans on changing a thing.
but..
if I was to do another it would be 1275
its still way under powered
I hate to say it but you can't buy enough go fast to match a stock 1275.
i will have to say stop and find a 1275
its going to be a much easier cheaper stronger happier build
M
mxp01
Thanks, guys but I already have an original 948 in the car with some of the stage upgrades offered by BMC in 1959 (that I don't want to change at all), plus a ready-to-go 1275 (spare), but I'm looking to go completely stock on this 948 so I can use it with my Judson Supercharger. The 948 in the car has higher than spec compression ratio that won't support the Judson.
I'm taking the car to Europe later this year and I want all three engines at my disposal.
MXP
Whitephrog
Mike
You might contact Gary Johnson at East Tennessee Race Prep. He is superb on A series engines. If he can't help, he may be able to recommend someone in Nashville who can?
buzzman
I have run a Judson on my stock 948 sprite and it works quite well. One thing I would recommend for longevity and good oil pressure is to use a MK II sprite 948 block (9CG) because they have three cam bearing inserts. You could also have a Mk I (9CC) block machined to take the three cam bearings. I have had that done too. Yes, a 1275 would have more power and torque, but if you want to keep it original then the 948 is the way to go. I ran my super charged 948 in my bugeye with a 3.7 rear end gear and it handled it just fine.
Good luck,
Buzz
tr6web TR6 Need advice removing downpipe nuts Triumph 4
W Need advice on installing new side curtain glass Spridgets 1
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
CharlesBN1 BN1 Soft Top installation - need advice! Austin Healey 3
N Need brake bleeding advice Spridgets 6
CharlesBN1 need some advice fitting the bonnet on a 54 BN1 Austin Healey 4
Jer Thinning the collection, need some advice on pricing parts including a hardtop Spridgets 8
Bayless Need wheel bearing advice please Spridgets 4
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
davester Just got my Sprite back [in pieces] after 42 years...need advice Spridgets 8
T Need advice for installing a Winner's Circle Panhard rod on a BE Spridgets 4
R Need Advice On Refinishing A Bugeye Hardtop Spridgets 15
D Need Some Advice on My 1967 BJ8 Austin Healey 8
M TR5/TR250 Need some advice on TR250 Triumph 22
Jim_Gruber Need advice on how to fix this one. Spridgets 7
Jim_Gruber Issue with removing front drums and spindles on BE- Need advice Spridgets 5
R TR4/4A Need Advice as to what to do regarding Engine Compression Problems Triumph 26
J MGB Need some Exhaust flange advice MGB< but really any of our old cars MG 0
Jim_Gruber Bugsy II - Planning Welding - I need some advice Spridgets 14
B Cylinder Head - Need advice Spridgets 5
drambuie Need advice How to Install a volt gauge properly Austin Healey 16
Parker MGB MGB Chrome trim strip installation... need advice! MG 10
M Need advice on fitting rear pillar interior trim.... British Motor Corp 2
Patrick67BJ8 Painting inside of block with Glyptal-need advice Austin Healey 10
I Need some advice on bugeye conversion Spridgets 8
R TR2/3/3A TR3 Seats - Need advice Triumph 9
A need advice on fuel pump Triumph 12
britlover TR5/TR250 Looking at TR250, has issues, need advice Triumph 9
tri_carb_healey need some advice Austin Healey 8
Coyote1 Overider Restoration - need advice Triumph 1
B TR2/3/3A Need advice TR3b inner sill replacement Triumph 16
T T-Series Need Advice - MGTF Steel Wheels Need Attention MG 2
T T-Series Need advice re MGTF rack and pinion removal MG 4
T Need exhaust header advice/source for Amos Triumph 49
J need advice renewing front lower A-arm Spridgets 31
W restoring a BN2 - need advice on sheet metal Austin Healey 10
Sprocket Barake drum locked up - need advice Austin Healey 7
R engine trouble, need advice Spridgets 16
B I need some advice/suggestions.... Triumph 10
L Need advice on this 1953 XK120M - HELP Jaguar 7
R smiths guage problem- need advice Austin Healey 4
bobmga62 MGA mga hardtop... need reconditioning advice MG 7
kyreb1862 Need Some Advice MG 2
H Need advice, Should I Wrap the Exhaust Pipes? Austin Healey 7
jackq O/D problem..need advice MG 8
M Pulled the Trigger...Now I Need Advice! Spridgets 20
B T-Series Need advice on a 53 TD MG 2
T Need advice on a 1275 Spridgets 6
PATR8 Need advice on a new project [Volvo 240] Other Cars 19
