How Do I Set Timing On 1990 Marelli Ignition V12 after reinstalling distributor ?
Michael J.
I removed the distributor on a 90 XJS V12 to replace leaking O-ring at base. 90 model year has Marelli Ignition. I can't seem to find a procedure for setting initial timing in service manual. I aligned mark on Dymanic Balancer with pionter where magnetic pickup is and set rotor to 1A plug location. How do I determinr rotation of the slots with respect to the three set screws? Any ideas?
af3683 TR2/3/3A Set Static Timing on TR3B - Car Runs Poorly Triumph 27
T How do you set the timing on a Pertronix distribu Triumph 13
M Test light to set static timing Triumph 39
M Timing Light Set Up MG 4
drooartz Set timing for first time Spridgets 3
5 vendor for 948 timing set Spridgets 5
2wrench Timing set on newly installed BP270 cam Triumph 7
E Replacement timing set Triumph 3
Cain Distributor/Timing Set Up Triumph 7
nathandarby67 Best way to set the timing on a Midget MG 9
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
S TR2/3/3A old 4 bolt axle set up Triumph 12
S For Sale twin Weber 40 DCOE 31 set Other British Classifieds 0
S Weber carb set Other British Cars 7
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
Gatheringtree TR2/3/3A Gauge Set Triumph 17
Gatheringtree TR2/3/3A Billet Pedal Cover Set w/ Triumph logo Triumph 0
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
M Wanted WANTED...New TR6 piston set. Triumph Classifieds 2
HealeyPassion For Sale Tri-Carb Complete Set including manifolds Austin Healey Classifieds 13
K TR2/3/3A An Unusual Brake and Clutch MC Set Up? Triumph 2
71TR6 Set of 4 TR2/3/4 Connecting Rods Triumph Classifieds 0
J TR2/3/3A Confirming Cam Set Up Triumph 5
Walter74 Insulation set from Koolmat Austin Healey 3
G Valve adjustment and easiest way set cam position Austin Healey 15
Michael Oritt HD-6 support set Austin Healey 4
TRopic6 For Sale Vandervell .010 Rod Bearings, MG TB, TC, TD, TF [Partial set] MG Classifieds 0
S TR2/3/3A understanding the float and needle set up better Triumph 6
ArchieMcAllister Wanted Rebuildable set of HD8's Austin Healey Classifieds 4
R For Sale Italian Triple Weber Set Triumph Classifieds 1
6TTR3A TR6 TR6 Trunk lock set screws Triumph 2
S TR2/3/3A paint gun set up Triumph 15
histerical Wanted WTB Set of Later Spridget Rear Brake Backing Plates Spridgets Classified 0
H For Sale Rear end bearing and seal set Austin Healey Classifieds 0
B Wanted Need '58 TR3 adjustable steering set up Triumph Classifieds 4
K TR2/3/3A Rear bumper over rider set up. Triumph 2
Got_All_4 For Sale Triumph Austin Healy Jaguar 15"x5.5" Complete Wire Wheels Set & Hubs Triumph Classifieds 1
D BT7 tri-carb linkage set up Austin Healey 23
Michael Oritt Moss Motors rear brake "set" Austin Healey 11
Basil SOLD!! Set of Whitworth Sockets for sale Other British Classifieds 1
S For Sale Triumph Weber DGV dual Carb Set Up - $325 Triumph Classifieds 0
J For Sale Wire wheel set Triumph Classifieds 2
J Wanted HD8 SU carb set Austin Healey Classifieds 6
M For Sale Aston Martin wheels for Sale - $1600 - Full set in the original boxes Other British Classifieds 1
H Third Member - Differential - Carrier Housing - Center Section - Gear Set Cleaning Spridgets 4
Griz Carpet Set Questions Austin Healey 9
DrEntropy For Sale Midget/Sprite carb set Spridgets Classified 0
D For Sale TR3A-B Side curtain set - white Triumph Classifieds 1
T Wanted tube shock set-up/brackets for MGB MG Classifieds 1
K Wanted A set of TR3A windshield tenon plates. Triumph Classifieds 1
