TR4/4A Front cam bearing
bammons
Another dumb question from me. Why does the front cam bearing not come in the cam bearing sets? Does it not always need to be replaced even if the others are replaced? Is it a true "bearing" or more of a guide that is not as critical as the others? Would you always replace it if a new cam is used? Thanks Bruce
TR3driver
Great Pumpkin - R.I.P
Definitely a bearing, takes more load than the others because of the chain drive. Often it's the only one that needs to be replaced, and in fact on some engines the others are not replaceable. I forget the change point offhand, but TR2 only had one replaceable bearing. So did TR5-250-6.
Check the fit of the new bearing carefully; it's what controls the end play of the camshaft.
bobhustead
The front cam bearing is, i think, pictured by Moss at part #827-000. It is different from the other inserts, being more beefy and mounted with two bolts thru a flange to the front of the block. We call them all bearings but they are bushes without any moving parts. I don't know the clearance specification, but it is listed for $99.00. Why scrimp with a new cam.
Bob
CJD
The specs are in the Service manual. I’d recommend taking measurements before replacing the front bearing. My TR2 was 60 years and 58k miles old, but showed no measurable cam bearing wear.
TR3driver
B
bammons
Bob - Yes it is $100 for a replacement. If I took the theory that I just replace everything that may or may not need it on a full engine rebuild/full car rebuild then that could cost me much more than $100. But I will of course replace what is needed that is why I am asking. I am just a parts changer not a mechanic and am attempting my first engine build. In light of Randall's answer and because I am replacing the cam I will order a new bearing. thanks for the answers
TR3driver
I didn't mean you should automatically replace it; just check it for wear. Don't think I've ever done an engine like John's, with only 58,000 miles.
B
bammons
Yes John's is very low miles for such a old car. Mine shows 85,000. Part of my concern is that this engine was rebuilt around 1980 and has very few miles on it since. It has been sitting. I do not know what was replaced or not. So if it was put in new then it would be virtually new now. But I am putting the BP270 cam from BPNW in it so unless it was like new them I should put a new front bearing in (cam bearing set from TRF is on the way). What is the tool called that measures the internal diameter so I could check it? Can I buy it cheap like at HF? Or should I just order a new one?
TR3driver
Kind of tricky, but this is what I use.
https://www.harborfreight.com/6-piece-telescoping-gauge-set-5649.html
Takes some "feel" to get it right; you have find the point where the gauge just catches in the bore as you move the handle through center. I always do it at least twice, and repeat if they don't agree.
But you can also get a pretty good idea by just slipping the bearing onto the cam and trying to wiggle it. If you can feel it move, it's probably worn enough to replace.
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
Carlbanan56 MGB Front hub MG 4
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
C MGB-GT MGB-GT Front Ride Height MG 0
C MGB-GT Front Ride Height MG 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
AUSMHLY Front Wheel Spin Drag Austin Healey 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
bighealeysource Front Brake Adjusters Austin Healey 0
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
G Rebuilding Front Seats Austin Healey 4
drooartz MGB Front suspension rebuild is next MG 57
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
H TR4/4A Advise asked for front repair Triumph 1
A BN7 Front Hub Stud Nuts Austin Healey 5
P 100/6 Front Wheel Alignment Austin Healey 10
Prof. T Wanted 1974 - TR 6 Front Chrome License Plate Holder Triumph Classifieds 1
S For Sale Triumph TR 2-3 Front Left Fender Triumph Classifieds 2
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
P MGB 1974 MGB front spring length. MG 0
B TR4/4A Spax, Gaz and Koni on Front Triumph 12
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
G MGB '71 MGB Front End Rebuild MG 2
Popeye TR4/4A Latest thoughts on TR4A front springs? Triumph 8
X Front End Alignment Austin Healey 14
FrogPond "57 100E Front Hubs on E494A Spindles ? Other British Cars 6
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
K TR2/3/3A Oil leaks at two front cylinder head studs? Triumph 3
craigshealey3000 Front End Shake Austin Healey 31
K TR2/3/3A Centering the brake rotors(disk)s in the front brake calipers using the shims? Triumph 5
