Need some advice on bugeye conversion
ichthos
I did a total restoration on a bugeye (as original as possible)for my wife. She doesn't let me drive it all that much, but on the few times I have driven it, I have to say I actually enjoy driving it better than my TR6. I was thinking of restoring a second basket case bugeye I have, but this time putting in a 1275 engine, ribcase transmission, and disc brakes. I am going to totally dismantle the body and make repairs there first. I have a few questions I am hoping to get your help on:
1) Are there any sheet metal modifications that will be needed for my plans?
2) What year/model car what I need to get donor parts from?
3) I was told by a local British mechanic to look out for a 73 or 74 Sprite, but can I get the same parts from a Midget, and if so, what years?
Any opinion/thoughts are greatly appreciated.
Kevin
Gerard
Kevin,
Sprite or Midget, no difference for your purposes. Any disc brake car will do; cars up to '66 have the correct DB MC to use in a Bugeye. See my web page for details on DB conversion issues. Years '67 to '74 for the 1275. Earlier engine serial numbers are a bit better, but you want the 12CD or later ('68). Entire range of DB cars, up to '74, will have a ribcase gearbox.
https://gerardsgarage.com/Garage/Tech/DbrakeUg.htm
drooartz
I picked up a '74 Midget parts car when I converted my old Bugeye to disc brakes and a 1275. That one car gave me all the bits I needed. Got quite a few things off that car, then was able to sell the Midget body on to someone else who needed one.
Article on stripping the parts car down:
https://www.drooartz.com/index.php?page=36
I used the Bugeye brake master cylinder and had it resleeved through Gerard's service.
taskadog
It will be hard to find a '73 or '74 Sprite, since they ended production in '71. The 1275 came out in '67, so any car after then will have what your looking for.
As to '67 to '71, Sprites and Midgets where indistinguishable from each other except for badges.
Good luck, Phil
I
ichthos
I must have misunderstood the mechanic. I am not ignoring any of your advice, but if I want the rib case transmission from a 73 or 74, a 1275 engine, and disc brakes from one car, that one car would have to be a 73 or 74 midget, correct? I know it will take me a few years to complete the body restoration on the bugeye I have, so it will give me time to look for the correct donor car.
Kevin
Gerard
No, not correct.
Anything after '67 up thru '74. "67's have the thin flange block is why I recommended '68 (12CD engine number) or later.
I
ichthos
Can you explain to me what a thin flange block is and why it is important? I really don't understand what is special about the 73/74 transmission that was recommended to me, Gerard. I think it had something to do with better synchros, wear, and availability of parts.
Kevin
mightymidget
with your conversion remember to grab the differential for better gearing. just in case you are wanting a wire wheel car, find an early 1/4 spring car with disc brakes. the earlier rear ends were different and axles fit proper.
you just switch out complete rear ends. you will find most earlier cars are rust outs and be purchased reasonably.
you will still need another doner car for drive line and rear end gear.
Gerard
Kevin
Kevin, observe the sump flange in the following photos. The thin Flange is a 12CC series 1275, the thick flange is a 12CD. This design change is constant on subsequent iterations. It was done to stiffen the block.
As far as the gearbox, the production change occurred within the 10CC (large main 1098) Spridgets and continued through the 1275 series. Other than the addition of a different shifters and a reverse switch, I don't think there area any other internal changes. Even though some parts numbers changed for some of the gearsets, the gears are interchangeable... i.e. 22G232/22G1100 (laygear)
R Need Advice On Refinishing A Bugeye Hardtop Spridgets 15
tr6web TR6 Need advice removing downpipe nuts Triumph 4
W Need advice on installing new side curtain glass Spridgets 1
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
CharlesBN1 BN1 Soft Top installation - need advice! Austin Healey 3
N Need brake bleeding advice Spridgets 6
CharlesBN1 need some advice fitting the bonnet on a 54 BN1 Austin Healey 4
Jer Thinning the collection, need some advice on pricing parts including a hardtop Spridgets 8
Bayless Need wheel bearing advice please Spridgets 4
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
davester Just got my Sprite back [in pieces] after 42 years...need advice Spridgets 8
T Need advice for installing a Winner's Circle Panhard rod on a BE Spridgets 4
M Need Advice On 948 Engine Rebuild Spridgets 7
D Need Some Advice on My 1967 BJ8 Austin Healey 8
M TR5/TR250 Need some advice on TR250 Triumph 22
Jim_Gruber Need advice on how to fix this one. Spridgets 7
Jim_Gruber Issue with removing front drums and spindles on BE- Need advice Spridgets 5
R TR4/4A Need Advice as to what to do regarding Engine Compression Problems Triumph 26
J MGB Need some Exhaust flange advice MGB< but really any of our old cars MG 0
Jim_Gruber Bugsy II - Planning Welding - I need some advice Spridgets 14
B Cylinder Head - Need advice Spridgets 5
drambuie Need advice How to Install a volt gauge properly Austin Healey 16
Parker MGB MGB Chrome trim strip installation... need advice! MG 10
M Need advice on fitting rear pillar interior trim.... British Motor Corp 2
Patrick67BJ8 Painting inside of block with Glyptal-need advice Austin Healey 10
R TR2/3/3A TR3 Seats - Need advice Triumph 9
A need advice on fuel pump Triumph 12
britlover TR5/TR250 Looking at TR250, has issues, need advice Triumph 9
tri_carb_healey need some advice Austin Healey 8
Coyote1 Overider Restoration - need advice Triumph 1
B TR2/3/3A Need advice TR3b inner sill replacement Triumph 16
T T-Series Need Advice - MGTF Steel Wheels Need Attention MG 2
T T-Series Need advice re MGTF rack and pinion removal MG 4
T Need exhaust header advice/source for Amos Triumph 49
J need advice renewing front lower A-arm Spridgets 31
W restoring a BN2 - need advice on sheet metal Austin Healey 10
Sprocket Barake drum locked up - need advice Austin Healey 7
R engine trouble, need advice Spridgets 16
B I need some advice/suggestions.... Triumph 10
L Need advice on this 1953 XK120M - HELP Jaguar 7
R smiths guage problem- need advice Austin Healey 4
bobmga62 MGA mga hardtop... need reconditioning advice MG 7
kyreb1862 Need Some Advice MG 2
H Need advice, Should I Wrap the Exhaust Pipes? Austin Healey 7
jackq O/D problem..need advice MG 8
M Pulled the Trigger...Now I Need Advice! Spridgets 20
B T-Series Need advice on a 53 TD MG 2
T Need advice on a 1275 Spridgets 6
PATR8 Need advice on a new project [Volvo 240] Other Cars 19
