TR2/3/3A Confirming Cam Set Up
jruddsr
I need some help. I am rebuilding my Tr3 engine and have installed a new standard camshaft, chain and gears. The WSM is pretty clear about timing the cam with unmarked gears. Set cam at point of balance on cylinder #4. Set #1 piston at TDC and install chain. My cylinder head is not installed so I made a “Macy’s Garage” dial indicator setup and degree wheel.
This is pretty straightforward, if this is correct.
Now for my problem. The WSM provides a nice graphic of the crank rotation with intake and exhaust valve timing. Intake opens at 17 degrees BTDC and closes at 57 degrees ABDC. Exhaust valve specs are also provided. Try as I might, I cannot confirm those specs with my degree wheel. What am I missing?
CJD
Timing using cam lift is a bit more complicated than just reading the lift. Some list the valve opening as initial cam movement, .030" of lift, or .050" of lift. This is because the initial ramp on the cam is very subtle as the lash in the valve train is being taken up, and then motion is faster and easier to measure.
So, my first question is if the cam came with a degree card that tells at what cam lift they measure the timing? It should be something like: .012" or .050", etc.
mctriumph
Point of balance on #4 ....doesnt look like you are checking #4 ... 2 push rods in #4 will have a zeropoint where one is the same height as the other
with the 1 pistol at TDC, you will be as close as a stock cam has to be .NOT up to race spec however and you will not have checked to see if the
specs on the cam are accurate.This can come as quite a shock but I have seen badly cut cams.....
MD(mad dog)
J
jruddsr
John, There was no degree card included with the standard cam. I guess the idea is, since it’s a standard cam, use the WSM method and don’t worry! (Be happy).
MD, I set the point of balance at #4, installed chain with #1 at TDC. I moved the dial indicator to #1 in an attempt to confirm the cam was set up correctly. I was hoping I could confirm the specs in the manual, but no luck. I think you are saying use the WSM method and move on, right?
John
CJD
OK...I think I understand...you set up the balance point at #4, just as you should. But if the crank is at that point in the rotation, you would have to check the lift on #4 intake for 15 degrees before TDC movement.
In other words, the #1 cylinder is in the firing stroke where you set the cam, so the #1 valves are both closed tightly, and will be for almost 1/2 crank rotation. To do your check, assuming you have just set the cam sprockets, and you are now set up on the #1 tappets, you will need to move the dial indicator to the intake tappet, which is the second lifter from the front of the block. Then turn the crankshaft clockwise from the front for 345 degrees...to 15 degrees before the NEXT TDC, but almost one full rotation out from where you set the cam in the manual instructions. This point is where the second lifter should start to move upward.
Sarastro
The basic idea is that you set the crank at TDC and the cams for that cylinder to the point where the valves are open the same amount; then that is TDC at the exhaust cycle. You can do this with any cylinder. Then install the timing chain, with the camshaft timing gear in the position that makes the chain fit precisely. Frankly, I thought that the method in the shop manual was not likely to be very accurate. Here is what I did:
http://tr4a.nonlintec.com/engine/#timing
The engine is finished and the car is on the road. It runs very well.
Jer Confirming the best choice for clutch / release bearing for my 67 Midget Spridgets 2
J TR 4 Norris Cam 342S Spec Sheet Racing 1
PAUL161 T-Series Crane Cam MG 0
D TR6 Gp 2 cam, head shaved ,shorter pushrods, with a rough idle Triumph 10
M MGA RHD twin cam steering pinion MG 0
D Cam Timing question. Spridgets 11
TomMull TR2/3/3A Steering Box Cam or Worm Triumph 18
S TR2/3/3A Replacing the cam shaft Triumph 27
K TR2/3/3A Rebuilding an Engine?..New Cam Sprocket & Gear...1/2 Price Triumph 0
Kolecki TR2/3/3A engine assembly cam timing issue Triumph 8
K TR2/3/3A Finding valve lash with cam specs? Triumph 8
Got_All_4 TR5/TR250 Cam and Lifter Problems Triumph 13
B Installing cam bearings 1275, can I do it? Spridgets 1
B Anyone have a Europa Twin Cam for sale? Lotus 6
G Valve adjustment and easiest way set cam position Austin Healey 15
Walter74 Kent AH4 cam shaft Austin Healey 18
J General TR Cam shaft upgrade????? Triumph 3
S TR6 Quiz .... What cam is this? Triumph 0
J TR2/3/3A Triumph TR3 cam shaft measurement Triumph 2
B TR4/4A Front cam bearing Triumph 8
B TR4/4A Performance cam Triumph 24
K TR2/3/3A More pics of Kast Cam Triumph 4
K TR2/3/3A Kast f cam...301466 Triumph 5
L TR2/3/3A Cam follower rotation Triumph 5
Csarneson BN4 Cam Gear Install Austin Healey 3
N Best cam choice??? Spridgets 5
KVH TR4/4A I Replaced the Cam Bearings Triumph 19
M Wanted TR3/4 Cam Bearings Triumph Classifieds 1
R General Tech Cam measurement. Triumph 6
Got_All_4 TR6 Cam selection decision time could use your thoughts Triumph 2
M TR2/3/3A Cam Bearing Tool Dimensions Triumph 16
W Cam gear position BJ8 Austin Healey 11
R TR6 Cam choices? Triumph 23
T TR4/4A Core Plug - Cam Rear change Triumph 7
D cam bearings Austin Healey 23
KVH General Tech Engine Rebuild: Failed at Cam Break-in Triumph 11
E TR6 Some cam questions Triumph 9
steveg Denis Welch mild cam Austin Healey 9
B Twin OH Cam for the BIG Healeys Austin Healey 15
K TR2/3/3A Street cam again and Valve gap? Triumph 6
K TR2/3/3A Mild street cam and Idle? Triumph 13
T Spitfire Cam shaft Triumph 3
J MGB MGB cam, gear? MG 3
K TR4/4A Performance Cam=Broken Rings??? Triumph 9
Marvin Gruber Cam shafts for 3000 Austin Healey 2
J TR4/4A Cam Timing with Head Still On HELP! Triumph 8
K Kastner "F" race cam. Racing 3
mgedit TR2/3/3A Cam Sprocket Bolts - Shoulder or not Triumph 6
B TR2/3/3A Positioning new cam sprocket Triumph 4
