Reinstalling 948 engine
Bill_Reid
I'm looking for guidance on reinstallation of my Bugeye engine after a rebuild. I did not remove the transmission when the engine came out. So it's a matter of lining everything up and bolting the two back together. However, we have already had one unsuccessful go at it......just couldn't seem to get the transmission shaft completely seated in the rear of the engine, although the shaft did pass through the release bearing properly. I asume that the rear of the engine needs to enter the engine compartment at a downward angle.....how much? How about the motor mounts? Attached to the engine? attached to the frame? Not attached til the engine is almost in? Any advice would be appreciated......thanks, Bill
nomad
I always use a couple of long bolts with the head's cut off and ground down to a little bit of a point to guide the engine and trans mating. A bolt on each side of the engine to slide through the mating holes on the trans. Of course the clutch plate has to be exactly centered and sometimes the input shaft needs to be turned a bit to get though the clutch plate splines. If you are having trouble right at the last I would expect that the clutch plate isn't centered or the angle is not quite right. The guide bolts would help the latter. Don't use too much force!
Kurt.
smaceng
If all else fails, take the transmission out and attach it to the engine.....I have always found that is the easier way to do it on the Sprite.
Scott in CA
B
Bill_Reid
Thanks. I'll give the bolts a try. Any thoughts on the motor mounts......Attached to engine? Attached to frame?
SD Bugeye
Lot easier stabing the input shaft thru the clutch and not as likely to scar the pilot bush with tranny out.
just remember to tape up the universal on driveshaft or it's another Easter egg hunt from that end too!
Billm
The motor mount by the steering column bolts to the car, the other one bolts to the engine
BillM
apbos
BillM
The motor mounts are "handed" , so mount to the correct side. Do not ask how I found out.
Paul
nomad
I've always found it a toss up on bolting the engine and trans together in the car or out. I'm ready to pull the engine in my BE and will leave the trans in. If you get things lined up it should slip together. The usual problem is that the clutch disc isn't quite centered. I have an old trans input shaft to use for centering the clutch disc but I've done quite a few of other match's by eye balling the clutch disc but only tightening the pressure plate enough that it holds the clutch disc loosely. Then with my guide bolts I slide the trans in. Then I'll remove it and do the final tightening on the pressure plate. Really never had a problem with these technique's.
KVH General Tech Reinstalling TR4A Interior Triumph 13
Jim_Gruber Reinstalling Brake Hubs and Wheel Hubs in Rear. Spridgets 5
T TR4/4A How do you go about reinstalling cylinder head? Triumph 7
pkmh Reinstalling oil pressure gauge in a BJ8 Austin Healey 4
Jim_Gruber Reinstalling Rear End in a BE - Quick Steps Spridgets 8
Lin Reinstalling rear springs and axle in 64 MK2 Jaguar 1
T MGA Grease axle stub before reinstalling hub on a MGA MG 2
T TR4/4A Prep before reinstalling TR4a gas tank Triumph 2
TRnorwegian Reinstalling the old Strombergs Triumph 2
TR4nut TR2/3/3A Question on reinstalling pinion flange on TR3A Triumph 8
T Reinstalling radius arms etc... Spridgets 4
zimmy reinstalling windshield Spridgets 1
G Reinstalling my Roller Rockers Triumph 4
J help with reinstalling the rear diffy on a 6 Triumph 8
B Reinstalling front springs. Spridgets 11
MGTF1250Dave Reinstalling Cylinder Head MG 3
M How Do I Set Timing On 1990 Marelli Ignition V12 after reinstalling distributor ? Jaguar 0
sim looking for 2 valve spring kippers for a 948 Spridgets 3
sim 948 aluminum head gasket Spridgets 2
R Extra 948 and 1098 Engines Spridgets 9
R 948 convert to 1275 info Spridgets 13
M 948 Cylinder Block Studs - Sequence on Cylinder Block Spridgets 4
M 948 Engine Rebuild Question Spridgets 0
M Vacuum Line on a 948 Spridgets 4
A Bugeye engine swap, 948 to 1275 Austin Healey 11
pbraun For Sale Free 948 and smooth case Spridgets Classified 0
M 948 Engine ID help Spridgets 3
apbos Turbo 948 engine? Spridgets 3
F Ribbed case tranny in 948 bugeye Spridgets 2
J New Guy 948 ribcase question Spridgets 6
M Timing Chain on 948 Rebuild Spridgets 1
Jim_Gruber What is the correct Radiator Cap for a 948 with a Downflow Radiator Spridgets 4
M 948 Side Cover Needed Spridgets 0
M Need Advice On 948 Engine Rebuild Spridgets 7
M 948 Pulley Nut Size Spridgets 1
M Engine Stand - What Bolts Recommended for 948 Spridgets 3
Jim_Gruber Shift Points for Bugsys 948 w Cooper S Head Spridgets 3
M 1275 to 948 Generator Swap - Need Input Please Spridgets 4
Jim_Gruber Static Timing a 948 in a BE Spridgets 12
Jim_Gruber Question on 948 Head Torque Specs - Before I break something please Spridgets 3
Jim_Gruber Coolant Bypass Nipple on 948 Welded Closed - Advice needed Spridgets 7
AN6-TX 948 Thermostat Housing Spridgets 11
certifiedcarnut 948 front brake shoes warning Spridgets 5
certifiedcarnut pipe between front brake wheel cylinders on 948 midget [drum brakes] Spridgets 4
SD Bugeye Are there any of us with 948 builds left? Spridgets 13
M 948 clutch hydraulic line Spridgets 7
bugedd So I drove my first 948 Bugeye...... Spridgets 25
D wtb 948 exhaust manifold Spridgets 3
D 948 Oil Cap Spridgets 5
Trevor Jessie 948 engine with a 1275 head question. Spridgets 3
